Question about Canon PowerShot A70 Digital Camera
Camera will not take picture, givingme err msg and shutting off
I noticed that my camera will not take a picture. It turns on, I aim and lightly press the shutter button allowing the camera to focus. The led lights next to view window let me know it has focused and I press the shutter fully but no image captured, no flash and an err msg shows then the camera turns itself off. Every other function works (video) batteries are fully charged. What can I do?
I just found out that it's a known CCD problem with some Canon models. And you can get it fixed for free: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Posted on Apr 08, 2007
SOURCE:
Got the shutter and mirror clicks and err msg
bring it to your nearest nikon shop for a check up. i suggest a mirror lock up / shutter error.
Jul 26, 2009 | Nikon D90 Digital Camera with 18-105mm...
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My fuji finpix s1 will not pull up the menu, nor can I take any pictures however the automatic focus works, the function lcd lights up but it will not work either.
rdp19 did not mention the ERR msg.
I had the same problem, however after messing with it the ERR message is up.
If RDP19 gets this, did you get it fixed.  Where and what cost?
Jan 26, 2009 | Fuji FinePix S1 Pro Digital Camera
Err 99
Hi Ben ,
To isolate the cause of the issue, we suggest that you do the following:
4. Insert a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
camera should be serviced.
Let me know if this worked, if not then the camera is dead and it would require some service or a replacement
Thanks
Proton
Aug 07, 2008 | Cameras
Canon Rebel EOS camera
Err 99 is a general error msg. That is, it has to be connected to the service soft that only Canon self or an ASF has, to know more precisely the problem.
To narrow the possibilities;
-choose Av, shutter priority,
-choose the smallest aperture your lens allows, 22 or 29 or so,
-while pressing and releasing the depth-of-field preview button, (front, under the lens release) look into the lens from the front.
If the diaphragm doesn't move it has to be changed. If you have the 17-55 standard lens; throw it away and buy a better one instead of paying a repair. You'd be better off.
If you have the Err msg with several different lenses the problem is in the body itself, often the shutter. Check also your PINs in the CF-slot. If one PIN is toching another; break off the bent one and normally you can go on, the PINs are almost all doubled.
Jul 27, 2008 | Canon Digital Rebel / EOS-300D Digital...
Fuji s2pro (2 units)
Your shutter mechanism reached its life expectancy, (5000 shots).
Aug 23, 2007 | Fuji FinePix S2 Pro Digital Camera
My Canon is displaying - Err 99 what should I do?
Just found this info which should help diagnose the err 99 issues (info direct from Canon apparently)
Apr 10, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Msg on the back of the cam
You can try to reset and format the camera by following the steps from the Knowledgebase article http://ask.americas.creative.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=ww_english,Company={CEAE216D-8719-4C00-AC9F-03BC258F7B70},VARSET=ws:http://us.creative.com,case=2544
Sep 12, 2005 | Creative Labs PC-Cam 600 Digital Camera
Canon PowerShot A70 Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
