Question about HP Computers & Internet
I HAVE A HPW19EV MONITOR ITS OPTIMUM RESOLUTION IS 1440 X 900 @60 HZ CAN YOU HELP
    Sergeant:
    Champion:
  • 226 Answers
I don't understand your question. I have 2 of the HP w19ev's on dual view and their max resolution is 1440 x 900 @ 75Hz. You'll have to explain what you want help with.
Posted on Nov 19, 2008
How to fix analog input can not display this video. Optimum resolution 1280 X 1024 60 HZ
you cannot ajusta a system to handle a resolutuion it was never made to handle
May 27, 2014 | Dell Computers & Internet
Tell me what is samsung syncmaster 794 default setting
The maximum resolution supported is 1280 x 1024 pixels at 65 Hz refresh rate, while the recommended resolution stands at 1024 x 768 pixels at 85 Hz. However, the maximum usable resolution is 1152 x 864 pixels at 75 Hz. Maximum usable resolution signifies the maximum resolution supported by a monitor at a refresh rate of 75 Hz or better. Though 85 Hz is an ideal refresh rate, 75 Hz is the lower limit. Any refresh rate, lower than 75 Hz, will give a flickered output and can cause some serious eye damage after prolonged usage...i hope this helps.
Aug 29, 2011 | Samsung 793DF 17" CRT Monitor
When i open the screen i get an indication "not optimum mode Recomended mode 1400 x 900 60 Hz but i can't find a way to adjust it!
this setting is set in windows, right click on your desktop, go to either graphic options or properties and look for a resolution slider, the more you increase the slider the higher you resolution, but smaller the graphics on the screen, if the slider wont go that far or does not have that resolution you will need to change your monitor driver. in the same window, click advanced, monitor settings, look under the driver tab. you may need to download a driver for you monitor and operating system, if its not listed.
Aug 27, 2010 | Samsung Syncmaster 940BW LCD Monitor
I have a Samsung SyncMaster 901B, it's not new, a friend gave it too me, i connected it to my computer,i start the computer, it works fine until windows finishes loading, then the screen goes black and i...
What happen when you hook this monitor up to other PC that has the video setting 1280 X 1024 60 Hz? Just ant to narrow down the problem before opening up the monitor. You may have logic problem in the logic board. If it does the same with other PC, then open it up and inpsect the inside for such thing as failed caps on the logic board or on the main power supply board, I think more likely to be ROM chip on the logic board is scrambled.
See typical failed monitors: http://s807.photobucket.com/home/budm/allalbums
Mar 30, 2010 | Computers & Internet
Out of range
Use F8 at boot to access windoze safe mode. Right-click the desktop, and open the display manager. In the display settings configure as a plug-n-play monitor, or manually set the resolution to 1280 X 1024 and the refresh rate to 60 or 70 Hz. Those setings match the monitor's optimum settings. Save and close. Reboot and allow normal startup.
Feb 06, 2010 | Daewoo Lucoms L750DP 17 inch Monitor
Monitor stops working and box start floating around on screen with "Not Optimum Mode -- Recommended Mode 1280 X 1024 60 Hz." Replacement monitor works on computer.
check if your monitor has an auto-adjust button, this will help you autoadjusting the recommended resolution so that there are no problems, if not, you can try to rightclick on windows desktop and go to properties>configuration, set the resolution there
Sep 16, 2009 | Computers & Internet
Not optimum mode
This means your computer windows resolution is not display in the correct resolution which your samsung LCD will take.
What you need to do it boot the computer in safe mode. (pressing F8 at start up and select safe mode) This should bring the windows to start up in the generic 800x600 resolution.
Once you are able to see the display in safe mode, go onto the display properties and change the resolution.
* right click on desktop -> properties -> settings
Please rate this if it solves your issue. If you need further assistance please post.
May 29, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Monitor goes black
Does it show a picture in safe mode? If it does you might want to install drivers specific to the Monitor if you can find them.
Jun 18, 2007 | Samsung SyncMaster 510N (Silver) 15 inch...
Computers & Internet Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
