Question about Kodak EASYSHARE 5100 All-In-One Printer
Uninstalling .net 2.0 software
Hello again etuckram,
This might be a repeat of my previous message:
I tried going through windows/add remove programs and it says this cannot be removed? Not having much experience with this software until I tried to make AiO software for my 5100 work. I am unsure about how to proceed. I have included an image showing all .net software I have installed. Can I remove 2.0 despite what windows says and does that interfere with 1.0 and 1.1 already installed?
Regards James
  • 34 Answers
It could make your other software stop running but you will reinstall it right away so you have nothing to worry about.
willing to help,
etuckram
Posted on Nov 20, 2008
C:/Progam Files/blocktards/unins000.dat what is this error and how do i fix it
Hello crouch8323,
Welcome to FixYa.Com!
Unins000.dat is a files that if used by Blocktards' uninstaller to properly uninstall Blocktards off of your Desktop. If your are trying to uninstall Blocktards and you are getting an error message, I recommend that you uninstall Blocktards from the Control Panel's Add & Remove Program (for Windows XP) or Programs & Features (for VISTA or 7). If you still have the same error message, you can also try uninstalling Blocktards by going to the Start Menu, All Programs, Blocktards, and click Uninstall. If these steps give you the same error message, you may need to use Blocktards installer to uninstall the game, see if running the installer gives you the option to modify, remove or repair. And if all else fails you can always use a 3rd party uninstaller software like the option found in CCleaner.
Regards,
Deathschythe33
Aug 22, 2011 | Computers & Internet
I've tried to install the game D_DAY (montecristo) on my notebook but the message displayed is: "Application Installed successfully. Rebootthe computer to complete the installation" but if i...
Hello
This could be a corrupt install,try uninstalling through add remove programs,then reinstall.
You may want to try running the game as administrator or in compatibility mode.
Thanks for using fix ya
Feb 10, 2011 | Monte Cristo D-Day for Windows
Can not install Net Framewoek 3.0 because of
Sir,
Run the cleanup tool to clean out temporary files, run the .NET
Framework cleanup tool, Run the installation file, then reboot and try to install it again and see if it works. If not try the below following steps....
Step One:
1. Go to Add or Remove Programs, try to remove all .NET Framework.
2. Please download and install the Windows Installer Cleanup utility
from this link:
http://download.microsoft.com/downlo...BD/msicuu2.exe
3. Then, please run it from Start-> All Programs-> Windows Install
Clean Up.
4. Please remove all Microsoft .NET Framework shown there and click
Remove.
Step Two:
1. Click Start->Run, type INSTALLER and click OK.
2. In the open folder, click View menu and select Details.
3. Right-click the Date Modified column header.
4. Click Comments
5. In the Comments column, locate the cached Windows Installer file
that displays Microsoft .NET Framework 1.1 (English) RTL x86 enu.
6. Right-click the cached Windows Installer file and then click
Uninstall.
7. Close the window.
8. Delete the cached Windows Installer file.
Step Three:
1. Restart your computer.
2. While your computer is booting up, press F8 to invoke the startup
menu.
3. In the startup menu, choose Safe Mode.
4. Log on as an administrator.
Note: In Safe Mode, your system display and Desktop will look and
perform differently than in Normal Mode. This is only temporary.
5. Delete the folder C:\WINDOWS\Microsoft.NET
6. Delete the folder C:\WINDOWS\system32\URTTemp
7. In the C:\Windows\System32 folder, locate the file mscoree.dll.
Right click and rename it to mscoree.old
Step Four:
1. Click Start->Run, type REGEDIT and click OK.
2. Navigate to the following registry key by expanding the "+" beside
the registry tree in the left pane:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework
3. Delete this key in the left pane.
4. Repeat steps 2-3 to delete the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup
5. Restart your computer to Normal Mode
Step Five:
1. Please download the Microsoft .NET Framework Version 1.1
Redistributable Package from the following link and save it to C:
http://www.microsoft.com/downloads/d...DisplayLang=en
2. Click Start->Run, type "c:\dotnetfx.exe /C" (without quotation marks
and there is a space in this command) in the open box and click OK.
3. Click Run, and type "C:\.NET Framework 1.1" (without quotation
marks) in the open box click OK
Note: If you are prompted to create this folder, please click Yes to
continue.
4. Locate the folder C:\.NET Framework 1.1 and double click the file
netfx.msi in it to install .NET Framework components.
If .NET Framework 1.1 can be successfully installed, we can go on to
install .NET Framework 1.1 Service Pack 1:
Microsoft .NET Framework 1.1 Service Pack 1
Step Six:
If the above two can be installed correctly, please download KB886903
from the following link and install again:
http://www.microsoft.com/downloads/d...displaylang=en
If the problem still exists, please describe the error message when
installing Microsoft .Net Framework Service Pack in further detail
Thanks
Good luck
Nov 07, 2009 | Microsoft Computers & Internet
Uninsalling Where in the world is Carmen Sandiego
Try uninstalling through some uninstalling softwares like Zsoft Uninstaller or ccleaner.
you can use ccleaner to delete the entry from add/remove programs, then delete the folder from the Program Files, to remove the registry entries use ccleaner to to clean the registry too.so that you can install this software later without any issues.
Jun 09, 2009 | The Learning Company Where in the World is...
Connecting the One Touch 8920 scanner to my Windows XP
Hello.
These problems seems to have a different solution every time and with differents addon devices.
However you might want to try this...
1. Restart the computer in safe mode and uninstall the scanner software from the control panel (add/remove programs or sofware)
2. Shut the computer down.
3. Unplug the scanner from the computer
3. Restart the computer
4 Install the software from the CD.
5. plug in the scanner to the computer and let windows detect the scanner.
6. (optional) restart again.
Good Luck.
Feb 10, 2009 | Visioneer OneTouch 8920 Flatbed Scanner
Getting message stating add-on was running when problem occurred
Try going into your control panel & uninstall your Internet explorer, then re-install it. IE7 uninstall can be found in the main add-remove program window, IE6 uninstall can be found under the add-remove windows components part of the add-remove programs. To re-install IE7, though, you need to go to windows update to download IE7 again. This won't be a problem because uninstalling IE7 automaticaly returns you to IE6
Jan 08, 2009 | Microsoft Internet Explorer 7
Uninstalling .Net 2.0
I suggest you to verify if you have administrator rights on your computer (Control Panel > User accounts and check if your name says Administrator)
You could try to reinstall the .NET framework 2.0 by going to microsoft website (on serch, look for .NET framework download and it will take you there), and see what happens.
If it is still not working, you should contact Microsoft because this would be an issue with Windows itself.
Nov 19, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
When trying to open adobe reader 8.1.1 get following message: patch package could not be opened. verify that the patch package exists and that you can access it, or contact the application vendor to verify...
it sounds like the application that is needed to uninstall the version 8 is corrupted or missing. Try reinstalling version 8 first then uninstall it before loading version 9. If you can reinstall version 8 and it asks you if you want to repair or install, choose install to get all of the files back before uninstalling it again. Always uninstall from add/remove programs. If deleting it from program files instead of uninstalling it correctly it will cause problems.
Oct 22, 2008 | Computers & Internet
Kodak EASYSHARE 5100 All-In-One Printer Logo
32 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
