Question about Whirlpool GHW9200L Front Load Washer
Whirlpool Duet not spinning. motor, or ??
I have a whirlpool washer that i picked up used. Upon testing, itwouldn't spin/agetate/ anything involving the motor. Got an error F06.Tach sensor or something similar. After doing some internet research, iwas led to believe it was the MCU. MCU is now replaced. Now, i can hearwhen the motor tries to kick on, but it never kicks over. (you knowthat faint high pitched noise you hear from a TV or monitor when its on, buttheir is no noise in the room?? thats the noise). I can see the drum hub and motor pulleys wiggle back and forth very slightly as its attempting to start.
I can turn the motor/hub pulley fine in both directions, with minimal effort. When I hearthe noise of the motor trying to start, if i reach back and give that"hub pulley" a little jump start by hand, then it will work. however, it will onlyfinish the high speed spin cycle. any lower speed spins or agitationcycles, and it will work momentarily, and shut back off. atwhich point it needs my assistance again to get started, or error code F06 ensues after a few failed attempts.
I tested the 3 pins on the motor harness that are listed on the tech sheet with a multimeter. it says they should test at ~6 ohms. they all three tested at 6.4-6.5 ohms, so I guess that is okay. Also, since replacing the MCU, i've noted that the cycle indicator LED is flashing (the one the main dial points to). I don't believe it was blinking before the MCU was replaced. I can still select and start cycles, however.
any help is appreciated, as I am stumped, and most definately not an appliance mechanic! ...and sorry for the exceedingly long post!
  • murraywp Apr 24, 2009
    i was told by a repairman, i needed a CCU and Motor, the cost would be 700$+ parts and labor. more than a new washer, motor works fine, except @spin i get the f 06 error and it shuts down,
    all help is appreciated
  • 15,935 Answers
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Whirlpool Front Load Washer (LHW0050PQ) not spinning
Use a quarter inch nut driver to remove the bottom panel. A tech sheet should be under there that will give diagnostics. Open the pump filter and check for objects.616c06e.jpgea4423e.jpgfb90284.jpg
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet gets to the spin cycle and gets to the super, fast speed and starts to shake Is there anything I can check before getting a repair person involved?
is it on a pedistal? pedistals tend to male it worse due to the raised center of gravity.
make sure the feet are adjusted correctly and is sits squarly on the ground. Is it new? did whoever installed it remove the bolts that are installed for transportation?
Feb 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet spin cycle problem
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the MCU
Check the Wire Harness
Feb 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
When agetating th washer makes a cicking noise?
It is your clutch that is on the motor is bad. Your clutch controls the motoro in order for it spin or agitate.
Dec 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a sears roebuck hd model 92279100 it will do everything but spin. We used to be able to lift up on the agitator and it would spin, but it won't do it now.
sounds like you have a bad drive block and basket drive you will have to remove the agetator to see the drive block. under the agetator there will be 2 small peices remove those. After that you will be able to see the drive block and basket drive ears. there are 2 slots that the basket drive fit into. if there are metal shavings and it does not look flush with something. this would be your problem. spin the drum and see what happens in that area. Have you ever heard a sound like thump thump thump? when it was spinning or slowing down? please let me know how it goes
Jun 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer won't spin
Sounds like the whirling noise is the pump, pumping. Does it drain at all? Check the drive belt and make sure that it is not broken. This system uses a drive belt with a clutch system to agitate back and forth. The clutch system could be bad as well.
This might not be a cheap fix, these are the main components of the system
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet makes spinning sound but drum is not spinning.
What is the model number? To get your clothes out and the door open on that model, try unplugging it for awhile and open the door (you probably have tried that already. Some models you can take off the bottom panel and reach up and there is a little ring you can pull to open the door. (most likely) you might be hearing the pump running since it always run when spinning. If you give me the model number I can let you have the test code. You could try Pressing any key (not power or stop) hold it in for 3 seconds let go 3 seconds, press 3 sec, let go 3 sec, hold 3 sec let go. It should come up all lights on. Don't worry you can't damage anything in the test mode. Watch what it says. then press that same key about every 30 seconds to advance it. It's kind of hard to explain but I'm trying my best. It should at least unlock it in the process. Good luck
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9200L Front Load Washer Logo
138 people viewed this question
Dan Webster
Dan Webster
Sal De
