Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a
link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the
blade package to make sure you actually have an 80" blade.
After I posted this problem al72512 where do I log into to get my solution?
To danny; craftsman band saw 12" model # 113 243310
It will be right hee on this page once someone can answer it.
Really need to know the brand name and Model number
