Question about T-Mobile MDA
Usb sync charger broken on 2nd mda in 6 mos.
I purchased a used MDA from my sister, that was in working order (it powered on), but the usb mini sync charger was loose inside unit. I had a tech look, he resoldered, now will not work. My sister purchase a new one in October 2006. Now same problem. T-Mobile says only warranty for 14 days. Have insurance, but all signs say manufacturer's defect. I have read numerous developer forums that show this as a problem for a couple of years for these types (same manufacturer) of units. In the USA. Thanks!
  • Anonymous Nov 18, 2007
    i had the same problem on two phones (mda) they work, but the usb sync charger broke. i will never buy that phone again!
  • Kimbobo Dec 02, 2007
    I have had the same problem. I have had the phone from new and treated it respectfully. I took the phone to phone a T Mobile shop for warranty assistance (the phone is less than a year old) T Mobile were not interested saying th fault must have occured through misuse. I am very disappointed and am considering changing providers
Http://www.xdarepairs.co.uk/home.asp Found this website and they're based in Wimbledon, UK ... should be able to fix any problem with MDA Vario's, but are a little pricey!
Posted on Apr 28, 2007
I'm dealing with the same problem overher in Holland. I'm looking for someone to "weld" the contacts. But you sould take a look at this website perhaps they can help you. http://www.pocketpctechs.com/main.asp?unit=Qtek_9100-513&area=repairs
Posted on Feb 09, 2007
Active Sync. on an MDA Vario 3
i had this problem, everytime i refreshed the mda the pc showed that the phone was connecting then once the mda vario had stopped the connection was lost, what i did notive was that the com port for active sync showed up on my pc as com port 4? which isnt a choice on the mda as there is only 2 ports available com 6 and com 7, what i did was to add new serail services to the pc until i was given com 6 as a choice,(because by default the pc starts off as com 4 then com 5 etc, so goto the bluetooth configuration then click on client apps and keep adding new service until you get com 6 then try and sync via activesync on your phone, if that doesnt work make sure that you have added new bluetooth device which gives you options of what services you would like the phone to use with the pc, click activesync then configure it to connect on com 6 voila that should work fine iv just updated mine to netframework 2.0 and can now run all the apps i want, any problems email me on iwannatoken@hotmail.co.uk il be happy to assist any way i can as i was stuck on this problem for ages and ages until i finally solved it hope you succeed.
Mark
Aug 31, 2008 | T-Mobile MDA
No power
Make sure you have an original OEM charger for the MDA. Many of the knock off chargers don't provide the right amperage for the device. What happens is that since the phone is completely dead, it can't regulate how many amps the battery should get during the charge and an incorrect charge current won't charge the battery. I'm guessing that someone sold you a Motorola RAZR charger or another knockoff made for the RAZR. This might charge your phone when the battery is working, but not when it's DEAD. Also you won't have luck plugging it into a computer USB cable because, again, the phone can't tell the computer what charge to send and most computers only produce <0.5 amps in the USB port.
Get a charger that states it is an OEM (original eqipment manufacturer) device or one that is specifically designed for the MDA (or Cingular 8125). eBay is full of them.
Bad charger (probably won't work for a dead battery)
Good Charger (correct amperage and designated for the MDA)
Jul 08, 2008 | T-Mobile MDA
I have an T-Mobile MDA. I haven't used it for over 6 months, went to charge it last night. plugged in the charger and the blue power light came on, went to menu screen. Left the MDA charging upon returning...
Your first bet is to remove the battery and hold down the power button for 10 seconds, then replace the battery and try to turn it on.
Sorry I'm not more familiar with the model of phone you're talking about but this has worked for my old PDA's when they won't power-cycle correctly.
Jun 27, 2008 | T-Mobile Computers & Internet
MDA 3 dead
If a device fails during a rom upgrade its as good as dead because it doesn't have enough instruction to start the process over.
Jan 17, 2008 | T-Mobile MDA
Broken USB Port on T-Mobile MDA
My daughter's MDA had the same problem. I just opened the phone and soldered the legs on the corners back to the board. You have to bend the pins on the back of the plug down to make contact with the board, before you solder. Place plug back down and line it up with contacts. If done right should work as normal. Hope that helps
Jan 16, 2008 | T-Mobile MDA
T mobile mda
If the unit is not new have you checked the status of the battery and is it a manufacturer's battery - some units are quite sensitive to that.
The problem may also be with the charger
Dec 22, 2007 | T-Mobile MDA
Battery won t charge or operate phone Problem - T-Mobile MDA Compact Smartphone
Okay, I searched and searched until I found a solution that worked for me. I tried the USB thing, I got my phone to turn on once, but never to charge. Here's what I did:
(Do this at your own risk)
I zapped my battery with a 9v battery. One wire on each terminal and then held it to the MDA battery (positive to positive, negative to negative) for about three seconds. I did this about five times. (Don't let the wires touch while they are connected to the 9v battery.) I IMMEDIATELY plugged my phone into a wall charger, NOT my computer (The computer wouldn't charge my phone). As soon as it was connected to the wall charger, I turned it on. After starting up, the orange light came on, and it started charging. I was skeptical about this solution at first, but trying everything else I resolved to do this and then if it didn't work buy a new battery, but it worked and my MDA is charging as I'm typing. The original ideal came from a post on the xda-developers website by dew1989. I added the additional steps that got my battery charging again. I hope this helps!
Dec 04, 2007 | T-Mobile MDA Compact Smartphone
MDA (T-mobile)
Make sure that your mda is being charged with an original charger
Sep 14, 2007 | T-Mobile MDA
T-mobile MDA on/off switch broken
plug in your charger to your phone, find something small to stick into the reseting hole, when your phone turns on, go into settings>power>advanced: un-click the "turn off device if not used for"
it may drain your battery faster, BUT it works!!! :D
Good Luck!
Apr 14, 2007 | T-Mobile MDA
T-Mobile MDA Logo
108 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
matt
matt
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
