Audio static coming from DVD player, checked to be sure it was coming from DVD player by recording and playing the recording back - static is on the recording
SOURCE: Dish network
With the dish remote and do a code search as described in the remote manual and see if you can find it that way. If you go through the entire code search and none of them turn off the VCR/DVD combo, then there is nothing you can do, as those codes in the remote are all stored in the remote and they cannot be programed in. If you do not have a remote manual to set up the remote, to do a code search, simply go to the dishnetwork web site and search for it.
SOURCE: EMERSON DVD RECORDER MODEL EWR20V5
here's a link to the manual emersonaudiovideo.com/pdf/om/EWR20V5.pdf hope it helps
SOURCE: Emerson DVD Recorder EWR20V
Called the funai's service tech line at 1-800-605-8457. They will sell you a firmware update for 23.00 shipped that will allow it to use up to 8X DVD-RW. I'm using memorex 2X DVD-RW (RITEKW01) I got from walmart. They seem to work OK although dubbing on my deck doesn't seem to work. Probably unrelated.
SOURCE: I have a emerson dvr recorder that everytime you
Need a firmware upgrade. Emerson will charge you for it. Otherwise you need to find Dvds it will accept. Hard to do with all of the newer dvds. -RW only 1Xor 2X. -R 1X-2X. Memorex would not work for me. Multi- speed dvds over listed speeds will not work. Maxell -R 1X-4X worked for me. Good luck finding any.
