Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
Analog power save
Title: analog power save
Body: When I turn my monitor on, a pop-up come up that say "analog power save" and shuts down.
  • 1 more comment
  • fido44 Nov 23, 2008
    monitor displays the following: analog power saving mode.
    can't fix the problem.
    help
  • Anonymous Jan 02, 2009
    Yes, what gives with this cheap piece of ****?
  • Anonymous Jan 04, 2009
    what is the snwer for this?
Same as above asking for a friend who does't know about commputers
my email is mssposs@bigpond.com
Posted on Nov 22, 2008
My computer turns on and all I get on the monitor
Can you use the monitor controls to adjust the Input selection, color settings and display settings. You may have the wrong input selected. Another possibility is the resolution output from your PC will not work on your monitor so it shuts down to protect itself from overdriving signals.
Oct 10, 2014 | Computers & Internet
Dropped keyboard. Now display on monitor says 1. Analog input in power save mode - press any key or move mouse to turn on. I have done both, neither works. I have turned off system and I see it rebooting...
the message Analog input in power save mode means that your monitor is not getting a signal from your computer.
Maybe you moved the video cable while reconnecting your keyboard? check both ends of your video cable.
If you have a DVI cable, then your monitor has to be switched to digial input.
I hope this helps.
Nov 10, 2017 | Dell UltraSharp 1708FP 17" LCD Flat Panel...
It's lg lcd w1943T that always shut down after 30 minutes and states power saving mode analog
check your video card and update the driver or pe install your video card. add cooling system. another is the motherboard capacitors
May 11, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Analog power saving mode
If its going to analog power saving mode, that is what its supposed to do when it does not get a recognizable connection from a computer vga port. I would suggest coming back on with some more information about your computer and suggest testing another screen on your pc.
Oct 31, 2009 | LG 22" FLATRON LCD Monitor
Monitor boots ok, then "Analog" appears/monitor shuts off
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Analog power saving mode?...
I have a LG flatron wide keeps saying Analog power saving mode and than powers off how do I reset this?
May 13, 2009 | LG 22" FLATRON LCD Monitor
New LG 2452T keeps going to digital power saving mode
i had the same problem.
connect the monitor with the analog cable and shut down your pc.
while it is off unplag the analog cable and place the digital one(dvi).
this should fix your problem m8 ;)
Feb 28, 2009 | LG Flatron L2320A 23" LCD Monitor
LG flatron analog power save problem
Sometime we can set the setting looking through manual. Have to do some reading.Try it from the manual instruction.
Apr 20, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
"analog power save mode"
different monitors have different settings. Anyhow, press the menu button on your monitor (hope it is there otherwise some other button must have been assigned this function). Choose recall or auto adjust or factory default from there (whichever of these options you can see). Nothing serious.....
Sep 09, 2007 | LG Flatron L1750S 17" LCD Monitor
Analog Power Saving Mode
Right click on your desktop>Properties, then click on Screen saver tab, then at botton of the box you should see 'Monitor Power'. Click on 'Power' then Power schemes tab. Look at 'Turn off monitor' and set to 'Never'
Nov 30, 2006 | LG Flatron L1951S-SN 19" LCD Flat Panel...
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
193 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
