Question about Air Tools & Compressors
Problem spray painting water based paint
I have been trying to spray paint using a water based paint, but I have been having the following problems;
1) The fluid flow has been "Pulsing" even when I put nothing but water in the gun.
2) When I spray it has this "pulsing" effect and sprays intermittently.
Occasionally the flow of fluid stops, but after a shake or fiddle it starts again.
I have cleaned the gun several times, checked for blockages and even tried using turps in the gun with the same effects as above.
The gun has a 1.5 nozzle and I have adjusted fluid flow, air flow and even the airpressure from 30psi through to 80 psi without any noticable effect. I have used the paint in virgin state and thinned it down by up to 20 percent. It does spray more paint at 80 psi than 30, but that is to be expected.
Am I doing something wrong or is there something wrong with my gun.
It is a standard gun, not gravity fed, and was given to me some time ago. I dont know any details othervthan its a wagner.
I spoke to a friend who was a spraypainter in his last job, apparently due to the thickness of the paint, I needed a larger nozzle on the gun. I couldnt get a nozzle to suit this gun so I purchased another gun with a cuple of different size nozzles. All seems to be working fine now.
Posted on Nov 20, 2008
Can I use spray paint in my back yard?
Sure, why not?. I've sprayed kitchen cabinets in my driveway, dining room chairs (metal, with auto paint) on my patio, wood paneling and more.
I would suggest using drop cloths or plastic to cover whatever you're not spraying, as spray will spread, especially if you use a water-based paint.
Dec 31, 2015 | Air Tools & Compressors
Used filler for filling nail heads rubbed back next day perfect two weeks later painted wattyl undercoat water base and filler went soft
The wood filler, a water based product, pulled the water out of the latex paint and softened. To preclude this in the future, you can cover these repairs with shellac or another sealant to provide a barrier between the filler and the paint. Spray shellac is available in hardware stores, and is used on water stained ceilings before repainting.
May 20, 2015 | Timbermate Wood Filler Water Based 8-oz...
Can I paint over this with a water based paint
Don't use a water-based paint for any purpose on a motor vehicle.
It can damage the finish of existing paint, and will NOT stick to the original paint. If this is just a stop-gap measure to cover some imperfection(s), and you don't care about perfection in the result, just purchase a can or two of spray touch-up paint and "have at 'er"!!!
Mar 24, 2015 | Cars & Trucks
Shoots drips
Most airless spray guns spit a bit when you pull or release the trigger because the paint between the spray tip and the paint valve is under pressure but not enough to atomise the paint. If you increase the pressure you may reduce the spit to a point when you don't notice it. A blocked filter could slow the paint getting through to the tip cause lower pressure.
Jan 03, 2014 | Wagner SprayTech Wagner Airless Paint...
Won't spray
There are a lot of variables while airbrushing. If you are having trouble with a new airbrush(or one that isn't hugely gunked up) you likely need to do 1 or both of the following to get it to spray the paint:
1) Thin your paint, use the correct medium based on the paint type. Water can be used to thin water-based paints but too much will result in a bad coat and finish. You are looking for a milk-slightly thicker than milker consistency.
2) Crank up the air through the airbrush. Assuming you have a regulator you may need to turn the pressure up to get thicker paints to spray. If you are using a siphon feed you may need a couple extra PSI to recoup for what you are losing from the syphon. Make sure to check the max pressure your airbrush can handle before cranking it too high(most can handle at least 30 PSI).
Hope this helps.
Jan 23, 2013 | Airbrush-Depot Master Airbrush Model G23...
I am an experienced spray painter, but I have been out of the game for a few years and things have changed in that time. I am familier with most types of paint, including synthetic, cellulose, 2 pack and...
water base paints are out there but as far i know i think you should error on the safe side and use a resporator with most all paints........ as far as i know they havent fully improved waterbase paints to the point that they hold up on metal correct me if i am wrong when the car companys use them for all cars then i will! ( base coat clear coat is the best so long as you follow the mixtures as directed on the cans ( call some paint suppliers , savage dupont ect they can guide you on most types of paints)
Feb 24, 2011 | Air Tools & Compressors
Spraying kitchen cabinet doors 40 degree weather airless graco sprayer enamel water base paint at first finish is great then bubbles start to form
first problem is the waterbase paints ( ****) the other is how did you mix your paint , you cam trap air in the paint if you padle or stired it without a shaker mixer air will gas out of the paint, tofix this use a foam brush to flaten air bubbles
Jan 23, 2011 | Air Tools & Compressors
What is the correct concistancy the paint needs to be mixed at for the dynatec psg 45 electric spray gun
It depends on 3 things.
