My Fujitsu Siemens Pa 1510 laptop is constantly freezing randomly, with white/blue/black vertical lines.I have taken it to repairers who replaced inverter cables to no avail. How can I fix this problem once and for..Is there any programme I can download and run that can give me a guaranteed solution
  • Darren Kessinger
    Darren Kessinger May 11, 2010
    When you say freezing do you mean as in the whole system freezes?
    or just the video (external monitor could answer this question)
    What Operating System are you running?
    But my first thought would be to immediately check the processor fan for dust build up on the heats ink since a pretty common issue with allot of laptops is that a small layer of dust builds up on the heatsink sort of like a thin blanket that prevents the air from cooling the heatsink like it is supposed to and that of course causes the cpu to overheat at first and one of the first signs of overheating is the whole thing freezing up.. And at first it may just happen when doing something extensive that requires allot of cpu power but after a while as the dust layer gets a little thicker it will happen more frequently and could result in a dead cpu after a while. (I have seen this situation countless times)
    Only problem is that if there is not an access door (removable piece of plastic) on the bottom that allows direct access to cpu fan and heatsink then you will probably have to take apart the laptop somewhat to be able to see if that is the problem (if you do not feel comfortable taking apart the laptop then I would suggest mentioning it to them the next time you take it in) since there is really no way to shine a flash light into the vents and see the dust because the layer of dust builds up on the other side of the fan and is usually impossible to see through the vent.
    NOTE: if you’re going to be attempting to do the repair yourself try to make note or which screws you remove from where since some of them are different lengths for a reason And be extra careful of ribbon wire connections when separating panels and so on
    Novelist:
    Scholar:
  • 85 Answers
My first thought would be to immediately check the processor fan for dust build up on the heats ink since a pretty common issue with allot of laptops is that a small layer of dust builds up on the heatsink sort of like a thin blanket that prevents the air from cooling the heatsink like it is supposed to and that of course causes the cpu to overheat at first and one of the first signs of overheating is the whole thing freezing up.. And at first it may just happen when doing something extensive that requires allot of cpu power but after a while as the dust layer gets a little thicker it will happen more frequently and could result in a dead cpu after a while. (I have seen this situation countless times)
only problem is that if there is not an access door (removable piece of plastic) on the bottom that allows direct access to cpu fan and heatsink then you will probably have to take apart the laptop somewhat to be able to see if that is the problem (if you do not feel comfortable taking apart the laptop then I would suggest mentioning it to them the next time you take it in) since there is really no way to shine a flash light into the vents and see the dust because the layer of dust builds up on the other side of the fan and is usually impossible to see through the vent.
Posted on Nov 20, 2008
Where can you find the CMOS battery for Fujitsu Siemens Amilo PI3625
On the web!
Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie - YouTube
? 6:39
www.youtube.com/watch?v=s8kKHChQ2sw
Oct 16, 2013 - Uploaded by MrHarsel Fuijitsu Siemens Amilo Xa 2528 CMOS Batterie ... Fujitsu-Siemens Amilo Pa 3553 - Disassembly and fan cleaning - Duration: 16:09. by ...
Sep 25, 2015 | Fujitsu Computers & Internet
Laptop freezing
try check cpu and ram
Feb 02, 2014 | Computers & Internet
I have Fujitsu Siemens ( Amilo Pa 2548) laptop ,who won't startand when it's turn on a white screen appearI don't have drivers for this laptop to reboot it and I really don't know what to do help me plz
If you Google the make and model of your machine there are loads of places to obtain your drivers from, even going to the Fujitsu site should supply them. Have you tried rebooting in "Safe" mode (normally the "F8" on boot up) it might just sort it.
Feb 04, 2011 | Fujitsu Siemens Computers & Internet
Blue Screen, Zig Zag Squiggily lines, black sceen and freezes
No, try to call the HP tech support for possible repair. call at 1-800-474-6836
May 09, 2010 | Computers & Internet
Vertical coloured lines on Fujitsu Siemens Amilo laptop
u screan is damaged
u must replace the screan with a compatible one,
Feb 21, 2010 | Fujitsu Siemens LIFEBOOK N6010 PC Notebook
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
Blue vertical line on my screen which disappears when i tap screen. had laptop for 3 years. amilo fujitsu siemens laptop.
Hi Sir. This is cause by a hardware failure. THe lcd that you are using has a dead line. It will not be restored unless you change your lcd.
Jan 23, 2010 | Compaq Presario M2000 Notebook
Flashing black and white vertical lines
Vertical lines in the display indicate a failing screen. New screens are expensive and not worth the labor and parts charges to repair it. It's new monitor time.
Jul 28, 2017 | Samsung LTN1535 15 in. HD-Ready LCD...
The problem i am facing is i have vertical lines (blue) on my screen, when the laptop starts there is this unclear dots and dashes all around, the laptop i have is the Fujitsu Siemens Amilo M 1437, if...
Sounds like to two separate problems, the vertical lines, indicate a poorly seated or bad lcd inverter. the other, the dots and dashes sounds like a cpu issue, I would have it looked at.
Apr 05, 2009 | Fujitsu Siemens Computers & Internet
Computers & Internet Logo
235 people viewed this question
David Payne
David Payne
