Question about HP VP6121 Multimedia Projector
Hp projector vp6111
Lamp was replaced and give me a 15 seconds warning that the lamp have to be replaces, and this is a new lamp, how do I reset to zero. It do not give me chance to enter to the Menu
    Problem Solver:
  • 5 Answers
Go into the menu and find the lamp timer. You should then be able to reset the timer back to zero.
Posted on Jun 03, 2009
HP VP6111 Projector. problem: From day one when I bought it brand new, this projector had problems starting the bulb. Everytime I didn't use the projector for some time, when I tried to turn it on it...
It is a pity you did not return it after the first problem. If it is still under Warranty, I suggest you do now. Even if it is out of time, it is still 'not fit for purpose '
Mar 13, 2014 | HP VP6111 Multimedia Projector
Can't reset lamp timer after lamp replacement on Panasonic PT-AE40000
I have a Panasonic PT-AE4000U and could not reset the timer after replacing the bulb with a, non-Panasonic branded bulb. Calls to tech support were not very helpful. It was another bad customer service experience. Through troubleshooting it myself, I discovered the solution was simply to unplug EVERYTHING (serial cable, hdmi cables, etc.) from the device, power it off and back on. Follow the procedure in the manual, the timer immediately reset!!
Feb 11, 2012 | Panasonic Office Equipment & Supplies
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
Lamp for PLV-Z2000: Hello , I have a Sanyo Z-2000 projector. Aft...
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 12, 2010 | Sanyo Lamp for PLV-Z2000
I replaced the lamp when and the red LED light
More likely a faulty ballast. Check connections.
Jan 19, 2010 | HP VP6111 Multimedia Projector
Just replaced vt700 lamp. projector still indicating faulty lamp. i also reset the lamp hrs by pressing help on remote. can any one help thanks
Try the old lamp again and reset again and see if that works. When you originally replaced the lamp did it give you a warning that replacement was required or did it just stop? I haven't worked on that model before but you may require a new Ballast (power supply ) that runs the lamp (technician job usually)
Lamp replacement
Hi there
There is normally a sequence of buttons on the Projector that needs to be pressed ! What make and model do you have ?
Sep 16, 2008 | Panasonic Videoprojector PT-LM1E...
Replace lamp warning light goes on after raplacing it with the new lamp
I had the same problem. There is an internal reset button just above the lamp that needs to be reset. You have to take the cover off, which would void your warrantee, but it's quite easy. My lamp only had 660 hrs, and I bought a new one too. So now I have an extra. My guess is that my filter was getting clogged causing an overheating situation and tripping this reset button which I'm guessing is a heat sensor.
Jul 21, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Replaced Lamp and warning is still on screen
This work´d great
the "please replace the lamp" text disappeared but the lamp timer is still on the same, but i am still satisfied that the big red text on the screen is gone :P
/Newton from Sweden
Feb 29, 2008 | Sony VPL CS5 Multimedia Projector
Sanyo plc-xu35
Sounds like a simple problem to fix but don't ask here unless you plan on signing up...take your projector to a "real" professional who'll actually speak to you.
Sep 12, 2007 | Sanyo PLC XU35 Multimedia Projector
HP VP6121 Multimedia Projector Logo
291 people viewed this question
Ben Johnson
