If the new memory card is an SD card, you should be able to use up to 2GB. MMC can support up to 1GB. You can check this link.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=ModelTechSpecsTabAct&fcategoryid=145&modelid=14824#SupportDetailAct
I would suggest trying another card if that happens to be an SD card.
Hope this helps. Pls dont forget to accept the best solution. Thanks!
open up the cameras memory card door and clean the contacts with a electrical contact cleaner available at any auto parts store and spray couble of shots and let it dry. Seems the memory cards contact points get dirty after so much use and need to be cleaned. This would probably work on any kind of camera that uses memory cards and has the same problem.
This camera Supports Memory:
SD - Secure Digital standard card supports capacities up to 2 GB.
SD - HC Secure Digital High Capacity currently supports capacities up to 32 GB.
MMC - MultiMedia Card supports capacities up to 1 GB.
Just format the memory card in the camera.
Here is a link for more support...
http://www.usa.canon.com/consumer/contro...
Sir the solution is simple the file size limitation on that paticular model is 1gb. No matter what you do you will only be able to format and use a 1gb memory card. This should help!
Ok foramt your card with FAT32 file system.
then attch into camara
.check there is only one meory card as single card .
alsom pres power button for 10 seconds then remove all bsattery and mempory card.then fixagain.then try.
connect your memory card to computer witrh cardd reade then check it is working fine/?
then pls let meknow
check that your camera supports to 2 gb card.
your camera supports only compatibility with MMC, SD and SDHC memory cards
check your card type from this 3?
o.k. I put the memory card back in but it still reads memory card error.
The 16 mb card that came with the camera works fine.I had the card formatted on acomputer to make sure the camera wasnt formatting but it still wouldnt work
Larry
When I bought the card I had it put on the computer to format it and it was formatted and confirmed that it was indeed formated the same as the 16 mb card that came with the camera
yes this is a cannon powershot A550 we formatted from the camera when this didnt wor we used the computer and formatted and checked it is indeed formated but the camera wont read it
Thank you very much
You are very professional and prompt
Larry
