Question about Dell Inspiron B130 Notebook
\windows\system32\config\system corrupt
I installed the bck up disk or reboot for dell xp but it is not being read
    Genius:
  • 1,913 Answers
Check ram refix again after lcean it.then check.
but may be u have repair your xp.
if u have xp setup boot disk.
then bott with your cd.
then gov to recovery console.
then type "chkdsk /r" at command prompt.
then it check the disk and recover bed sectors.
Posted on Nov 19, 2008
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Saying:/windows/system32/config/system is missing or corrupted n i dnt now how to fix it wut link exactly do i have to download to my usb to fix it n wut r the steps?
Assuming it is windows XP here are the steps to fix that error:
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:md tmp
My YouTube Channel
Click Here Live Tech Support
May 03, 2013 | ASUS Eee PC 2G Surf Notebook
I can use my Dell OptiPlex GX280 PC Desktop says that windows could not start because the following files is missing or corrupt: \windows\system32\config\system
You'll need a operating system disk or repair disk to run the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Mar 31, 2012 | Dell OptiPlex GX280 PC Desktop
Following files missing or corrupt: \windows\system32\config\system
Well this means one of important files needed to start Windows is corrupted (it's a registry file).
I'd recommend repairing Windows installation. If you have Windows XP and also the Original Windows CD follow: this guide.
Dec 31, 2011 | Dell OptiPlex 740 (BPCW6TT) PC Desktop
I have an hp mini 210-1041nr running win xp and when I start it, the computer tells me Windows\System32\Config\System missing. I tried service pack 3 but it didn't work. Can u please help?
You need to get a Windows XP from someone and follow these instructions:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD.
2. At the first R=Repair option, press the R key
3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4. Enter in the administrator password when requested
5. cd \windows\system32\config
6. Depending on which section was corrupted:
ren software software.bad or ren system system.bad
7. Depending on which section was corrupted
copy \windows\repair\system
copy \windows\repair\software
8. Take out the CD ROM and type exit
If that doesn't work or you can't get into the repair console then With the XP disk you choose to install Windows XP and when you choose to install over the current XP installation you will be given the option to repair the current Windows installation and you won't lose all of your data.
Mar 01, 2011 | Computers & Internet
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
I can't open windows xp i got this message:\r\n"unable to read file C:\windows\system32\config\software " I tried to fix it thru recovery console copying the i386 file but nothing happenned Help me please
hi You need to get a Windows XP from someone and follow these instructions: Windows could not start because the following files is missing or corrupt \WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD. 2. At the first R=Repair option, press the R key 3. Press the number that corresponds to the correct location for the installation of Windows you want to repair. Typically this will be #1 4. Enter in the administrator password when requested 5. cd \windows\system32\config 6. Depending on which section was corrupted: ren software software.bad or ren system system.bad 7. Depending on which section was corrupted copy \windows\repair\system copy \windows\repair\software 8. Take out the CD ROM and type exit
Aug 28, 2010 | Microsoft Windows XP Home Edition
My lap top will not turn on giving error message windowssystem32congfigsystem
Copy \windows\repair\system
Copy \windows\repair\software
And Thanks.
Mar 18, 2010 | Computers & Internet
When I turn on the 1525 Dell laptop...a screen comes up saying windows could not start because the following file is missing or corrupt.windowssystem32configsystem. The page then suggests attempt to repair...
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
Jan 10, 2010 | Dell Inspiron 1525 Notebook
Dell Inspiron B130 Notebook Logo
54 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
