I can see cheap parts on amazon, so take a look... Amazon com mcculloch blower parts I hope this was helpful. cheers
SOURCE: I have a McCulloch MB3202 back pack blower that
Must have good strong blue spark
Must have correct fresh fuel / oil mix.
Must have air. Check for leaks at intake manifold.
Can you use choke to keep it running, if so air leak OR lack of fuel.
SOURCE: Carb adjustment on McCulloch 32cc?
the l is for idle and the h is for top end but thats not ur problem it sounds like ur carb is clogged there is a screen inside of the carb the fuel gets crystalized and blocks off some and sometimes all of the fuel ill bet thats the problembut u can try the adjustments first give the unit full throttle and turn the h adjustment screw in and or out till it sounds great and at full power if that dont work then do the screen in the carb
SOURCE: McCulloch 32cc backpack leaf-blower
Mcculloch MB3202 anti-vibration back pack leaf blower, runs better at the middle setting of the choke than it does if it's wide open the way it should be. Can't get it to blow leaves well. Owners manual lost. ANY ADVICE???????? New gas, spark plug starts on the first pull but just doesn't give out like it should.
SOURCE: i need a clutch for the mcculloch backpack leaf
Email me with your model # and I'll quote you a price & availability. The blower is made by Poulan.
Email [email protected].
SOURCE: I have a mcculloch backpack
I am assuming the carburetor is ok. Check your spark arrestor. This is a screen located at muffler exit. Usually just a screw holds it in, pull it out with a pair of pliers and clean or replace. I usually hold it with pliers and burn it clean with a little bernzamatic torch. If that doesn't fix it probably a carburetor problem.
