Question about Medion MD 7317 17" Flat Panel LCD Monitor
Medion md 7319
Hi
we are with video and audio repair center ca we have two medion
lcd montor with exit same issue , blue light blink , we took apart inverter ok if i unplug main lcd control cabel lcd will lit and if i put cabel back blue start blink i thin may be bad y-x or main pcb any idea
  • Anonymous Nov 21, 2008
    My monitor, same model has been doing this for last six months. I bought a new monitor but hopefully can find a solution before I have repaired which was quoted as more than a new monitor. I'm still researching
  • 736 Answers
Look for capacitors with the tops bulging .. these are high failure rate chinese made capacitors .. they made zillions of them and they fail frequently .. replace any that have buldging tops (should be flat with over pressure vent lines impressed)
Posted on Jul 22, 2009
6 * 470uF 25v capacitors + 1 * 220uF 25v on inverter board, all with bulging tops. Replace them all (note 105 degC variety) and monitor works OK!
Posted on Sep 02, 2009
    Genius:
  • 2,120 Answers
It's probably just a burned out backlight fluorescent bulb.
Posted on Dec 26, 2008
Using medion md 96340 with built-in realtek hd audio sound card. in skype video calls the caller can hear very well but called person does not hear at all. skype echo test says-cannot find sound...
Analysis- The call can gear very well - indicates that the speakers / head phones are working fine and the audio drivers are working well
The called person doesnt hear any thing - it indicates that the caller is not able to transmit sound. This can be a microphone related issue. It can also be skype settings issue.
Please answer following questions to analyze the issue better
1. has this ever worked before?
2. Have you tried using the microphone for some other application like recording some audio?
3. Have you tried audio / video calls using some other chat program like gtalk?
4. Are u using any external microphone attached to a head set or is it the laptops inbuilt microphone?
-IAmAraldite
Aug 18, 2011 | Medion MD 96340 Laptop
AUDIO LEADS
There should be one audio cable, Green.
goes into one of the green plugs behind the computer.
Oct 31, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Hi, I have the Medion LCD-TV model MD 30058 40inch. I cant get a clear picture anymore, there are popping up lines, like there are bad signals. Sometimes the screen goes totally black, and I have to turn...
Medion LCD-TV model MD 30058 40inch is a "troublemaker", the problem you descibe Trond Larsen can probably be solve by replacing a capacitor on the CPU board, costing only NOK10,-
Are you placed in Norway?
Oct 16, 2010 | Medion MD 30262 32 in. LCD TV
Blue light goes to Orange blinking no sound no picture Screen on
Hi!
Okay, if the screen is white! First, take apart and check the ribbon like cable that goes from your signal board (where you inputs are plugged in) to the lcd controller (under a small metal plate feed the lcd screen), see if loose and or reset! Secondly you either have a bad signal board or lcd controller!
Feb 28, 2009 | Westinghouse LTV-30W2 Television
Need Audio and Video driver for Medion md-1768
Not sure on the Video but uninstall the soundmax and use realtek AC-97 driver available at
http://drivers.softpedia.com/get/SOUND-CARD/REALTEK/Realtek-AC97-Audio-Codec-Driver-A397.shtml
Oct 17, 2008 | Medion MD-1768 PC Desktop
Medion PC model MD 1777 wabout 4 yrs old will not start/boot up. Blue light just flickers continusly and makes a tapping sound.
Remove any disk inserted n your computer (floppy or cd) and try again.
Check the cables connection and monitor connection.
If no boot, try boot your PC using the CD restore provided with your machine
Oct 12, 2008 | Medion MD-1704 PC Desktop
Medion MD 7317 flashes colors after computer shutdown
That's what it's supposed to do. This is the monitor test to let you know that the monitor is working but it's not receiving a video signal.
Jun 15, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
My screen has horizontal lines across it
its the ram
mine does the same took ram out replace
Nov 24, 2007 | Medion MD 7317 17" Flat Panel LCD Monitor
Medion MD7317 17 inch Flat Panel Monitor
My MD7317 did the same thing until I actually installed the driver for it. My windows did not have the correct driver in it's driver base, so I found the driver online ( took a few minutes of searching) and within a few minutes of installation the monitor displayed a great colorful picture. Naturally, I had to use another monitor while I was searching. Driver is about 3.3 megs. It came in a zip format. I did not keep track of the link to driver, but it omly took a few minutes to locate it.
Jun 12, 2007 | Medion MD 7317 17" Flat Panel LCD Monitor
Medion MD 7317 17" Flat Panel LCD Monitor Logo
663 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
