Question about HP Pavilion a305w (DM181AR) PC Desktop
Machine won't recognize CD-ROM after harddrive format
The machine was low-level formatted, and I need to have it boot up with a Microsoft XP install CD. However it won't recognize the CD-ROM at all. I switched drives with another functional machine, and eliminated the drive as the problem. I then switched the ribbon cable with another functional machine and eliminated the ribbon cable as the problem. I've checked the Startup Utility, at its configured as having a CD-ROM installed. Yet I can't seem to get it to work. Every time it boots up, it seems to ignore the drive and only look to the floppy for the operating system, and displays the basic "put floppy in drive and press F1" pictoral diagram. Any ideas why the machine won't see the CD-ROM drive and how to get this problem resolved? Thankx in advance! Basically the same problem. Had no problems before format. I used a 2nd program that ran from cd rom to " euthanize " the hard drive and after installing xp pro FROM CD....... xp wouldn't recognize its existence. Please Help!!!
    Sergeant:
    Champion:
  • 226 Answers
When booting up select whichever key gets you into the Bios. Normally either F2 or delete. Once in the Bios, find the boot up sequence and by the instructions that will be there to change the sequence change it to Floppy Drive, then CD Rom, then your hard drive with Windows on it. Press F10 to save and reboot.
Posted on Nov 19, 2008
My operating system was damaged by virus,i need ro reformat my computer..how can i reformat my competer?
Install the XP discs and restart the machine. It should boot from the discs. Then follow the onscreen instructions. You will want to reformat your main drive. (C:)
Apr 04, 2011 | Microsoft Windows XP Home Edition Service...
Can not install xp , it says disk boot failure, insert system disk and press enter
If you are trying to intall Windows XP and you get that message it means that the MBR section in your disk is physical damagaged, you can not perform any installation, your HDD is dead, get a new one. But before that you can try to do a low level format :
1- Get "Hiren's Boot CD" from the internet
links for HBCD
torrent : http://www.btscene.com/details/2247719/Hiren+s+Boot+CD+12+Full.html
Uploading : http://uploading.com/files/ab2c6mda/Hirens...12.0.part2.rar/
http://uploading.com/files/42a119e7/Hirens...12.0.part1.rar/
2- It's an ISO file, burn it on a CD.
3- Reboot your machine using that CD.
4- Navigating over the menu of Hiren's Boot CD and go to Disks Problem and formatting, (some thing like that).
5- Perform a low level format.
6- The operation will take many times, about 4 to 8 hours.
7- After the operation complete try to install XP.
8- If it does'nt work then get a new HDD.
Nov 20, 2010 | MSI PM8M-V Motherboard
How to remove this copy of windows did not pass genuine windows validation
First enter into BIOS setup by pressing key recognized by your machine oftenits DEL key. AT the boot sequencegive first booting option to CD Rom and second to the hard disk, save settingand exit. Boot system with Windows CD, apply option for fresh copy. AND if youhave already been done and failed. Boot computer with Windows 98 CD. Apply bootcomputer with CD Rom support. At the DOS prompt FORMAT DRIVE C. Restart yourcomputer and boot with windows XP CD.
Sep 24, 2010 | Microsoft Windows XP Professional With...
I need to reformat a dead harddrive
Hi there !!
Method 1: Perform a clean install of Windows XP loadTOCNode(2, 'resolution'); A clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base: 313348 (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk in Windows XP To perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
If you have successfully installed Windows XP, you are finished. If these steps did not help you install Windows XP, go to the "Next Steps" section.
Here's the link that contains the screen shots as well:
http://www.buildeasypc.com/sw/windows_xp.htm
Try these steps & hopefully you will be able to format the Harddrive.
Regard's
Anurag Shukla
Sep 03, 2009 | Microsoft Windows XP Professional With...
Swaping hdd
You have half a dozen reasons why this will not work. The Operating system (XP) does not recognise the different hardware, the Bios doesn't recognise the MBR (the file structure of the harddrive) and you have all the wrong hardware drivers installed.
There is a way to do this if you have the original XP installation disk, install the harddrive, put the XP installation disk in the CD/DVD drive and set the machine to boot from the CD/DVD first. When the machine boots up and goes to install XP follow the instructions as if you are doing a fresh install, when SetUp attempts to format the harddrive it will discover you already have a version of XP installed and will give you the option to repair it, go ahead with the repair and MAYBE SetUp will be able to see and install the correct hardware drivers. If not you are looking at Slaving the harddrive, saving your personal files and then formatting the harddrive and reinstalling XP fresh.
Oct 31, 2008 | Dell OptiPlex GX110 PC Desktop
Compaq presario v5000
Boot into Setup and run the TOOLS / PRIMARY HDD TEST / SHORT TEST.
If it fails, try another HDD.
If OK, verify Boot Order is Floppy, CD-ROM, HDD. Exit Setup.
Print Table 1 Low Level Format instructions from http://support.microsoft.com/kb/106419
Boot with a DOS disk that contains Debug. Run the Table 1 script. Turn V5000 Off.
Boot with the HP Operating System CD. XP install should now proceed normally.
Good luck.
Sep 12, 2008 | Compaq Presario V5005us Notebook
Installing operating system
You are getting this error because you have formatted the harddrive and now your computer cannot find your old copy of Windows.
To install the new copy you have to put the Windows disk in the CD or DVD drawer and restart the computer, when the compter starts (before the no operating system window) you should have options to Enter SetUp. You need to press the appropriate "F" key to enter set up or boot order and tell the machine to boot from the CD.
As it is now your machine is trying to start from the harddrive and its not finding anything, you need it to start from the cd drive so that it can install windows.
Aug 07, 2008 | Microsoft Windows XP Professional for PC
How to format laptop: step by step please!
1. configure cmos bios... first boot cd rom drive...
2. insert your xp starup/intallation disk to the cd rom drive
3. then follow the instruction appear on the monitor....
after the formating/installation of window xp.. it is the time for conversion..its need a application software..
Apr 04, 2008 | Microsoft Windows XP Home Edition
Replacing VISTA with XP Pro on Toshiba Qosmio F45-AV 413
Skokerdog51:
It came with the SATA drive, Go into BIOS settings, hard drive settings from whatever existing (I am slipping the exact name from my mind now). Make sure you save the settings, go into Bootable options and make sure your cd rom is the first to boot, put the cd in, restart your machine and thats it............make a clean install of xp. By the way I am also not a big fan of vista.
Enjoy!
Dec 25, 2007 | Acer Aspire 3680 Laptop
You have to change it in the bios, press F2 or DEL on startup depending on your bios type. The bios screen then will have second line of advanced bios settings, in here you need to select the cdrom as the first boot device, by using the up down arrows or pageup/down or '+or-' keys. Press ESC when cdrom selected and save settings when propmted. The system will re boot so ensure the cd is in the drive and press enter when prompted to start with cdrom.
Jan 29, 2007 | IBM NetVista A40 PC Desktop
HP Pavilion a305w (DM181AR) PC Desktop Logo
125 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
