Panasonic TV Model PT-51G30. Power go off intermittently. Will not go on with power button. Can be restarted by unplugging power cord and re-plugging, then pushing on/off power button on TV ( not on remote control ). When re-started, power may last for hours or minutes. Then suddenly goes off.
  • 2 more comments
  • Rpxo Nov 19, 2008
  • Rpxo Nov 19, 2008
  • Rpxo Nov 19, 2008
    Panasonic TV Model PT-51G30. Power go off intermittently. Will not go on with power button. Can be restarted by unplugging power cord and re-plugging, then pushing on/off power button on TV ( not on remote control ). When re-started, power may last for hours or minutes. Then suddenly goes off. ( no problem with remote -- it works fine when TV on )
  • Rpxo Nov 19, 2008
    Several solutions were helpful. I will have to call a serviceman, but at least I know what will probably be wrong. Thank you.
    Sergeant:
    Champion:
  • 435 Answers
This might either be due to power supply unit problem or loose contact some where.
Open the power supply unit to make sure none of the connections are loose. Also check for any burnt capacitors or any other components.
Does it work normally w/ remote ?
Posted on Nov 19, 2008
    Scholar:
  • 181 Answers
The main power supply board is getting short somewhere in the circuit tracks get the main board of your tv checked to locate the exact fault.
  • 4,806 Answers
Sounds like a power relay switch is ready for going, have a look for a semiconductor which has slightly blackened
hope this helps
regards
  • Lee Hodgson
    Lee Hodgson Nov 19, 2008
    If you cannot find the fault and you want to have it repaired and live in the US here is the repair website:
    http://tv-repair-service.com/panasonic_t...
    regards
    Sergeant:
  • 276 Answers
It the internal board problem in your tv set any of the capacitors have got loosed so when you ON the tv it works and when that loose electric component gets heated up the tv gets OFF.
  • smarttech Nov 19, 2008
    and for the remote not functioning it could be the battery problem replace the battery.or in the tv there is a sensor which gets detected when you use the remote.that sensor in the tv must have gone faulty.so the remote is not able to make the tv ON.
    if u have the proper technical idea oh how to use multimeters and soldering irons you can open the tv back cover and then remove the main board which is normally attached to the tv base with six to eight screws and check out for the loose or burnt capacitor and get it replaced with a new.
    or you can take it to the repair center to get it repaired if do not have much technical knowledge.as it is very risky to open and service the tv when the the tv is ON  or the power cord is plugged in the electric outlet the results may be very fatal and dangerous.
    as the tv is getting ON and working properly as u said.it will not be too costly to get it repaired.
How to do lamp reset on panasonic pt-lb50u projector.
To reset the lamp hours, turn on the projector. Then press Menu and use the Up/Down arrows to highlight Options. Press Enter then highlight Lamp Runtime. Press and hold Enter for 3+ seconds until the Lamp Runtime screen is displays. Press the Power button (any other button cancels the reset). When the Power button LED turns red, unplug the power cord to the projector. You can either use the remote or the controls on the projector. Reconnect the power cord after a few minutes.
The reset instructions are on page 62 of the user manual. The manual is available from Panasonic here: https://support.panasonic.co.nz/docstore/PT-LB50U%20Operating%20Instructions.pdf .
I hope this helps.
Jun 18, 2016 | Panasonic PT-LB50U Multimedia Projector
How to reset lamp w/o remote panasonic pt-52lcx16
Instructions
    • 1 Pressicon1.png the "Power" button on the TV remote control to turn the Panasonic rear-projector TV on and display a picture on the screen.
    • 2 Press the "Menu" button. The "Main Menu" will appear on the screen. Press the "Option" button.
    • 3 Press the "Enter" button. The "Optional Menu" screen will appear. Press the button to select "Lamp Runtime."
    • 4 Press the "Enter" button and hold it for about three seconds. The "Lamp Runtime" will change to display "Time Reset (Powericon1.png Off)."
    • 5 Press the "Power" button to turn the TV to the off position.
    • 6 Unplug the power cord from the electrical socket. Wait about one minute and plug the TV into the electrical socket
Read more: http://www.ehow.com/how_7201809_reset-lamp-timer-panasonic.html#ixzz33LeXpAsl
Jun 01, 2014 | Toshiba 37WLT66 37 in. LCD Television
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
REAR PROJECTION HDTV ISSUE
Decoding the number of beeps may be possible with the owner's guide but this type of problem is normally due to a failed power supply.
These are often mounted on separate boards located in the bottom of your set and can be identified by the much larger parts you see on the board and possibly its relationship to the AC cord coming in. While these can be repaired, the cost of that will approach the cost of a new assembly.
Unfortunately, modern, more energy-efficient power supplies have some critical components that if bought cheap, don't last very long and frankly, 5 years isn't bad, I read of many dead within the first year.
Jul 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Green and purple ghosts
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Oct 09, 2008 | Panasonic PT-47X54 47" Rear Projection...
Panasonic PT-53WX53 cinemavision HDTV keeps powering off right away
5 blinks is telling you that IC4511 on the DG board is faulty. This is not serviceable you will need a new DG board the part number of that board is TNP2AA126
Mar 25, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
