Question about Sharp R-1750 Microwave Oven
Sharp R-1750 shuts down.
The screen has had the usual display issues for some time. My wife and I simply memorized the button positions from the manual, and have been using it thusly for years now. Last week a new problem developed. After starting the microwave, it would run a few seconds and suddenly shut the entire machine down, as in total power failure. Unplugging will reset everything, but it now shuts down the instant you hit the start button. Is there any chance the usual board failure could be the cause of this as well? We really like this machine...
  • Sharp Master
  • 9,098 Answers
The shutdown you're experiencing is separate from the control unit / display issue.
The shutdown is probably due to a a loose fuse holder, loose wiring, or a problem on the inverter board or the magnetron.
If the control unit doesn't receive the proper signals form the inverter, it will shut down the cooking process, but you say it acts like it's being unplugged - that makes me suspect a loose fuse or wiring.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person attempt to take readings on these inverters.
We actually have the service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it in case you don't have it already.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
If you get the shutdown problem repaired, we'd be happy to repair your display problem for you.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 24, 2008
How do i fix my clock from military time to regular time
Hi Tinay
I found this on page 10 of the manual:
"MY SETTINGS
Your new microwave oven can be customized to suit your
personal preferences. Simply press the My Settings
button to configure the following options
No. 3 - Clock display control 1=12HR 2=24HR"
Link to manual page 10 --> Samsung SMH1713 User Manual Turning On The Power For The First
Trust this helps, regards Alan
Mar 04, 2015 | Samsung SMH1713B 1.7 cu. ft....
How do I reset the clock
On most machines there is a tiny button somewhere near the digital display.thus usually has to be held in for 5 to 10 seconds to get the clock digits to flash.then using a dial or up down keys you change the hour then press which ever button you first pressed to get minutes then set that then press the first button again to return to normal display.you may need to experiment to find what button to hold in first to get the clock to flash.
Jan 03, 2015 | Microwave Ovens
Time
follow the next steps use the VOM and fix it. God bless you
  1. Main control boardIf your microwave runs for a few seconds and stops, the first thing to check is the main control board to ensure that a shortage has not occurred. If the part is defective then it will need to be replaced to prevent continual shut offs. If this is not the issue, the next step would be to check for a faulty touchpad.
  2. Touchpad/Control panelIf the control board is not the issue and your microwave continues to shut off after running for only a few seconds, the next thing to check is your touchpad, which is also known as a control panel. Although uncommon for this issue, symptoms are usually that the display and some buttons are working properly; however, when selected some buttons are not functioning. If this is the case the touchpad will need to be replaced.
Jun 18, 2013 | Panasonic NN-S254BF Microwave Oven
Hi, i own a kenmore elite speedcook oven model 363.63692301, ever since my wife used the convection speedcook oven and had the heat setting set to the maximum temp of 450 degrees which the oven should...
I have had issues with my Kenmore Elite conv oven too. I have had several service calls and found out that the TCU (thermal cooling unit) sensor was not working. This allows the oven to cool down so it doesnt overheat the sensors in the display. I actually had to have the oven replaced after 4 months of use. I am currently waiting for a technician to review the replacement oven for the same issue. I spent $7k on all new Elite appliances and will never purchase Kenmore appliances again. Good luck
Nov 30, 2010 | Kenmore Microwave Ovens
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
What does error message F5 mean?
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing..
I'm not finding the one for for this model online.
If it's a convection model, F5 would be a damper door sensing error, which is usually a bad switch.
More info on switches is here.
One of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
If it's not a convection model, F5 is probably a sensor error.
On some models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
Here's some info from Samsung, which is the actual manufacturer of these ovens:
"Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
"Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
"If the message is either ERROR or E-6, it indicates a mechanical fault.
"For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
Feel free to contact me directly if you need more help.
Aug 22, 2010 | Frigidaire GLMV168K Microwave Oven
Sensor error
I had the same exact thing happen...I put in some popcorn, it wouldn't pop. The screen said "sensor error". I tried heating water, a piece of chicken...nothing would heat. I unplugged it, plugged it back in...nothing. The manual says to close the door and hit the clear/cancel button. I could have sworn I had done that, but my wife simply hit the clear button and it started working again good as new. Hope yours does the same. : ))
Jun 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Microwave won't work; timer word stuck on screen
The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Our site is linked here on Fixya: http://tinyurl.com/yzjozk
Oct 25, 2007 | GE JVM1340AW/BW/WW Microwave Oven
Can't use the microwave
To lock or unlock the keypad, press and hold the CLEAR pad for 5 seconds. If this recurs, you may have a power line problem or trouble with your controller. If you suspect trouble and it's under warranty, don't hesitate to contatc GE via ge.com. If you don't have your mower's manual, you can download one at: http://www.geappliances.com/service_and_support/literature/
Nov 07, 2006 | GE Advantium 120 Convection/Microwave Oven
Sharp R-1750 Microwave Oven Logo
83 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
