Question about Kenmore 22642 Top Load Washer
Kenmore top load washer 92573210
Tub balance spring, where does it attach?
  • 240 Answers
4 springs on bottom of washer 3 from tub to top of base hidden, 1 from rear tub to bottom of base straight down, hole in inner lip of base, to counter weight of motor.
Posted on Apr 26, 2009
Fix balance ring
if you have a regular top load direct drive washer and if the tub is tilted off balance remove the frame of the washer,look at the back bottom of the frame,there's a spring that is connected to the bottom of the frame and hooks the the back of the tub,sometimes the frame rusts out and the spring rips through the drill hole in the frame,you have to drill a new hole in the frame and reconnect the spring.i've never seen a balance ring this is the first thing i would check if washer is off balance.
Jul 03, 2014 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Heavy Duty 60 series Washer. The agitator is out of balance, so I took it apart to find the counterweight spring was not attached to anything. Where does it attach too, it is already...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
You should be able to see where the springs attach by looking at the base diagram.
Following also is the Whirlpool / Kenmore PDF on how the transmissions work but it also has a good diagram of where the springs attach.$FILE/L-55.pdf
I don't believe that the counterweight spring attaches to the brake.
Dec 20, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Oasis washer model 110.27032600; trapped hidden water
when you tipped the washer was the drain hose still attached? and if so was the drain hose elevated? most top load washers will have an amount of leftover water in the bottom of the tub. with the drain hose off and the washer tipped towards the rear you should lose any excess water. also try to open the top of the agitator to see if there is any water trapped there. hope this helps....
Oct 18, 2009 | Kenmore Washing Machines
Kenmore 70 Series top load washer makes noise during spin cycle
There are three springs under your machine. two that look the on each side of the tub. and one in the back of the tub. it is common on machines that are a bit older for the rear spring to wear itself through the metal at the bottom. if this is the case, it is best to get a new spring and just drill another small hole next to the old one. you might be able to get by with using the old spring for a bit longer....just drill another hole.
Dec 27, 2008 | Kenmore 23822 Top Load Washer
Kenmore mdl 10022622100 goes out of balance
to cause unit to go off balance taking in fact that you put clothes in washer even...check your counter balance spring it hold the tub to base at rear of unit,,,and check your balance ring at the top of your wash basket its fill with water if cracked will cause this problem,,
Dec 24, 2008 | Kenmore 22422 Top Load Washer
Kenmore Series 80 wobbles when spinning
the basket is attached to a triangular brace that must match up with the frame it sits on.
Dec 19, 2008 | Kenmore 24032\24036 Top Load Washer
My washer leaks occasionally from the back
ok i need a lilttle help from you,,,ok,,,open lid..take your hand and put it on the top of the agitator,,push the hole agitator and tub back,,and let it go if the tub stays back and does not come back center by its self,,your counter balance spring broke,,no mattter which way you push that agitator it shoud come back to near center..what could be bad counter balance springs ,,or tub surport springs.if you need help removing and changing please post
Dec 03, 2008 | Kenmore 15864/15862 Top Load Washer
Unstable tub
There are springs inside the unit that stablize the tub during spin. If the springs are not attached correctly the tub will be off balance. Sometimes the Balance Ring loses it's fluid due to a crack or leak and the washer will spin off balance. THis requires a service tech to dissemble the machine.
Nov 27, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer
There are a few things that can cause this issue.
1. The counter balance spring broke or the mounting hole for the spring rusted through.
2. One or more snubber pads may have come off.
3. The balance ring may have come loose from the basket or the ring has been damaged and the fluid has leaked out..
Start by removing the shell as follows:
A.) The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw.
B.) With console lifted you will find a lid switch connector (white in color). Unplug the switch from the connector.
C.) There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
D.) Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
1.) The counter balance spring is located in the bottom rear. It should be attached between the cabinet and a bracket on the tub.
2.) Inspect snubber and corner pads. May be brown or white in color.
3. Remove tub ring by pushing down then lifting each locking tab.
Inspect balance ring for proper fit and any cracks. By moving/shaking ring you should hear liquid sloshing around.
If you need further assistance, let me know
The FixYa Team.....
Jun 26, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 22642 Top Load Washer Logo
265 people viewed this question
Sal De
 Brian Main
Brian Main
