Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
The arrow does not line up with the direction the trolling motor
Goes.
  • southernseas Dec 31, 2008
    I have the same problem. What adjustment is done to correct this?
4 Suggested Answers
SOURCE: the arrow on top of unit does not line up with the direction the
Sometimes when you disconect your battery for what ever reason and later hook the battery back up you will cross the wires and the motor will run backwards.
Posted on Nov 27, 2008
SOURCE: On my standard motorguide trolling motor the
put the motor in the water and ensure that the propeller is at the rear. On the head of the unit (where the direction indicator is) push down and turn the round plastic plate (this plate has the direction indicator on it) clockwise until the direction indicator mark (mine is blue and is about one inch long) is in line with the alignment bar on the non-moveable part on the head. You will hear several "clicks" and this means that the indicator plate is clicking around to the proper directional alignment with the motor in the water.
Posted on Jun 17, 2010
  • 24 Answers
SOURCE: I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Posted on Jun 29, 2010
Lot of interference with unit transducer mounted on trolling motor when trolling motor is being used. Then clears up when not used.
Some how you have Radio Interference conflicting with your unit. The RF as it is called, may be coming from the engine. Try to connect to an INDEPENDENT power supply for the Eagle and not the same source your trolling motor. You seem to be getting line interference.
Feb 02, 2015 | Eagle Fishelite 502c Igps Fish Finder...
Bearings for trolling motor shaft?
try a dealer who sells this machine or go on line to the maker and open up the spares section.
Jun 22, 2013 | Boating
Motor works fine but red indicator arrow does not move in direction of motor . what could be wrong.
you could have a broken gear inside the top of the motor. take the cover apart and you will see 3 plastic gears. one on the motor shaft, one on the indicator and one in between. check all gears are ok.
Jul 01, 2010 | Minn Kota Edge 40 Freshwater Bow Mount...
On my standard motorguide trolling motor the direction indicator points one way my motor goes the opposite direction. How do I fix this?
Jun 13, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
No owners' manual
I have a Motor Guide Trolling Motor - Bow Mount - Model-71V- 24 Volt. Problem is arrow on top of motor does not align with the direction motor is going about 100 degrees off. Any solutions? wm.513@hotmail.com
May 12, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Mar 09, 2010 | MotorGuide Standard Motor Replacement...
Trolling motor doesnt work?
Most trolling motors have in-line breakers, I would start there & see if one went bad, then check the wiring under the foot pedal for broken or corroded contacts, then you will have to trace wires & make sure everything is in order starting at the trolling motor plug.
May 24, 2009 | Boating
The arrow on top of unit does not line up with the direction the
Nov 19, 2008 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
201 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
