Question about Car Audio & Video
Kenwood GX-99, error: BUS-E04
I have a subaru factory sound system, kenwood GX-99, it suddenly doesn't operate & amp displays "Bus-E04".
Does anyone know of a reset code or something I can do?
nb: The car is a japanese vehicle.
4 Suggested Answers
  • 4 Answers
SOURCE: BUS - E04 appears and the stereo wont work on car
You need to take it to a radio thec and have thenm recode it or the stereo is not for that modiel
Posted on Dec 27, 2009
SOURCE: Operating instuctions for 97-99 mitsi
I advice you check the two links below to search for the user manual of your unit, the link contain virtually almost all the manuals of all unit.
manualsonline.com.
or
manualnguide.com
Type any of the above link on your web browser to search for the user manual of your unit.
Take care.
Posted on Jul 08, 2010
  • 52 Answers
SOURCE: I received a kenwood kdc-mp345u
Any time you upgrade your radio to an aftermarket you have to have the wire harness with it to connect to your dash.
Posted on Dec 25, 2010
Ricoh aficio 3035/3045 error sc 672 not able to proceed to service mode also, kindly help me pls.
possible a bad operation panel replace or 672 B
After powering on the machine, the
communication circuit between the
controller and the operation panel is not
opened, or communication with
controller is interrupted after a normal
startup.
Controller stall
Controller board installed incorrectly
Controller board defective
Operation panel connector loose or
defective
690 A GAVD block I2C bus error
An error is detected in the GAVD
communication I2C control register of
the GABIC2.
I2C bus on BICU defective
691 A GAVD FCI block I2C bus error
An error is detected in the FCI
the GABIC2.
692 A CDIC GAVD block I2C bus error
An error is detected in the CDIC
the GABIC2.
700 B ARDF original pick-up malfunction
After the
Sep 21, 2012 | Ricoh Aficio 3045, 3035 Kit
Bus: 06, Device: 01, Function: 00 ERROR Resource Conflict - PCI Network Controller in Slot 02 Bus: 06, Device: 02, Function: 00 ERROR Resource Conflict - PCI in Slot 03 Bus: 06, Device: 04, Function:...
I would firstly reboot and if that doesn't clear the error run www.iobit.com asc.setup utility to remove crosslinked files and sort out a crosslinked registry. Failing that remove the driver from the Control Panel and let the OS set up a fresh driver. Make sure the driver is the correct one!
May 02, 2011 | Acer Aspire 5100 Notebook
Code u0008 high speed can communication bus (-) high
U codes are reserved for future systems and may be proprietary to the manufacturer.
The CAN Bus allows 12 Volts, or other potential, power to be distributed around the vehicle (or system) on a single power rail with local actuators connecting the power to each application as needed. Vehicle functions such as temperatures , alarms or the positions of switches are monitored by sensors connected to the bus and the controller can direct the actuators to initiate the appropriate response as required.
Two variants are available to suit different transmission rates. A high speed (1 MBaud) bus is used for rapid control devices for operations such as engine management and vehicle stability and motion control. For simple switching and control of functions such as lighting, windows, mirror adjustment and instrument displays a low speed (100 KBaud) bus is used.
The CAN bus was designed to provide secure communications in the very harsh operating environments with high levels of electrical noise which are found in automotive systems.
The communications protocol defines the following:
  • Method of addressing the devices connected to the bus
  • Data word format (The message)
  • Priority setting
  • Transmission sequence
  • Control signals
  • Error detection
  • Error handling or correction
  • Transmission speed
The message data, the control signals and the error correction are contained in a data frames of equal length which are transmitted sequentially over the transmission channel.
Definitively, you need visit the dealer to know excalty is you have any problem with the software in your modules os any loss harnesses or wires there.
Additional details, onyl with the manufactured.
Hope this helps.
Jan 30, 2011 | 2002 Hyundai Accent
BUS - E04 appears and the stereo wont work on car stereo which is a subaru super real focus sound system GX -99
Nov 08, 2009 | 1997 Subaru Legacy
CD Changer connector of KENWOOD GX-608EF2B
aye have the same system for my car a subaru, but the release button is missing and need a new one?
Apr 01, 2009 | Kenwood Car Audio & Video
BUS-E04 KENWORD ERROR
It is letting you know there is an error with the audio system. Error code #4.
I don't remember what that code is exactly, but I thought those codes were for the CD Changers. Do you have one?
Bret
RepairPal.com
Nov 20, 2008 | 1996 Volvo 960
Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
Jul 19, 2008 | Toshiba Satellite A105 Notebook
Device manager shows error in sm bus controler
goto to system devices look for the question mark, right click, and try reinstall the drivers again, this should normally work and reboot your machine and the drivers should be there.
may be the bus driver you are trying to install may not be compatable for your machine, check with the user manual to see what bus derivers you can install
Nov 17, 2007 | Computers & Internet
Kenwood in-dash DVD/Sirius/Nav/etc
Hi wonky1,
On an identical problem, I posted a reply here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Oct 02, 2007 | Kenwood KHD-C710 MP3 Player
Car Audio & Video Logo
293 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
