PC Desktops
Problem for PC Desktops
Generic problem for all PC Desktops
I'm having problems starting my
By dantehr on Nov 19, 2008
I'm having problems starting my desktop computer. After I push the power button, I hear the computer working but it doesn't fully com on. There's no display on the monitor and I continue to hear the computer working and working.
Comments:
Dec 10, 2008
- Sorry but I can't seem to locate the CMOS jumper. I tried everything else and the computer is still doing the same thing. You're right, at first I hear a beep, but after it does seem like it's just the fans running. Thanks for your help.
Dec 13, 2008
- I tryed doing everything that you asked and the computer still doesn not want to boot. The fans continue to work. My brother knows a little more about computers and was able to find the CMOS and switched the pins and put them back. Still a no go. What else can I do? Will I need a new board?
Dec 13, 2008
- Oh yeah, I forgot to mention that I also replaced the 3v dl2032 battery with a new one and still the same problem.
Same Problem
Dec 13, 2008
-   I have the same problem on a dell 2350. The diagnostic lights are off except for D which is yellow, and the front power light is off. The fan runs and the motherboard led is green. What would be the next steps as I have tried the ones you suggested.
-   bappey
Solution #1
posted on Nov 20, 2008
Somewhat Helpful)
SYSTEM ONE
Rank: Guru
Rating: 89%, 41 votes
When you say you hear the computer working and working do you mean that the fans are going and the lights are on?
i ask this because the fans and power lights can come on just from the power supply coming on when you push power but that doesn’t necessarily mean the cpu is functioning.
Do you hear a post system beep and the hard drive reading files also?
Or does it just sound like only the fans cam on ?
If you think that possibly only the fans are working then try this
Shut down the computer and unplug the power cable.
Check to make sure monitor cable is connected all the way
Open the case and check to see that the video card is inserted all the way into the board properly
Remove the memory (RAM) and then put it back in to make sure it is properly seated in the slots
Plug in computer and try it again and if it still does not work then try clearing CMOS
on some systems you can clear the CMOS very easily by just holding down the insert key on your keyboard while pressing power button and continue to hold it down when releasing power button until you see something on the screen but since this does not work on all computers you might have to do it manually by moving the CMOS jumper on the board
(the CMOS jumper on the motherboard is usually the one closest to the little battery that you see on the board. with the computer off move the jumper over one notch to the other pin for a second and then put it back where it was (there are usually only three pins so this is easy step)
You should now be able to boot but you will need to go into the CMOS setup and set the clock again and other settings
If you still have a blank screen then let me know and i will take you to the next diagnostic step...
Hope this info helps
Comments:
Dec 10, 2008
- the CMOS jumper is usually the one closest to the little battery on the motherboard
it will have three pins with a jumper on two of them just move it over to the other two pins then back
Dec 17, 2008
Here is a link to diagnostic codes for your model: http://support.dell.com/support/edocs/systems/dim2350/advanced.htm#1118998
The D on the back of the case usually means there’s a problem with the display or the video card
And if it’s integrated video, than maybe it’s the mobo
But you can also try this:
Unplug everything, cd-drive cables, hdd, pull out all expansion cards, unplug the fans than try it again
See if anything changes
(Break it down to i/o panel, memory, cpu and psu)
If it’s having the same problems than try resetting the ram, if there’s two sticks than try them individually in each slot
If that doesn't work, than unplug the front i/o panel (power button) and plug the power cable back into the psu. And it should power up automatically with the i/o panel unplugged
Was this helpful?
Yes
No
Popular Solutions for PC Desktops
Questions and Unsolved Problems for PC Desktops
Answer
I am looking a great 2000 volt battery back up for my computer.
Answer
How can we improve the graphics quality with our SAMSUNG P2370 LCD Monitor for use with Photoshop... (More)
Answer
black screen with the words safemode , safemode with networking once clicking on them it still dose... (More)
Answer
I lost my installation disk and need to update my sound driver. how do I get a new one for my pc?
Describe your PC Desktops problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktop Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
