Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Beeping before booting
I have a MacBook. When I turn it on the monitor turns gray and it starts beeping loudly and it does not boot up but it continues beeping. It starts with two beeps and continues with three beeps every 2-3 seconds. There seems to be a CD stuck in it as well.
  • Anonymous Nov 24, 2008
    Same problem here - and I'm really annoyed. I had a deadline - grrrrr!
    Novelist:
  • 137 Answers
Probably the RAM. Take it out and put it back in to check. You will need some RAM to boot, so try each stick separately if you can. I'm guessing though that you'll have to get at least one other stick of RAM to check. You'll probably find that one is bad. It's probably covered for life, but that would be a good reason to upgrade it.
Posted on Nov 19, 2008
Gray screen on macbook pro
does it chime?
could be ok if it chimes.
could be bad ram, bad hdd, spill damage, liquid damage, might need new logic board. Places on ebay offer repairs for flat rate for about 250 bucks.
Feb 12, 2014 | Apple MacBook Pro Notebook
Macbook stuck on load up screen
When you say "load up screen", I assume you mean the Apple boot screen (it has the apple on a gray background).
You might try resetting the PRAM on the macbook.
You can do this by pressing and holding the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
So, turn the macbook completely off. Turn it on and immediately press and hold the Command-Option-P-R keys until the computer reboots and chimes. Once it chimes, release the keys. Your system should boot normally.
Jan 19, 2014 | Apple MacBook Pro Laptop Computer with...
HP xw4600 Workstation Beeps loud immediately when turned on, then does nothing for about 10 seconds and then the cpu fan runs very loud and there is nothing on the monitor. Will not boot at all.
Seems your MOBO is bad.When MOBO are damage the symptoms you describe is the cuase your PC dont boot.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 07, 2011 | HP Computers & Internet
My apple macbook won't start and continuously keeps on giving a beep sound.
the beep pre-boot is signaling a kernel panic. It could be bad ram or something else, it's hard to tell without hearing the beep (they signify different things)
1 beep = no RAM installed
2 beeps = incompatible RAM types
3 beeps = no good banks
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
taken from http://www.welovemacs.com/whdoallthbme.html
So depending on the beep, it means different things. However in any case I'd suggest taking it to an Apple Authorized Repair Facility. Unless you feel comfortable with assessing the proper solution on your own
Good Luck.
Feb 17, 2011 | Apple MacBook 13"White /2.0Ghz Intel Core2...
It won't turn on
try booting in safe mode (hold shift key while booting)
Jun 08, 2010 | Apple MacBook Mac Notebook
When booting up my laptop it has a gray screen with the apple for a minute and then it turns to a circle with a slash through it
Boot from the CD/DVD that came with your Macbook. Launch 'Disk Utility' and perform 'Repair Disk' as well as 'Repair Disk Permissions' on your boot drive and hopefully that will fix the issue.
If that doesn't do it, try holding the Option key during startup to select the boot disk and select your Mac HD. If it boots in this manner there are rumors about some bad SuperDrives out there causing this boot issue. So you may want to boot it while holding "D" and run the Apple Hardware Test from the DVD/CD.
Mar 19, 2010 | Apple MacBook Pro Laptop Computer with...
Won't boot up
If you hear NO beep code when system starts to boot , it is dead ( one beep then after a few seconds it will beep again before you see windows start up screen )
Jul 20, 2008 | Intel D945GTP Motherboard
My computer crashed and now the monitor goes into power save mode
You said that you hear a series of beeps, if you hear this kind of sounds maybe there is a loose connection from the CPU. Try to remove the Memory and put it back again.
Mon =)
Nov 15, 2007 | IBM IntelliStation M Pro 6219 PC Desktop
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
789 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
