Question about Dayton (3E379) Heater
Need to disassemble a thermostat
I have a dayton model 2E468 thermostst and I can't get the cover off to relpace it with a programmable one. Can you help me?
\Need to disassemble a thermostat - need-disassemble-thermostat-hkhrgyi5xknzwfjjbqmysm0g-3-2.jpg
  1. Pull the faceplate (bottom) straight out from the wall.
  2. Loosen the screws at the end of the wires, like the one in the middle at the tip of my middle finger.
  3. Remove the 2 screws which hold the rest in.
  4. Make a note of which wires were attached to what. I suggest taking pictures.
Posted on Jul 15, 2016
  • Elwood Bergman
    Elwood Bergman Jul 15, 2016
    I suppose it would be prudent to say that you should disconnect the power first, and remember that you may have to re-light the pilot on your furnace, if applicable. Please don't electrocute yourself, or blow the house up.
  • 108 Answers
Check for screws on this stat. If no screws than you need to exert force to remove the cover. Will you damage it? Who cares! You are replacing it. Just be sure you remember the color code. R to red, W to white and etc.
Honeywell programable stats are availible from Home Depot for under $50.
Hope this helps you Dave....
Ray
Posted on Dec 07, 2008
4-wire coming off living room wall. Needs direction to connect to Dayton 2E468 thermostat which has only 3 post with blue, white & yellow wires on 2 of 3 posts.
Must be a nice living room wall!! Do you honestly expect to get an answer to that? What's the unit, what's the old tstat, where were the wires landed before????? Help us so we can help you!!!
Aug 08, 2017 | Dayton Heating & Cooling
Looking for how to hook up a thermostst
That all depends on how old the system is, wires colors change over the years,.
May 19, 2017 | Dayton Heating & Cooling
Where is the thermostst located in a 2006 cobalt LT 2.2 eng.
Check this diagrams...
Fig. Location of radiator outlet hose clamp (1) at thermostat cover for the removal of the radiator outlet hose from the thermostat cover - 2.2L & 2.4L engines
Fig. Location of thermostat cover bolts for removal of the thermostat and thermostat cover O-ring seal - 2.2L & 2.4L engines
Hope this helps.
Sep 22, 2011 | 2006 Chevrolet Cobalt
I have a carrier heat pump model # 38RQ034300 I need instructions for. To maintenance and use thermostst correctly
That is model number for your outdoor unit. Thermostats are not dedicated to any particular model outdoor unit. You need instructions for the thermostat so the thermostat make and model number are needed.
Oct 16, 2010 | Carrier Heating & Cooling
How do i hookup a thermostat to a dayton unvented radiant heater modle be132c
Hi, If you are hooking up a programmable stat, the connections on it would be RC, RH, with a jumper connected to both, Y, W, and G. If you only had 2 wires before, red to RH and white to W. For cooling,Red to RC, and W to Y. Do not remove the jumper.
Shastalaker7
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
I need to set my thermostst and I don't know how. I have the RTH 2308
I think you have a RTH230B. Here is a link for this stat.
http://customer.honeywell.com/techlit/pdf/69-0000s/69-1800.pdf
Oct 01, 2009 | Honeywell Electronic Programmable...
Have dayton model 2e215 mercury thermostat and trying to replace with programmable. How do I get the old one off of the wall. It looks like the mercury vial sits on a cover over the wires but I cant see...
There are either 2 or 3 small screws which hold the thermostat to the wall plate.
Remove these and the thermostat will come off to reveal the wall plate with the wiring connections.
Sep 06, 2009 | Heating & Cooling
Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
Dec 07, 2008 | Dayton (3E379) Heater
Dayton (3E379) Heater Logo
289 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
