Panasonic Model PT-51G30 TV. Power goes off intermittently. Can be restored by unplugging and re-plugging power cord and pushing "on" button on TV ( not on Remote ). May stay on for hours or minutes then off again.
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
TV won't turn on when push power button red light flashes
You can unplug the tv for 1 minute and then plug it back in since you have a red light you know it is getting power, also don't plug it into a surge protector when trying this. If the tv still has a flashing red light a service center will need to repair the tv, replacing more than likely the power supply or small signal board.
May 07, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My panasonic rear projection tv will not power on and no lights turn on. Any suggestions?
Please plug TV in another power source and turn it ON,
if still does not turn ON, unplug AC wire of TV, take off back cover and follow AC cord f TV that will take you in power supply board, find fuse nearby and check is it blew off? if yes, replace it with same ratings written on it.
Plug TV in AC wall socket and turn ON, if fuse blow again that means power supply section in TV got problem and need qualified tech to find out and replace components or power board.
Sep 18, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Panasonic PT-51HX41 51 inch
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Green and purple ghosts
Try to reset first if nothing happens we proceed another solution;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Oct 09, 2008 | Panasonic PT-47X54 47" Rear Projection...
Panasonic PT-47WX49E will not power on
Thats a power supply module going bad. Dont use it until a person with knowledge on TV see that. Or if you feel you can DIY open the back panel to see if there is a toasted or foreign object near the power supply area. Its located when you follow the main plug going into the back panel of your TV. Look for a dying Fuse too. And watch out for Capacitor that has still current, you may electicuted with that component. That parts its only for qualified servicemen area only.
Aug 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
TV turns off
That sounds like a power board problem if im not mistaken where your power cord plugs into the tv there is a board it connects to often times if u plug the tv in and it starts itself or turns its self off its the power board that needs to be replaced which btw is not cheap at all
Mar 20, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
