Question about Toshiba 43H71 43" Rear Projection Television
I have this same problem, but it doesn't come back on.... sigh
I have tried to power it off... back on, wait... wait... but it does not come back on. The flashing light, the sounds... it all appears to be the same case. If you have resolved this, please let me know how... Thank you... and Merry Christmas.
Toshiba told me to unplug 24 hrs to reset
Posted on Jan 05, 2007
Keep trying to sigh in asking for email when i type it in and hit allow the allow arrow doesn"t go away won't let me sign in
Restart your computer. If that doesn't do it, Google the main program name and search for how to fix errors. You may need to reinstall the mail program (back up your e-mails first!). Good luck
Jan 14, 2018 | The Computers & Internet
I have a HP C8180 that will not power on. It tries but just doesn't happen.
Assuming there is power in the power cord, pull the power cord out of the back of the c8180, wait one minute, put the cord back in, press the power button on the front of the c8180.
Apr 13, 2013 | HP Photosmart C8180 All-in-one -...
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
Recently bought an older Craftsman portable table saw (221740) and cannot change the angle of the blade. Yes, yes, the blade tilting lock lever is loosened as much as possible. Surely, one doesn't have...
Spray Some PB Blaster on the mechanism that moves the blade bed back and forth.. In fact spray it on any part that looks like it turns or slides back and forth. The stuff is amazing.. 10 times better than other name brand loosening sprays.. I bet an over night soak with that will most likely loosen it up.. if not.. reapply and wait another day if you can.. If not grab a propane torch and heat the spiral rod that should turn where the rod runs through the "holder" for lack of using a more complicated name. The spiral rod runs through that like a screw.. Heating up that area will more than likely free it.. You could try that a couple hours after your first spray if you have a torch.. good luck
Jul 20, 2017 | Saws
Green light blinking very fadley pc will not turn on
Sounds like you might have a partial power supply failure. Try unplugging the power supply from everything. Ther should be a switch on the back that is red and says something like 115/220 just flip that switch over to 220 and wait 5 minutes then switch it back to 115 and replug everything in and then try it. If it doesn't work then unplug everything again and let it sit for about 30 minutes (this resets the power supply) and reconnect the wires and if that doesn't work try getting a new power supply. In partial PCB (Power Supply Board) failures the problem is that trere isn't enough power going to the system to start up so sometimes resetting the PCB will fix it temporary. You should get a new one anyway. that one will fail completely soon. Good luck!
Mar 15, 2012 | Dell Computers & Internet
Samsung le40
Have you checked all the inputs to the television? It might be blinking because it doesn't see a signal. If all the inputs are secure try pressing the input select button on the remote. If that doesn't work it never hurts to try unplugging the power cord, waiting a minute, and plugging it back in.
Dec 18, 2011 | Samsung Televison & Video
Doesn't print the whole page
Try to re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Oct 21, 2011 | Lexmark All-in-One Printer with PictBridge
Compaq Evo
hey,, Try re-seating the processor
this will ivolve removing the heat sink and fan, removing the processor then putting it back in..
You will then need to clear the cmos, to do this there is a jumper on your board named jcmos or jp1 or batt.. this is a 3 pin jumper, its currently set to 1 and 2, set it to 2 and 3 , wait 10 secnonds then set it back to 1 and 2
Verify the the power selector on the power supply is set to the correct voltage 220 or 110..
Jul 22, 2008 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Camera
HI
You have a Faulty Camera or bad cable connection
Feb 16, 2008 | Samsung SGH-U600
Toshiba 43H71 43" Rear Projection Television Logo
49 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
