Question about Whirlpool Refrigerators
Fan motor ???
I hear a loud chirping sound in the top compartment of freezer ,it stops and starts with air flow When fan runs constant there is no noiseMy question is is it a fon motor or the componet that controles the fan It chirps on and off for several minutes then quits for 30minutes .1 hour, sometimes more How accecable is this fam thank you howard
  • howardpc Dec 10, 2008
    Thank you for your help I replaced fan motor as instructed so far its working after one week dthanks again Howard
    Scholar:
  • 66 Answers
fan motor ??? - ef452b7.jpg I will send another figure then instructions
Posted on Nov 20, 2008
  • 2 more comments
  • Charles Caldwell Nov 20, 2008
    Now I will send you some instructions
    Some tips and procedures on replacing a common Whirlpool evaporator fan motor....
    Disconnect power before servicing!!
    - Unplug refrigerator
    - Remove the screws and the back wall of the freezer
    - Remove fan motor
    - Install the 2 mounting grommets and the 2 sleeves from the fan motor kit onto the new motor as shown in Figure 2. NOTE: On models with foam-insulated cabinets and special screw grommets ( shown in Figure 1 ) - Do not use the 2 sleeves provided in the kit to mount the motor.
    - Mount push-on fan blade onto the motor
    - Connect wire leads to the new motor
    - Mount the new motor to the liner with the 2 screws provided in the kit. NOTE: Porcelain liner models may require breaking off the ends of the mounting brackets where shown in Figure 2.
    - Plastic liner models do not need the parts in this kit.
    - Make sure that the fan blade spins freely
    - Reinstall the cover panel
    - Plug in the refrigerator
    This is typical of a bad evaporator fan motor.Usualy this is pretty straight forward if you are mechanicaly inclined. Of course you will have purchase a evaporator fan motor kit from an appliance supply store. Take your model numder and brand with you. They will be able to give you the correct motor.
  • Charles Caldwell Nov 21, 2008
    If this was helpfull to you, will you please rate me. I would so much apreciate that.
My LG ice maker fan is making a really loud noise right after the water stops going in
Hello, Self-defrosting refrigerators use a circulating fan to move air through the freezer and refrigerator compartment. This fan runs when ever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall,near the top or bottom, in the center of the freezer.
  • If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
  • If the freezer is on the left, the fan is on the back wall, half way up or near the top.
Overtime the fan may become noisy, usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise,just open the freezer door and push in any fan/light switches, if the noise is louder when the door is open, the evaporator fan motor is the cause. You can lubricate or repair this motor. You must replace it.
There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor(if self-defrosting), or the defrost timer (if self-defrosting).
Thanks
Jun 17, 2010 | LG LSC26905TT Side by Side Refrigerator
Freezer compartment is thawing
Sounds like the compressor seized. The buzzing you hear is the compressor trying to kick on.
I noticed that happens a lot with air conditioners if power is interrupted when the compressor is running.
Did you try unplugging it for 20-30 minutes?
Sometimes letting it sit unpowered relieves the pressure that was built up in the compressor, making it easier for it to start.
Jan 10, 2008 | Maytag MFD2560HES Bottom Freezer French...
The fridge works but the freezer, while cold, does not freeze
Hi, The freezer compartment is (logically) favored for cooling. There is a fan, normally between the back of the freezer compartment and the outside sheet metal that circulates the cooled air from the hidden coils to the refrigerator compartment.
When you hear the compressor is running, look for vents in the back of the refrigerator side and hold some wet fingers in front of these. Under normal circumstances, there should be an easily noticeable flow of air coming from these vents that represents the fridge's share of the cooled air. If there is none or is very little flow, the fan has either slowed (sticky sleeve bearings) or the fan has stopped completely. This isn't a dangerous problem since all modern electric motors are 'impedance protected' meaning that if the motor cannot turn, it still will not get any more than hot, it won't catch fire as they once would.
Thank you!
May 13, 2010 | Frigidaire FRS3R5EMB Side by Side...
Why does the top freezer work extremely well, even freezing water on the lowest setting but the lower part only gets to 47 degrees? As the freezer is turned to high the lower part increases to 52 degrees....
Sounds like your door seal is damaged somewhere on the lower door. Take a dollar bill and stick it longways along the door seal, and close door. There should be a firm resistance pulley the paper out. Move the bill along the door seal, checking each inch.
Of course, if the bottom part of the seal has a gap, this can usually be seen visually. Why the bottom part? Because when something gets spilled in the fridge, and "Not Me" doesn't clean it up, the stickiness pulls the seal, stretching and deforming it.
Why does the temp go up when freezer is turned lower? Because the fan in the lower compartment runs when the compressor runs. The more air that is moved in the lower compartment, the more air that is moved through the bad door seal.
Sep 15, 2009 | Refrigerators
Beeping sound coming from control panel model#10656562400
Hi!
Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.
To find out if the fan is causing the noise, just open the freezer door and push any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause which can't be lubricated or repair instead required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 01, 2009 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Humming sound? motor or fan constantly running
Hi, It is the evaporator fan motor you are hearing. The motor is the only thing that shuts off when the door is open. The fan motor is located behond the rear panel inside the freezer sections.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 01, 2009 | LG LSC26905TT Side by Side Refrigerator
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
GE side by side Refrigerator makes LOUD SQUEAK when running
Noise can come from these areas:
The inside of the freezer Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:
  • If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.
  • If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).
  • The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
  • If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.
  • The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
Mar 24, 2009 | GE Refrigerators
I have a Samsung RS21DPSM side by side fridge under 2 years old and the other day a loud noise was coming from fridge Sounds like a fan as when you open fridge door it grinds to a stop) compartment and...
There is a design problem with this model. The fridge section is icing over due to a design defect and the noise you can hear is due to the fan on the motor driving against the ice. Eventually the motor will be stopped from running and the fuse will blow in your plug. Contact Samsung and they should replace the defective parts with a fix.
May 11, 2008 | Heating & Cooling
Noise from Deodorizer
Sounds like the circ. fan may be hitting something or has a blade broken off. The refer gets cool air from the freezer section to cool it so the fan aids in the circulation along with vents/dampers, etc. to move air into the refer compartment. If that fan is broken off the motor shaft or something then the motor can run but no air will move. See if you can feel air moving out of the vents, it will be a little bit of "blowing" not a huge wind. A wet hand can help feel for wind. I believe the deodor light may indicate a change is needed (but check the owners manual for actual meaning). If there is no air flow open the freezer section and see if the air flow is noticed then... if a air channel if frozen and can't draw air from the proper area, opening the freezer door will give it outside air and you may feel flow then, that would tell you of a frozen air channel issue.
Oct 16, 2006 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
146 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