What you are painting.
Whether you are applying latex, oil-base, or primer.
What size TIP you are using.
We use spray equipment and use size 17 and 19 for latex, and 11 for oil.
Double-check the size that came with your gun and look at tips at Home Depot.
Old tips wallow out and the spray pattern is irregular/uneven and the gun blows out too much paint and our material costs go up.
The manual says "dilute correspondingly"
http://www.airless.com.au/Airless%20Sprayer.pdf
Let's say you are spraying oil-base stain: I would NOT dillute this material.
Oil-base primer: 1 thinner to 4 paint
Latex primer: use a roller and brush so you have a good undercoat for the paint.
Oil-base paint: I would add 1/8 thinner with 1 paint, and be careful of runs
Latex stain: try 1 water to 4 stain
Cheap interior flat latex: 1 water to 4 paint
Latex semi-gloss interior: 1-1/8 to 4 paint and apply very thin coats and let dry between coats.
Cheap exterior flat latex: 1+ to 4 paint, and add more or less water as needed
Good exterior latex paint: use a roller and brush because the purpose of latex exterior pain is to apply heavy protective coat over outdoor materials ... dilluted exterior latex will not give sun and mildew protection.
We use heavy spray equipment and apply exterior latex straight form the can. It's the only way to give lasting job, unless you're doing a temporary playhouse.
The key to successful spraying is to strain your paint to get out the lump and clogs - BEFORE putting paint into the gun.
We always strain the paint unless it's a freshly opened can.
If can was opened yesterday, we strain it.
That because paint gets a dry film that will clog the sprayer.
First you need to mix your material, so you need a couple buckets.
Pour the paint and thinning material in 1 bucket, and then to mix, pour back and forth between two or three buckets. This action will mix the paint thoroughly and save you an hour of rotating a paint stir stick.
Next, you need to strain the paint.
Wash out a 5-gallon bucket.
Buy 5 gallon strainer that fits into bucket.
Pour material into bucket with strainer, lift strainer up and then grab end of strainer and squeeze out all the paint.
Immediately put lid over paint so no drying film will form.
Wash out strainer.
You're ready to put paint in spray gun.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on paint project.
Jan 06, 2011 | Garden
Porter cable spray painter PSH1 it says what you can spray with it and I want to spray water base paint can I do it with this painter it is new and I didn't relize it was onl for laciur paint thank you...
Be sure to filter the paint you are trying to use so that you aren't dealing with large lumps of paint. You will need to experiment with hose pressure to get proper spray quality, and set the mixture control for a fairly fine mist as the paint is likely to be more fluid. Fan control is set so that you don't get an unpainted space in the middle of the paint swath. Make sure to wash the gun thoroughly after painting. If you are doing a lot of painting, expect some nozzle wear over time as the water base paint is somewhat gritty. Don't forget to trigger 'off' before the end of each stroke and trigger 'on' after starting the return stroke to keep running at a minimum. Good luck!
Jun 19, 2010 | Porter Cable Cable PSH1 HVLP Gravity Feed...
IR 210g - using thicker paint
i dont have so much as a solution as a couple of things you can try to figure out whats going wrong.
make sure your compressor can handle 10.5 CFM @ 50psi
hook up the gun and dry spray it to check for blockages in the air supply
if the air comes through strong and constant, fill the paint hopper with water and spray until empty
if the water comes through constant, add half of the hopper with paint thinned with penetrol or floetrol
if the paint is coming out weak or spotty, make sure the vent cap is open on the paint hopper
if the cap on the hopper doesnt have a vent, try spraying with the cap off or cracked a bit.
if that doesnt work take off the hopper and check the filter for blockages.
i suggest straining all your paint before pouring it into the hopper
Nov 19, 2008 | Ingersoll Rand Hvlp Automotive Spray Gun
Air Tools & Compressors Logo
1,559 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
