Question about Brother ML-300 Typewriter
Brother typewriter 340 in need of help
My typewriter makes noise and beeping when turned on cartridge to left
Called the Company direct and found a solution..
thanks..
Posted on Nov 20, 2008
I have a brother AX-25 and when it is turned on it will make a fast clicking noise and then just beep no matter what until it is turned off. What is wrong with it and what do I do?
Turn off the typewriter, open the top-cover and inspect the area around the carrier for any damage or foreign objects.
2. Move the carrier towards the center of the machine.
a. When moving the carrier manually, it should be difficult to move, but it will move under steady pressure.
b. If the carrier moves freely, the drive mechanism may not be connected properly.
3. Remove the ribbon and inspect the cartridge for damage. Turn the colored knob on the left side of the cartridge to remove any slack from the ribbon.
4. Check the correction tape to insure that it has not become tangled ordamaged.
5. Close the top-cover and restore power to the machine.
If the problem persists, your machine may require service.
Jan 23, 2014 | Office Equipment & Supplies
Brothers ax
a. When moving the carrier manually, it should be difficult to move, butit will move under steady pressure.
b. If the carrier moves freely, the drive mechanism may not be connectedproperly.
Dec 12, 2013 | Brother EM-430 Typewriter
Keyboard want work
If your machine is not printing properly:
1.Examine the ribbon cartridge to make sure it has not run out of Ribbon. If your ribbon appears silver or gray, install a new cartridge.
2. Ensure the black lever in the center of the carriage is pressed to the rear, towards the paper. If not press it to the rear to lock the Daisy Wheel into place.
3. With the typewriter turned off, press and hold down the "CODE" Key, the "SHIFT" Key, and the "TAB" Key.
4.Restore power with all three Keys depressed.
5.When the machine sounds a beep tone, release all three keys.
6.The carrier will move to the left indicating that the memory has been cleared and the machine has been reset.
7.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com/service/default.aspx
May 08, 2013 | Brother EM-530 Typewriter
Carrier stays to the left
Look inside the machine and make sure nothing has fallen into it that may be blocking the carriage from reaching it's "home" position. Sometimes a lift off spool will fall off and do that.
Apr 16, 2009 | Brother GX-6750 Typewriter
Pitch Beeping
make sure the printwheel is locked in place, and the cover is closed. otherwise it is probably the main board or power supply. take to a repair shop for evaluation
Aug 14, 2008 | Brother EM-530 Typewriter
Beeping noise
Please check inside the machine to ensure that all packing material has been removed..cheers, John
Oct 20, 2007 | Brother ML-300 Typewriter
New Cartridge Will Not Drop
Make sure the print hammer is pushed forward as far as possible so that it is latched
Aug 27, 2007 | Brother ML-300 Typewriter
Brother ML-300 Typewriter Logo
97 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
