Question about Minolta Opteka .5x Hi-Def Wide Angle Lens for DiMage S414 S404 S304
My minolta won't take picture, shuts off giving me err msg
Everything seems to work with the camera. It turns on, I aim as I press the button to take picture the camera automatically focuses. The two led indicators let me know it is done focusing and as I press the shutter button to take picture, nothing happens. No flash, no picture captured. The camera gives me an err msg on top and then it shuts itself off. The batteries are fully charged, What do I need to do ?? Please help. Thank you.
  • L Carol Feb 16, 2009
    Exactly the same and I have fresh batteries. please advise.
  • ultrafox Mar 02, 2009
    My Seems to 'Err' esp when the flash is needed.....I've never seen the flash work since this problem has occurred. I've tried newbatteries incl. ReCyko batteries that are suppoed to retain their charge for longer.
    I can take some pics without the flash.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Check voltage and amperage on batts or try another set
Posted on Feb 27, 2007
SOURCE:
Shutter-release button doesn't work
The manual only can give two reasons why the camera would not take pictures.
One, there is no memory card placed.
Two, the memory card is full.
You are sure you have placed a working empty memory card.
If you did save all the pictures on the memory card to a computer, try formatting the card in the camera.
When you are pressing the shutter release button half, does the camera say it is focused correct? light bottom corner of the display.
Your camera has a setting to take pictures with a remote control. Did you put the camera in that setting? Read page 76 of the manual.
success
Jan 16, 2014 | Konica Minolta DiMAGE A200 Digital Camera
I push the button but it wont take a picture
Did you try it like it is said in the manual? press the button half till the camera is focused and then press the button completely down?
Don't expect the camera to shoot with the same speed as a camera with film did. Give it some time to focus and everything will be fine (I hope)
If not let me know.
Jan 02, 2014 | Sanyo vpc-s1415 - Vpc-s1415 14.0...
My camera says Err 30 turn off and on and re-install battery. this doesn't seem to work....any advice?
Remove the battery, press and hold the power button, or turn the power switch to ON position(depends on the option available in your Camera) for more than 30 Seconds and then reinsert the battery to resolve the issue.
Sep 07, 2012 | Canon EOS 1100D / Rebel T3 Digital Camera
Minolta Dimage S414 does not turn on, displays err message then shuts off? No error code, just err. Been in storage four years, probably stuck lens or something?
Go to this website and try the fixes listed....one of them may "kickstart" your camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 29, 2011 | Konica Minolta DiMAGE S414 Digital Camera
Go to take a photo everything shuts down. and a err message comes up help.
Contact a Minolta representative. They're calling back the cameras with those symptoms and will exchange it for free until Dec. 31, 2010.
Aug 24, 2010 | Konica Minolta Dynax 5D / Maxxum 5D Body...
Got the shutter and mirror clicks and err msg
bring it to your nearest nikon shop for a check up. i suggest a mirror lock up / shutter error.
Jul 26, 2009 | Nikon D90 Digital Camera with 18-105mm...
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My Canon is displaying - Err 99 what should I do?
Just found this info which should help diagnose the err 99 issues (info direct from Canon apparently)
Apr 10, 2007 | Canon EOS Elan 7ne 35mm SLR Camera
Camera will not take picture, givingme err msg and shutting off
I just found out that it's a known CCD problem with some Canon models. And you can get it fixed for free: http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Dec 14, 2006 | Canon PowerShot A70 Digital Camera
Optics Logo
115 people viewed this question
Top Minolta Optics Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
JonSnell Electronic
JonSnell Electronic
Are you a Minolta Optic Expert? Answer questions, earn points and help others
