Question about Cooktops
MAGIC CHEF GAS STOVE/OVEN TURNS ON & OFF
MY GAS STOVE / OVER FROM MAGIC CHEF INITIALLY TURNS ON BUT SHUT ON & OFF INTERMITTENTLY, WHILE TRYING TO GET TO THE TEMPERATURE SETTING. THE OVEN MAKES A LOW MUFFLED POPPING SOUND, (LIKE WHEN IT SHUTS OFF), WHILE TRYING TO HEAT UP TO TEMPERATURE, REGARDLES OF WHAT TEMP IS SET. THIS SHUTTING ON AND OFF CAN HAPPEN EVERY 10 - 20 SECONDS.
AT TIMES IT WON'T ACT UP AT ALL. I HAVE CHECKED THE VENT HOLES ON THE OVEN AND THEY ARE ALL CLEAR
  • Anonymous Dec 10, 2008
    the same problem described by previous poster
Your technical support is horrible after being left on hold for so long and being told to pay 10.00 just to ask a question is poor business.
Posted on Nov 20, 2008
What wood cause a burner to ignite and will not turn off.
Is there an orange glow in the burner area when this happens? If so then the thermostat is not shutting the ignitor off and needs replacing. If there is no glow then the gas valve is not shutting off the gas and needs repalcing
Oct 10, 2014 | Whirlpool Kitchen Ranges
I have a magic chef oven the model number is 439w 3w, i need new burner knobs and oven thermostat knob, i need help trying to find them. Can you please help.
Hello, Thank You for using FixYa. I will be helping you today.Assuming the model is correct here you go http://lookup.bellparts.com/lookup/13830/76035
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Magic Chef 30 in. 8241RT Gas Cooktop
Magic Chef Gas Stove Model CGC2536. 1. On just one of the 5 burners the"Lite" function doesn't work. On all the others you hear clicking, and the gas lights. But on one, no clicking at all....
Try Google your manufacture name model # and the word parts. This will not correct your lighting problem. It sounds like you have a igniter switch problem.
always unplug electricity before attempting to repair on any electrical appliance
Sep 04, 2017 | Magic Chef CGC2536 Gas Cooktop
Magic Chef propane in 90 Terry 5th Wheel
unfortunately the model plate for these
was usually mounted on the the drop wall
or were paper on the inside right corner
Oct 05, 2009 | Cooktops
One of the burners won't light. The stove top is ceramic electric. It is a Magic Chef oven. Other three burners work.
check all wires to burner and switch. If they are good .....burner burnt out or switch no good.
Aug 05, 2009 | Cooktops
Magic chef rv oven burners work fine oven pilot hard to get lit and when it does lite the oven burner will not lite can you help me
thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
Apr 08, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
My Magig Chef Glass Rangetop
This part can cost over $400. It is usually not worth fixing. NEVER operate the stove with a cracked top. This is tempered glass and it can just explode! It is also a dangerous electrical issue. Liquid can drip down through the crack and contact the live open element.
Jul 13, 2008 | Magic Chef 30 in. 8241RT Gas Cooktop
Magic chef range
f1 is the code for a failed clock most of the times you must replace the clock most of them have a five year warrenty check your owners manuel for warrenty info
Mar 12, 2008 | Cooktops
Cooktops Logo
182 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
