Need internal diagram of coponents for philips tv 55pw938317f
Try to fi the convergence for my tv but would like a diagram of what everything else isso i could put it back the way it is supposed to be. i have lost my owners manual so i contacted philips for a new one and there was no diagram for the internal componets please help.
  • 373 Answers
SOURCE: e350 frod van
On your Ford E 350.
Are 3 Engine sizes available. 5.0L, 5.8L and 7.5L.
On Gasoline.
The Firing Order for 5.0L and 7.5L are the same.
But diferent on 5.8L.
Here is a Picture if the firing order and cylinder number.
e911241.jpg tHIS IS THE FIRST FIRING ORDER FOR 5.8L.
The CIRCLE mark is for the cylinder # 1 on the distributor cap.
e0ba3c1.jpg This is for the 5.0L and 7.5L
The Circle mark is for the cylinder # 1 on the distributor cap.
The ROTOR turn Clock wise.
I hope this help on your problem.
Thank you for use fixya......
Posted on Aug 26, 2008
SOURCE: sansui vcr 6010 owners manual
can u sure this vcr to hook up suriellances cameras
Posted on Oct 02, 2008
Ecollier2012
  • 3459 Answers
SOURCE: hitachi projection tv
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Posted on Jan 29, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Convergence on a Philips 51pw9303 rear projection TV
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Using your original remote go-to the tv settings then goto the convergence section.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
SOURCE: Need free owner's manual for a Detrola record player Model KM837
You have probably done this, but I had same problem on one I was given with no manual. I couldn't get the turn table to turn and by accident I move the arm to the right, away from record and it began turning. Hope that helps.
Posted on Apr 22, 2009
I have a big magnavox tv that all of a sudden the picture went out with only sound. I tried everything possible from changing cables and calling my cable company to see if the problem was there but no
Your flyback has failed most likely...bad new is they are nearly impossible to find, This is a known issue on most of the models below. The site Tv Repair Kits can sometimes get replacements - but its not often.
This repair kit is known to work on Magnavox TV sets with the following Chassis/Model Numbers.
DPTV305 , DPTV305F , DPTV310 , DPTV315 , DPTV330 , DPTV330F , DPTV335 , DPTV340 , DPTV345, MAG01
Model Numbers
( 43PP9202/17 43PP920217 43PP9202/17F 43PP9202/84 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920201 50PP920217 50PP920284 50PP920284F 50PP920217F 51MP392H/17 51MP3964H/17 51PP9303H/17 51PP9363H17 51PW9303/17F 51PW936317F 55PP9352/17 50PP920217F 51MP392H17 51MP3964H17 51PP9303H17 51PP9363H17 51PW930317F 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F 60PW938317F 43PP9202/17 43PP9202/17F 43PP9202/84 43PP920217 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920217F 51PP9303H/17 51PP9363H17 51PW9303/17F 50PP920201 50PP920217 50PP920284 50PP920284F 51PP9303H17 51PW930317F 51PW936317F 55PP9352/17 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F )
Mar 29, 2012 | Philips Televison & Video
HAVE DOUBLE PICTURE
Double picture can happen for two reasons. Is it double on TV/Cable or double on all inputs. If it is the TV, try a different input. If it is double on everything you tv is defective and/or broken.
Jan 22, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips proejector 55pw938317F is turning on and
Bad STK ICs replace Both of them i 110s up grade to 180s they are big black ics will have part number on them STK392-110 call mats 1-800-628-1118.
Sep 21, 2009 | Philips Magnavox 55P9271 55" Rear...
Philips TV model 60PP9202/17F veins circuit board destroyed
Email the team at www.TvRepairKits.com - they may have a photo or service manual for that model.
Jun 14, 2009 | Philips 55PP9401 55" Rear Projection...
Red curves on bottom and top of picture
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 18, 2009 | Philips 43PP9202 43" Rear Projection...
Red & green shadows
Replace the two STK392-120 Convergence Ics you can get replacements at the following link with step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jan 15, 2009 | Philips 60P8341 60" Rear Projection...
Philips tv
Sounds like your convergence chips are shorted which would make the set shut down. Its also possible that the flyback has failed but because the first symptom was the 3d look I would start with the convergence repair.
Screen looks 3D
No audio or video - typicaly occurs after having the distorted color problems listed above.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Ed
Sep 29, 2008 | Philips 46PP9302 46" Rear Projection...
Philips Convergence for 55PP8620/79
Yes the box marked sanyo is the focus and screen control box. All stk Convergence ICs for rear projection TVs are made by Sanyo, which was the origional producer of the STK series Convergence IC. You need the convergence repair kit for the DPTV series rear projection which consist of two STK392-120 ICs and 11 6.8 ohm 1watt metal film resistors. You can get the repair kit for your model at the following link , they do ship to Austrailia however they do have an international shipping charge which must be purchased for orders outside the north American continent,. They also probide free installations instructions with pictures and free tech support. Heres the link.
Sep 15, 2008 | Televison & Video
Philips Rear Projection Model 55PP8620 - convergence problem
Manufactures sometimes contract with other tv companies to build their tv. Regardless of the internal hardware you still have a philips tv. I beleive this set was made by Hitachi. And what you are looking for is a replacement board. This board is referred to as the small signal module. When contacting a rebuilt board, have the model# and the chassis# available. And contact PTSELECTRONICS.com or Andrews Electronics.com. The board you seek is in the rear lefthand side on the floor of the TV. You will see a pair of tall aluminum fins. Theses are the heatsinks for the convergence ICs. I would definitely replace this small signal module, as repair on the local level will require pulling the board in and out of the tv several times. The company will give a part number and then you may order this. Striving for success the first time!!!!
Sep 13, 2008 | Philips (867093110009) Projector Lamp for...
Philips 46-inch Rear Projection with bowed image?? slight distortion
Screen looks 3D
Solution:
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
