Question about Sharp EL-2196BL Calculator
How do I avoid using the decimal when typing a number with no 0s
All of our other adding machines have a + symbol in the decimal control so that when I am typing 56.23 for example, I don't have to hit the decimal key. This machine doesn't have that + symbol, how can I fix this?
  • 3 Answers
If I am not mistaken you are trying to set your decimal in dollars and cents correct? Well, if I am understanding your question correctly; you move tab that has F 6 3 2 1 0 set that to the 2 and then there is a tab that says "K * A make sure that is set to the A as well. Hope that helps.
Posted on Dec 16, 2008
My excel worksheet - for a whole number you have to enter 1. or 9. or 10. How can I avoid the . and still get a whole number
Use Edit, Column or row, and format cell. then select type of number, integer or number of decimal places etc.
Nov 03, 2016 | The Computers & Internet
I have a TI-83 plus calculator. I put into the calculator 96-5.970 ^2 multiplied by 0.2723 and it gave me the answer 2.4507 ^E- 4 Is there anyway to get the answer to the decimal value instead of it...
2.4507E-4 is scientific notation for 2.4507 times ten to the minus 4, or .00024507.
Take the 2.4507 and move the decimal point, to the left if the exponent is negative, to the right if it is positive, the specified number of positions.
If the magnitude of the result is too small or too large, the calculator will automatically switch to scientific notation. Imagine a number that has more than 12 digits to the left of the decimal point. How is that going to fit onto the display? Or a number that is 0 followed by the decimal point followed by 12 0s and then some significant digits?
Jun 21, 2011 | Texas Instruments TI-83 Plus Calculator
How do i enter 46degrees 15minutes into my ti-36x calculator?
Enter DMS (Degrees/Minutes/Seconds) values as D.MMSSs, using 0s as necessary:
  • D degrees (0-7 digits)
  • . decimal-point separator
  • MM minutes (must be 2 digits)
  • SS seconds (must be 2 digits)
  • s fractional part of a second
For example, enter
  • 46° 15' as 46.15.
  • 179° 9' 2.54" as 179.090254, note the 0s in front of the 9 and 2.
Before using a DMS value in a calculation, you must convert it to decimal with [2nd] [>DD].
Jan 13, 2011 | Texas Instruments TI-36 X Solar Calculator
How to convert a fraction into a decimal
First put the calculator in degree mode.
To convert from fraction to a decimal number first enter your fraction or, mixed number. I'll convert a mixed number to a fraction first since, I don't have a key for the symbol that shows that a number is a fraction on my keyboard. Example: [3][A b/c][1][A b/c][2][A b/cd/e][ENTER]
3/2 should be entered at the home screen. While at the Home screen enter, [2nd][FD][ENTER]
1.5 should now be displayed at the Home screen.
As you can see it is really just using the [A b/c] key to enter in your fraction and, [FD] key to do the converting. The [A_b/cd/e] key isn't necessary because, mixed numbers will convert to decimal numbers just like fractions do. I just don't have the key to show a fraction symbol that the calculator uses. So to show that symbol, I used the / symbol with the fraction number.
Dec 29, 2010 | Texas Instruments TI-30 XIIS Calculator
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
Nov 27, 2010 | Casio FX-300MS Calculator
How do I get dashes inserted into my long phone numbers?
Well it should do it by itself,but if not then when your typing in the number ,switch to symbol mode by using the star key..then you can add your dashes
Jun 01, 2010 | Motorola Mobility RAZR V3
Need help on scientific notation using a texas instrumants ti-83
still have problem's mail me at
Nov 11, 2009 | Texas Instruments TI-83 Plus Calculator
Convert 4 2/9 to a decimal
Step 1: Find a number you can multiply by the bottom of the fraction to make it 10, or 100, or 1000, or any 1 followed by 0s. Step 2: Multiply both top and bottom by that number. Step 3. Then write down just the top number, putting the decimal place in the correct spot (one space from the right for every zero in the bottom number) Example 1: Express 3/4 as a Decimal Step 1: We can mulitply 4 by 25 to become 100
Step 2: Multiply top and bottom by 25:
×25 left-up-over-arrow.gif 3 = 75
4 100 left-under-over-arrow.gif ×25 Step 3: Write down 75 with the decimal place 2 spaces from the right (because 100 has 2 zeros);
Answer = 0.75
Example 2: Express 3/16 as a Decimal Step 1: We have to mulitply 16 by 625 to become 10,000
Step 2: Multiply top and bottom by 625:
×625 left-up-over-arrow.gif 3 = 1,875
16 10,000 left-under-over-arrow.gif ×625 Step 3: Write down 1875 with the decimal place 4 spaces from the right (because 10,000 has 4 zeros);
Answer = 0.1875
Example 2: Express 1/3 as a Decimal Step 1: There is no way to multiply 3 to become 10 or 100 or any power of 10, but we can calculate an approximate decimal by choosing to multiply by, say, 333
Step 2: Multiply top and bottom by 333:
×333 left-up-over-arrow.gif 1 = 333
3 999 left-under-over-arrow.gif ×333 Step 3: Now, 999 is nearly 1,000, so let us write down 333 with the decimal place 3 spaces from the right (because 1,000 has 3 zeros):
Answer = 0.333 (accurate to only 3 decimal places !
Sep 22, 2009 | Black & Decker Juicers
Can't change the decimal symbol on my Kensington 33006PocketKeyPa
You can customize this setting in the Regional and Language Options in the Control Panel for Windows,
Dec 26, 2008 | Kensington Pocket KeyPad (33006) Keyboard
Cannot get backslash (\) character to display
To get a backslash, you need to print the upper ascii character 92 (decimal). On most machines you can get upper ascii characters by holding down the Alt key and typing the decimal value on the numeric keypad. On the little IBM machine I'm typing this on, there is no numeric keypad, but if I switch on numlock (by doing shift-scroll-lock) the j-k-l keys become 1-2-3 etc. Now id I hold down Alt and type 92 (i.e.keys 9-k), this is what I get: \ Howzzat?.
Mar 16, 2008 | IBM ThinkPad 600X Notebook
Sharp EL-2196BL Calculator Logo
477 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
