Logitech usb headset A-0374A does not play
My logitech usb headset A-0374A played 2 or 3 times. Most often it is not recognized by Windows when I plug it to the USB drive.
  • 7 more comments
  • jromeroperu Feb 01, 2009
    I have the same problem. Suddendly my Logitech headsets are not working anymore.
  • Anonymous Feb 22, 2009
    same problem....except it will work for like 30 seconds but then it stops and even though the computer volume says it is going through the device, it does not make any sound :-s
    i plug in the headset no sound. speakers still work and the volume control on the headset adjusts the external speaker system
  • Anonymous Mar 13, 2009
    Same problem...
  • unterron Mar 19, 2009
  • paniolo39 Apr 01, 2009
    Same problem here.
  • Anonymous May 02, 2009
    logitech itself sucks
  • leesajk May 18, 2009
    Same thing.  I thought my cat had chewed thru the wire or something, but its intermittent, and if you reboot it works for a few.  Also it took over my speakers and I have not reinstalled them.   I have Vista HOme basic addition, and was trying to look up drivers as my laptop states it can not find it or there is a malfunction with the drivers.
  • Zyant May 11, 2010
    If ure running on Vista than ure going to have to go into control panel and shut down all other sound devices, speakers, everything through device manager. Afterwords restart your computer so the changes can take effect. your headset should be working
Probably need to set the Logitech headset as your default device in Control Panel-Sound. XP or Vista updates may reset the audio-video default devices
Posted on Feb 25, 2011
2 Suggested Answers
graemevm
  • 519 Answers
SOURCE: my logitech usb headset A-0374A played 2 or 3
Have you tried uninstalling and reinstalling the drivers for your headset?
Also check in your device manager to make sure all USB ports are okay (with no yellow dots next to the listed port)
Let me know if this helps or not.
Regards,
Graemevm
Posted on Apr 25, 2009
When i plug in my logitech headset whitch is usb plugin the music plays go over the headset.But when I unplug the headset music does not play over the speakers.How do I fix this so it playes over my...
Start - Control panel - Sounds and Audio devices - Click on the "Volume" tab. Check that the device volume is included in your volume control (Advvanced - Options - Properties)
Also check your speaker Volume and Settings.
May 16, 2010 | Microsoft Windows XP Professional
ClearChat Pro USB headset asks for driver upon install
  1. (Vista) Confirm your system restore point first. It needs to be prior to what you're going to attempt here. If it has a recent restore point, great, but if not, make a system restore before you do this, in case it doesn't work.
  2. In the Control Panel, click System, Advanced System Settings, click System Protection, and click System Restore.
  3. (Optional) Try updating your usb drivers before trying the final step, reinstalling the Vista Service Pack 2.
  4. Here's how to verify if your USB (drivers) in the Device Manager are up to date.
  5. Open the Control Panel, System, Device Manager.
  6. Open the Universal Serial Bus controllers (usually at the bottom of the device list).
  7. Right-click, on your first USB, Updating Driver Software. It will look for the update or let you know (which may take a bit of time) that it is up to date already. Repeat this process on all the USB devices.
  8. If that doesn't work, try this: plug in your headset, and keep it plugged into the usb.
  9. In your Windows Updates, re-install the Service Pack 2. After Vista reboots your computer and finishes the install, unplug your headset from the USB and then replug it in. What you are likely to see is a Windows message indicating that it sees the software and is installing it (minus the windows pop-up message of "where's the driver disc for it?").
  10. Now the trick is to get the headset to play the microphone through the speakers appropriately!
Oct 20, 2009 | Logitech ClearChat Pro USB Headset
USB Device Not Recognized...
Your headset is faulty. Open it to check for loose wires.
May 28, 2009 | Logitech ClearChat Pro USB Headset
Regards,
Graemevm
Apr 25, 2009 | Audio Players & Recorders
Logitech clearchat pro
The headsets are defective. I believe the manufacturers warranty is 2 years.
Mar 30, 2009 | Logitech ClearChat Pro USB Headset
The main reason for getting this message is that the USB chip or part of the connection to the chip has failed. The best way to test to see if the product is defective is to try it on another computer.
This will tell you if the product or the computer port has failed.
Sep 14, 2008 | Logitech ClearChat Pro USB Headset
USB Headset mM/N:A-0374A mic problem
I get a problem when gaming all the sound of the game is on the outside of the map and its not with the sound properly
Jun 01, 2008 | Logitech 980374-0403 Consumer Headset
Logitech headset usb A-0356A
Ok, here is what might help, goto control panel, sound and audio devices,then audio. click the pop down list and see if it is there, that is how i got my plug and play to work on my 250....
Nov 13, 2007 | Logitech 250 Headset
Check to see if the headset plugs are into the right port. If you still have problem let me know of your operating system: » Microsoft Windows Vista » Microsoft Windows XP
Oct 06, 2007 | Logitech 250 Headset
5,757 people viewed this question
 Grubhead
Grubhead
