Question about Dimplex Compact Electric Flame Stove Heater
The switch broke on my model DS3311 and while taking it apart, it broke the one of the other switches. I need two switchs and the wiring diagram for this model
  • Anonymous Jan 25, 2009
    I have the same problem. The light comes on but no heat or fan. Took it apart and found a broken switch. Local hardware stores had switches but not correct width. Need correct switch and wiring diagram.
  • 65 Answers
Either go to: www.dimplex.com or call their number: 1-800-668-6663 ext : 358 They are very helpful!
They can help you with a reapir manual you can download as well!
Posted on Jan 05, 2009
1997 5.7l V8 ext. cab. How can I replace ignition switch?
You will need to take the steering column apart to replace the switches. You will need specific tools to do it also.
Check this link:
1997 Chevy truck ignition switch replacement
Feb 04, 2016 | Chevrolet Silverado 1500 Cars & Trucks
Chain on a JInyou E70469 3 speed fan switch broke. need to replace switch
I have this exact Jin-You E70469 switch. Forget a replacement unless you drop about $20 on ebay. Westinghouse replacement switches did *not* work for this type of switch. Here's the solution that worked for me: CUT THE POWER and test before you touch anything electrical. 1) Diagram the wiring configuration of the switch noting where things go---take pictures. 2) Take out the wires that connect to it. Use a paper clip to spread the clips to pop them out. If you have any wires that come out and back in the switch itself, you can leave them attached. 3) See those pins that keep the housing together? Get a drill bit---or Dremel tool---just slightly bigger than the bottom of the pins. You're going to drill off bottom/rolled over part of those pins. Take it easy. LEAVE THE PINS IN. Do not take the pins out. With the bottoms of the pins ground off gone, now take off the nut that's threaded onto where the chain comes out. Now, carefully pry apart the bottom of the housing. Take a picture. Notice the position. Notice the position. Now, pry the little closure carefully just a little and replace the chain. Put the spring back exactly how it was. NOTICE the little finger in the bottom cover where the spring catches to snap it back. Put the bottom housing on. Holding the whole thing together, try the switch. If it doesn't recoil, pry it apart again, and adjust where the spring catches. This part will annoy some of you. Test again. If it pull ans recoils, you've got it. Put the nut on. Put electricians tape around the housing---don't cover any inputs. Re-insert your wires according to what you had. Put back together.
Mar 22, 2013 | Westinghouse Electric Westinghouse...
I need to know how to wire everything in the handle back together
Oster website should have all u need and i believe the diagram is able to be down loaded
Mar 15, 2013 | Oster Golden A5 2-Speed Universal Motor...
Dimplex DS3311 switch is overheating and melting. What to do?
How long does it take before the switch melts?
You could try retrofitting a switch from the hardware store that has a higher watt/amp rating...
Jan 16, 2013 | Dimplex Heating & Cooling
My turn single the push botton to turn it on broke how do i fix it
You can replace the two switches on either handlebar switch housing. Take the switch housing apart and unsolder the wires from the bad switches. Take the small screws out and replace the switches with new ones. Resolder the wires.
Good Luck
STeve
Feb 02, 2011 | 2000 Harley Davidson FXDWG Dyna Wide Glide
I took it apart and cant remember how to plug every wire connection in correctly need wiring diagram
"I took it apart" or "Did you take that apart"
Boy if I had a dollar for every time......well lets say I'd be typing this on a beach somewhere.
Ok I need to know a couple things. First...WHAT WERE YOU THINKING! ";-}
I know you've taken things apart before and promised yourself that next time you would draw a diagram or label everything. So what happened?
Ok I said the same thing and blew it off too so just forget it.
Can you tell me the make and model of the pump and if possible the switch.
What exactly did you disassemble? When I dismantle something it's dismantled so how much are we talking about.
I'm going to assume you are dealing with the switch for now unless you tell me different. I will also assume it's 110 because.... well... just because that's why. Your the one who forgot to label the stuff.
Most 110 pump switches have four connectors. Two referred to (and often labeled as), L1, L2. The other two are just M or M1 and M2 and sometimes T1, T2.
The L is for your line coming in from your power supply. M is for the motor.
There are some differences in switches but the most common set-up is for the motor wiring to be on the two inner connectors and the outer ones for the supply line in.
So basically both white wiring on one side and black on the other.
The link I provided is for the basic sheet you get with most new switches. It might help so take a look.
If you get me the info I requested (make and model), I will try and find a diagram but odds are long on that so you may have to do this one step at a time if you are talking about 220 volt or if you disconnected those wires in the motor house.
But I'll stick it out cause the only thing more fun then taking it apart is......ah who am I kidding there isn't anything better then taking it apart, but I'll stick with you and do me best to help.
By the way. For future reference nothing beats taking pictures. Even if it's with a phone camera. So give it a try. I mean next time.
Hope this helps and HAPPY (insert preference)!
And just respond back if it's more then the switch.
http://static.schneider-electric.us/docs/Machine%20Control/Condition%20Sensors/Pressure%20Switches,%20Water%20and%20Air/9013FHG/65013-005-50G.pdf
Dec 16, 2009 | Air Tools & Compressors
I need a wiring diagram for a milwaukee heav duty circular saw
It is probably something like a 6365 and on all the Milwaukee products they have a switch wiring diagram but nothing for the switch. I would recommend going to a local repair center with the switch and match it up with a new one probably less than 15.00 If you give me your location with zip code I can direct you to the closest one. Let me know
Apr 08, 2009 | Milwaukee 0730-22 V28 6-1/2" Circular Saw...
I am taking the old motor out of my Rainbow SE
Switch is not serviceable.
I think you are talking about old model switch (originally installed in your Rainbow) To remove 6 wires from the switch - push a pin where the wires go into the switch. It will release wires so you can pull them out. Make sure to draw a diagram how to connect them back.
If you need a new switch - go here
Nov 28, 2008 | Rainbow 75th Anniversary Canister Vacuum
Eureka boss vacuum, model 4331
it is posible you do not need the other wires have you replaced the original switch for the same or similar some of these switches have lights on could this explain the extra wires? also vacumcleaners sometimes have interferance surpresors they work fine without these but they interfear with tvs etc if not fitted mabe its missing?
Jul 19, 2008 | Kenmore Progressive Bagless Upright with...
Hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
Jul 18, 2008 | Hunter 20761 52'' The Stratford II Brushed...
Dimplex Compact Electric Flame Stove Heater Logo
329 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
