Question about Samsung RS2556 Side by Side Refrigerator
SAMSUNG RS2545SH I HAVE SEVERAL RETURNED SAMSUNG SIDE BY SIDES...THEY ALL HAVE THE SAME PROBLEM... AFTER A PERIOD OF TIME THE FRESH FOOD SIDE TEMP LITE FLASHES.... YOU SAID IN THE SOLUTION TO REPLACE THE CONTROL BOARD... IS IT THE MAIN BOARD ON THE LOWER BACK OF THE REFER OR IS THEIR ANOTHER... WE HAVE ALREADY REPLACED THAT ONE AND THE PROBLEM SEEMED TO COME BACK....ANY CLUES????? THANKS, KEITH
murdozzz2
  • 75 Answers
SOURCE: inside fan area freezing up (no defrost?)
hi there this is a common fault you need to replace the evaporator cover with the new modified one which has a large heat sink around the fan to stop iceing up also you will need to replace the thermal fuse and the defrost sensor.
hope this is of some help
Posted on Dec 13, 2007
bobotfel
  • 236 Answers
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Posted on Mar 08, 2008
SOURCE: Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
sandy82
  • 10 Answers
SOURCE: samsung SR-S22FTCS
dear friend
The water filter doesn't affect the cooling perfomance of ref.ther may be problem of defrosting of ref.compartment.
regards
sandy
Posted on Jun 08, 2008
  • 22 Answers
SOURCE: Samsung Refrigerator
this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Posted on Nov 13, 2008
I have a Samsung model RS2530BSH and the water freezes up all the time why?
does the icemaker work? this has 2 evaporators and the flow of refrigerant goes through the fresh food side first and if the icemaker fails it will cause it to up temps in freezer to increase thus increasing the temp around the fresh food evap. now if this is not the case check the seals around the bottom part of you fresh food evap for air leak .
Feb 25, 2013 | Refrigerators
I have a samsung rf267AA fridge and there is a lot of water collecting under deli draw why? is it the evaprator it has 2 witch one is it ?
I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Sep 07, 2012 | Samsung Refrigerators
Accumulates water on bottom floor below bins
Thanks, Sea Breeze
Jul 19, 2012 | Sub-Zero 695/O Side by Side Refrigerator
My Frigidaire PHSC239DSB2 side by side's digital temperture display is flashing a 2 on the freezer side & the fresh food sides temperature went up to 47 degrees, but has no flash. What is goin
HI this is a difficult one without a visual but i would sugest u disconnect the power supply.re-connect everything again and re-start.reset temp if not pre set.and try before u call an engineer.good luck.Ali
Jun 18, 2012 | Frigidaire FRS26H5AS Side by Side...
Samsung sidexside refrigerator model RS263TDBP refrigerator warm freezer fine. Replaced fan on refrigerator evap coils, still not working. Help
Check the diverted box in fresh food side. Some of them have an electric flapper that opens to let cold air in to maintain temp in fresh food side. If coils are not frozen up then that is the next thing I would look at. The flap might not be opening up,
May 17, 2012 | Samsung RS263TDBP Side by Side...
What temp should the frezzer be and what temp should fresh food side be
hello, the standard temps are zero in the freezer and 38 in the fresh food side. Hope this helps.
Jun 07, 2011 | Samsung 24.6 Cu. Ft. 4-Door Side-by-Side...
What should frig and freezer temp be set to and how to set temp on model RS2545SH
Appliance manufacturers usually instruct customers to set the temperatures (both freezer and fresh food areas) to approximately the "one-half way" mark/setting.
Feb 15, 2010 | Samsung Refrigerators
My SAMSUNG freeze side working fine but on fridge side is not
This has happened in my GE side-by-side (model GSS20IEMDWW). For me,the problem was caused by a faulty temp sensor in the fresh food side.That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Sincethe compressor was running constantly, the evaporator coils (back wallof the freezer compartment) eventually iced over (took about a week).Since the fan that draws air over the evaporator coils could no longermove any air (due to the icing), the temperature in the fresh food sidecontinued to climb. (The fresh food side is chilled through a hole witha motorized door at the top of the dividing wall, so if no air ismoving in the freezer compartment, temps in the fresh food compartmentclimb.)
I replaced the temp sensor in the fresh food side andsolved the problem for a while. About six months later I had the sameproblem again, so I replaced both temp sensors in the freezercompartment - which solved the problem again. (My fridge is about seven years old.)
Ifyou are going to replace any of the temp sensors, replace them allunder the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a refrigerator that is 10 years old it is a tpx24pbe bb model number and the refrigerator side is staying at 50 degrees what is the problem?
On my GE side by side (model GSS20IEMDWW), a warm fresh food side, as well as iced-over evaporator coils in the freezer, was caused by the temp sensor in the fresh food side sending faulty data to the computer.
The temp in the fresh food side would climb because air could no longer pass over the iced-up coils in the freezer side.
For me, the faulty fresh food side sensor made the computer always thing the fresh food side was too warm, making it constantly run the compressor (thus icing up the coils).
If you do not have a coil icing problem in the freezer, then your fresh food side temp sensor may be telling the computer that the fresh food side is already cold enough.
Jul 27, 2009 | GE Refrigerators
Samsung RS2556 Side by Side Refrigerator Logo
118 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
