Question about Samsung VP-L750 Camcorder
Samsung VP-L700 Hi-8
I have a Samsung VP-L700 and i think I have plugged my phone charger into it by mistake. Needless to say it now does not work. It doesnt power up at all and when connected with the correct charger the charging light doesnt come on either. Is there a internal fuse that can be changed or have I fried it.
  • Tony Parsons
    Tony Parsons Jan 12, 2018
    Most people put an adhesive label on their chargers, to ensure this does not happen.
    Master:
  • 669 Answers
The majority of electronic manufacturers are aware of users making mistakes with power sources; thus they generally fit electronic devices with a special size input. A small plug will not fit into a large input and visa versa. That eliminates mistakes using various power supplies. I doubt if you fried the Samsung, but stranger things have happened from time to time. Take the 700 to your local provider and ask them to run a test. Go from there.
Posted on Jan 12, 2018
techman
  • 3130 Answers
SOURCE: Samsung VP W95D Hi 8 Camcorder
are you trying to charge the battery while on the camcorder??? does the camcorder work when you plug the camcorder into the charger?? If the battery fails to charge while its on the charger it can only be the charger but most likly the battery. If the camcorders dead it could be the dreaded pana cap think thT HAPPENS TO MOST CAMCORDERS AFTER A LITTLE AGE. good luck
Posted on Apr 14, 2006
INTERLOGIC
  • 326 Answers
SOURCE: apply force to cable for phone to charge
try cleaning the connecting point
Posted on Jul 07, 2009
270rexton
  • 782 Answers
SOURCE: samsung omnia problem trying to charge battery
It looks like battery is damaged... When plugged in to charger phone shouldn't power on. Try put it on charger when on and see if charging icon appear. (top right corner-battery status icon should change -insted of battery to charging.) Battery is fully charged after cca 4 hours, 80% after 2 hours.
Posted on Jul 16, 2009
GrinningFool
  • 625 Answers
SOURCE: My Samsung Blackjack II won't charge.
Return to the carrier for warranty repair.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II Battery charging problems
Posted on Jul 27, 2009
nightlisa
  • 102 Answers
SOURCE: Samsung glyde - no response to charging
Find someone else with a glyde and ask them if you can trade them batteries for a day to see if it's a bad battery. ( you can usually buy a battery for $5 on ebay, or up to $20 in your carrier cell phone store)
If the problem follows your old battery, toss it and buy another battery.
And if neither swapping out the charger and the battert solve your problem then its the phone itself. I have called in to our cell companies before and let them know we have a phone that will not hold a charge no matter what battery or charger I use... and they usually replace free it under warranty as long as the phone is less than 12 months old, and the white squares in the battery compartment are still white. (Pink Red means oops! water got in there) and then you’re only getting them to cover replacement if you have cell phone insurance
Posted on Jan 07, 2010
Have a 64 bit ACER Laptop with Window 7 pre-installed with it. Whenever i am trying to install PC suite driver for Samsung SGH L700 on my Laptop its showing In-compatible error message. Please...
I think you are using incompatible drivers. Because Samsung no longer use PC suite. Try searching for Samsung KIES. It is the one compatible with Windows 7.
Cheers!
Jul 03, 2011 | Samsung SGH-L700 Cell Phone
I have samsung l700 whose imei has been set to 000000000 by mistake, what should i do??? and can i get my original imei no. back???
hi,
it will fix by repairing its IMEI in a gadget called z3x...go to a certified mobile tech that having that kind of gadget...
Apr 13, 2011 | Samsung Cell Phones
My Samsung L700 IMEI no. was erased by mistake due the #*7337# code what i do
I'm affraid you have to rewrite the sofware or you can try this *2767*3855# -> Full EEPROM Reset ( THIS CODE REMOVES SP-LOCK!!!! but also change IMEI to 447967-89-400044-0, you must use CHGIMEI to restore it) but be careful this cod is very dangerous and work on older model i don`t test it on new ones
Mar 08, 2011 | Samsung SGH-L700 Cell Phone
Hi there,bit of a novice at this,i wish to download a driver for a samsung camcorder..VP-D10 .i have the correct cable,but where do i go from here...having bother getting the correct driver.as i would like...
Drivers and software in the link
Samsung VP-D10 Drivers Download - Update Samsung Software
https://www.solvusoft.com/en/.../drivers/mini...camcorder/samsung/vp-d10/sub-model...
  1. Cached
Samsung VP-D10 drivers are tiny programs that enable your Mini-DV Camcorder hardware to communicate with your operating system software. Maintaining updated Samsung VP-D10 software prevents crashes and maximizes hardware and system performance. Using outdated or corrupt Samsung VP-D10 drivers can ...
Instruction manual
SAMSUNG VP-D10 OWNER'S INSTRUCTION BOOK Pdf Download.
https://www.manualslib.com > Brands > Samsung Manuals > Camcorder > VP-D10
  1. Cached
  2. Similar
View and Download Samsung VP-D10 owner's instruction book online. Digital Video Camcorder. VP-D10 Camcorder pdf manual download.
samsung camcorder vp d10 software Google Search
Dec 07, 2017 | Samsung VP-D10 Mini DV Digital Camcorder
SAMSUNG
I cant understand the above solution that idea will never work for samsung l700 model but i think it could work in another manner please check in since it dnt work in my mobile (l700)
go to http://www.cell11.com in that go to computer softer column and in that u will have a softer called "my phone explorer" this software could be helpful since it has a java app installer PLEASE CHECK THIS AND POST A COMMENT COS I ALSO NEED IT
Apr 29, 2010 | Samsung SGH-L700 Cell Phone
Samsung sgh l700 mobile
Hi!
Remove the memory card and the plug it again.
Be sure you place it properly.
Hope it helps..
Thank you for reaching Fixya.
Please leave comments for further assistance.
Apr 06, 2010 | Samsung SGH-L700 Cell Phone
Front camera problem
wrute *#0*# and den go to 8.vga camera test it works dide
May 27, 2009 | Samsung SGH-L700 Cell Phone
Apr 13, 2006 | Samsung VP-W75 Camcorder
Samsung VP-L750 Camcorder Logo
82 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
