Question about Air Tools & Compressors
PAINT GUN SPITS PAINT AFTER ABOUT 10 MINUTES OF USE
After about 10 minutes of using my spray gun. the paint starts spitting out
  • sanchezauto2 Nov 20, 2008
    thanks for your help. we fixed it
  • hdpanama
    hdpanama May 11, 2010
    what kind of paint gun are you using please ? electric airless, conventional air, air powered airless
    Thanks
    Scholar:
  • 65 Answers
Are you straining the paint through cheese cloth or some other type of strainer ? Trash in the paint building up around the tip could cause it, straining will eliminate that. The return spring, or the grommets depending on what type of gun your using could be wore out keeping the needle from seating closed all the way. Is it when you stop spraying or during. May need to change the pressure setting or tip size for the material you are spraying, again, depends entirely on your specific situation as to what could be causing the problem. But these are things you can try. The paint store would probably be able to point you in the right direction if it comes down to changing tips. Might be worth a call to save yourself more aggravation. hmmm,, goes to show how observant I am,, sanchezauto,, are you painting cars,, with a conventional cup gun ? All of any of the above could apply. And if your painting cars you sure don't want a spitting gun messing you up. (-8
Posted on Nov 20, 2008
  • hdpanama
    hdpanama Nov 27, 2008
    your welcome sanchezauto2
    hdpanama
Spray gun problems
You basically have what is called a "cupgun" and there are a few reasons for this and it should be pretty simple to fix I want to stress that anytime you spray the paint no matter what latex-oil needs to be thinned with the compatible solvent water for latex paint thinner for oil/Alkyd by about 10% - 18% that could be the problem if you have latex in your gun but probably it has to do with the "needle seat" in the back of the gun there should be a knob to adjust the needle turn your gun on pull the trigger and turn knob till paint comes out if that wont work you may have debris in your paint that has clogged the stem pour all the paint out clean gun completely pour paint threw a strainer cone or strainer bag and be sure to thin it...
Sep 01, 2014 | Wagner Paint Sprayer. Flexio 570 HVLP...
Spitting
most paint spray guns require the paint to be thinned this may be the cause of the spitting
Apr 15, 2014 | DeVilbiss Jga-510 Paint Gun Sprayer Item...
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
440i wont stop spraying
Either your gun is dirty and the valve spring can't close the tip valve properly or the seat it pushes against is damaged. First try cleaning the gun very throughly. Take it apart and get everything out of the gun that doesn't belong there. If it still does the same thing you can buy a repair kits for the paint guns but they're usually expensive and you're almost always better off replacing the gun.
Sep 29, 2012 | Titan 440I Spray Guns
Porter cable PSH 1 - clogs even with thinned paint compressor 4 gal 5.1 scfm
strain paint befor using. run water in gun or thinner to see if it will spray it before using and mix paint to the consistancy that spray gun or paint requires for spraying ( fine strainer)
Feb 04, 2011 | Porter Cable Gravity Feed Paint Sprayer
Why does my gun keep spitting
Spitting is usually caused by not filtering the paint through a strainer (made for the purpose by the paint manufacturer). The paint debris blocks the paint for just a moment, then spits it out. Easy fix!
Jun 09, 2010 | Wagner GX10 Airless Spray Gun
Worked for about 10 minutes
do you have a gun that comes apart? alot of them have that filter in the gun that clogs up with latex.you could remove gun and soak in mineral spirits if it does not have that filter.
Sep 05, 2009 | Campbell Hausfeld Airless Spray Guns &...
I bought a psh1 to spray latex as the reviews
Hi
What size is the jet?
What compressor pressure are you using, LOW is good >20PSI
You will need quite a large jet for latex paint even thinned. I have tried a 1.8mm jet and that still clogs!! Consult your local spray painter with what size jet you need.
I am betting the standard size of 1.5mm is way too small, that type of gun is fine with the correct jet size.
Aug 12, 2009 | Porter Cable Gravity Feed Paint Sprayer
Problem spray painting water based paint
I spoke to a friend who was a spraypainter in his last job, apparently due to the thickness of the paint, I needed a larger nozzle on the gun. I couldnt get a nozzle to suit this gun so I purchased another gun with a cuple of different size nozzles. All seems to be working fine now.
Nov 19, 2008 | Air Tools & Compressors
Vaper primer gun has intermittent air supply
Does it come with instructions? The material thickness is VERY IMPORTANT when choozing the proper nozzle.
Nov 17, 2008 | Northern Tool Vaper 2.0mm Hvlp Spray Gun...
Air Tools & Compressors Logo
182 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
