Question about Nokia 3230
3230 joystick problem
Hey all. The joystick on my 3230 does not go to the right.Up down and left function perfectly.But the right doesnt . Pl help. Could this be a software problem. I have already formatted the phone but no use
  • Anonymous May 09, 2008
    diagram of the joystic
Hey the problem with your cell is not software but hardware.try cleaning your joystick or replacing it.....
Posted on Aug 12, 2007
Trow ur cellphone in d river! den cry! dats d best solution!
Posted on Jul 26, 2007
My Nokia 3230 joystick is not working properly. It selects the first option even if i try to move it up, down, right or left. Please tell me the solution. Thanks in advance.
your problem may cause a damage joystick or the top board of your may be damage or loosing connection try to dismantel it properly then remove and put back again all the connection of the top board.
Jul 30, 2011 | Nokia 3230
Etrex legend joystick problems
could be the hardware switch itself
Oct 05, 2017 | Garmin eTrex Legend GPS Receiver
Z525a screen comes on but stays vacant.
If you have access to a laptop computer that has an Infrared Port or Bluetooth communications, you can download your videos and picture files via either of these two methods. I use an old IBM Thinkpad 600 with IR port to download mine. You have to put your z525 phone into Infrared mode first, its kind of tricky with out seeing what you are doing. First, open your phone, press upper right (-) sign to get menu, click joystick control down 2 times then right 1 time. next press upper left (-) sign to select. next joystick right 4 times, and down 1 time. press upper left (-) sign, then joystick up 1 time. press upper left (-) 1 time. Your Infrared Port will now be turned on, and your I.R. enabled laptop can now receive the files from your phone. Close your phone, open it again, press upper right (-) , press joystick down 1 time, then left 1 time, then press the joystick center select button 2 times. Joystick right 1 time, press joystick select 1 time. press upper right (-) 1 time, joystick down 5 times, joystick right 1 time, joystick down 3 times, joystick center select 1 time. Hold the lower left corner of your phone toward the I.R. port of the laptop, it will receive the first photo file in your camera pictures file. Another possible method would be to obtain a usb connector cable for the z525 phone to connect it to your computer. Using the usb cable the computer would recognize the phone, you could click on the phone icon, under "MyComputer" and transfer the files to your hard drive. I hope this helps. -Mike
Mar 09, 2009 | Sony Ericsson Z525a Cellular Phone
My sony ericsson k750i joystick is broken.
Your joystick might have accumulated a lot of dust inside it. Try to clean it with alcohol or blow it off with some high high pressure air.
Jan 30, 2009 | Sony Ericsson K750i Cellular Phone
Camera not functioning
try opening your AGENT V game application and then hang it on by pressing the joystick to the left as fast as you can 'til the loading timer hangs.
exit from the said application and then check your cam if it is working. if not, repeat the process...be patient...
Nov 12, 2008 | Nokia 3230
3230 joystick
piles sir i am request my mobile 3230 joystick up down no waking piles help emijate
Jun 02, 2008 | Nokia 3230
Right Joystick. . .
I had this same problem with my 360 controller (after modding it, but the solution should be the same..) If you pull up on any 360 joystick it will stick the same way.
The quickest fix would be to take some sandpaper on the inside of where the joystick touches the controller shell, sand it down just enough so the joystick is moving smoothly.
More professional ways would be to cut the little piece of metal that sticks out and goes into the joystick. Just a very small amount, too much will make it hard to press the right thumbstick button.
You could also try some old fashioned grease, just a little bit on the inside, nothing noticeable from the outside.
Also make sure the controller is put back together right, I've taken apart many 360 controllers and sometimes joysticks stick when there's a wire in the wrong place and the shell won't close all the way. (The rumble motors particularly).
Hope this helped!
Sep 16, 2007 | Microsoft Xbox 360 Controller
Nokia 3230 Logo
207 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
