I purchased a 32 inch Sony TV. When going through hdmi cable for hi def, I hear a pop thru the speakers when changing channels from a hi def channel to a non hi def channel or the other way around, but I do get a picture. I do not get it when I go from hi def to hi def channel or non hi def to non hi def channel. I switched to component cables and every thing works fine.I tried different cables and switched cable boxes,also different outlet.Any suggetions?
SOURCE: akai lct42z6tm
I can confirm that replacing these 4 capacitors worked perfectly. I work in construction so i am not a technician or anything. I did not even have a solder iron. I have photos of the board if anyone would like to see them. Took me about a hour to replace the 4. I had to use (2)35volt & (2)50volt cause radio shack only had 2 of each and it works like a charm. This TV has been in storage for 6 months until i found this article on the problem. Cant say thanks enough!!!!!!!!!!
Posted on Jul 14, 2008
ahhsoo69
  • 167 Answers
SOURCE: blue ghost on left side of screen only when on hi def channels
hello its sound like you need to replace the (IC chip) for your blue (CTR gun) .!!! its going bad.!!!hope this help's you ."good luck"
Posted on Aug 20, 2008
SOURCE: turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
Posted on Sep 03, 2008
  • 57 Answers
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
Posted on May 31, 2009
SOURCE: Input 6 - HD Input - Green Screen. Audio Only. No picture.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
Posted on Sep 26, 2009
Trying to set up my new elements tv with a uverse wireless box. Did a channel scan but still can't find any channels. Help please!!
Is this a high def tv? Are you using an hdmi cable, component cable(red green & blue) or a low def coax cable to connect the tv? If coax, the tv needs to be on channel 3 or 4. If hdmi or component cable is used you need to change your input on the tv with your remote to the matching input you wired it to. The uverse stb (set top box) changes the actual channels once you have selected the correct input.
Jun 26, 2014 | Televison & Video
I just purchased a new RCA 32 inch w/ DVD. When starting up it asks if you will use Cable or Air. I have Dish Satellite and picked air. I only get one channel and if I try to go up or down channels I get a...
You should not have had to choose cable or air. When you have satellite it is considered the same thing as cable. Air is over the air rabbit ears antenna free programming. When you are connecting a satellite receiver you only have to turn to channel 3 or pick the correct av, component or hdmi input. Oh you must be connecting more than one television to the same satellite receiver. When that is the case tv #2 usually has to be set on a different channel and the satellite tv company tells you which channel. You still use the satellite remote to change channels and leave this television on one channel at all times. This television is good enough for its own hd satellite receiver connected with component cables or an hdmi cable though in order for you to see its full potential for displaying hd programs.
Jan 07, 2011 | RCA L32HD31 32 in. LCD HDTV
Picture blacks, tv needs to be turned to bring picture back. wii games do not go black
This is caused by your QAM decoder on hi def Sharp sets. You need to rescan for channels, turn off your TV then turn it back on to set to save the channels.The problem lies in the Tuner board and some Hi-Def signals can change frequency slightly due to improperly shielded cables etc. Verify that all of your cables, especially the Cable TV wire are firmly seated on your set. An improperly grounded cable television wire can wreak all kinds of havoc on reception.
Oct 29, 2010 | Sharp Aquos LC32D41U 32 in. LCD TV
I cant get any picture on my sony tv when i connect my ps3 upto it, yet get a picture instantly on a cheap 26 inch hd tv. i'm using a hdmi cable on both
Silly question -- but are you sure your Sony TV is on the correct HDMI channel? My 32 inch LCD has HDMI1, HDMI2, HDMI3. You must make sure you plug the PS3 into the correct HDMI channel and make sure you're tuned into the same one.
Aug 03, 2010 | Sony Playstation 3 (PS3) Console
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Feb 01, 2010 | Vizio VF551XVT 55 in. HDTV
Speaker distortion on SHARP 37" Aquos Hi Def
When you are changing channels you are using the tuner of the sat reeiver. the tv does not know you are changing a channel . It is just receiving a constant signal from the SAT receiver. I would suspect a problem with the receiver. Try another one first .
Apr 24, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Split screen
Yes I get the same problem with my Sony XBR and its Pace PVR.
The problem seems related to using HDMI interconnects; viewing the PVR through component leads allows the TV to switch modes easily, otherwise I have to turn the tv off and then back on again.
Nov 14, 2008 | Panasonic PT-52LCX66 Projection Television
Color screen
If you are hooked up with a DVI cable you need to either use hdmi, component cables or turn off the non hd override...
Jun 15, 2008 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Popping sound from speaker when changing channels
This noise is normal with the cable box unless you set the cable box on HDMI sound
Dec 26, 2007 | Bose 3 2 1 GSX System
Olevia LCD 32 inch
You can hook up direct but you will not get hi def channels, only the standard or digital depending on your hook up.
Oct 12, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
