Question about Kenmore 64852 Electric Dryer
It starts and runs for about 20 - 30 secondds then stops
The problem that I am having with my 2 year old kenmore is that it would run for about 20 -30 seconds then shut off and I cant turn it back on for about 5 minutes when I hear a click. Then it does it again. I have check for lint to see if that might be the problem but it is lint free. I got another dryer. It is another brand all together and it is doing the same thing that the kenmore is doing.
  • heartha Apr 17, 2008
    i have a kenmore electric dryer model #110 69902890 it would run for 20 or 30 minutes then turn off. i have cleaned and checked all vents and have cleaned everything inside. right before it shuts off it starts to hum loud. i will try to run it with out the vent in back also
    Scholar:
  • 76 Answers
Pwolf, looks like the problem you?re having is not with the dryer. The vent line is probably clogged up, which caused the dryer to overheat. The hi limit thermostat opens up which shuts off the dryer. After it cools down and closes, you are able to restart the dryer. To make sure this is a vent problem, you can disconnect the vent hose behind the dryer and run it for one load with it disconnected. If it runs fine, then the vent line needs cleaning. Usually it needs special equipment and is very hard to do yourself. It would cost you around $90 to get a professional out to do it for you. If it doesn?t run with the hose disconnected, then you have to provide the complete model number, which is located on the door frame. Gendos....post back.
Posted on Dec 14, 2006
I have a Kenmore 600 dryer, gas. It is about 2 years old. There is power but the drum spins intermittently. It will spin once or twice, make a thumping sound then stop. It sort of just happened without...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Kenmore 600 7962 Dryer
10 year old top loader, stops midway thru cycle
turns out it was the opening and closing the lid while trying to get it to run again. I placed a screwdriver in the hole on the lid sensor deal and it kept running so I order a new stinger or what ever you call the deal on the lid that goes in to the hole. I was going to order a timer until I read your emails on your web site..saved me a lot of money. THANKS
Sep 05, 2009 | Kenmore Washing Machines
My Kenmore Elite Oasis He Washer model #110.2706 will not fill with water. I have checked for blockage in the water lines and they are clean and clear. The washer is only two years old. It will hum like it...
Your fill valve needs replacing. Not too expensive to change. This is all based on the fact that you have checked both feeds to the washer hook up and that the shut off lever is fully open.
Jul 29, 2009 | Washing Machines
Dryer runs then stops.
IF LESS THAN 10-YEARS OLD/CHECK THE TUMBLER BELT AND BAND.IF 10-YEARS+ REPLACE YOUR MOTOR OR BUY A NEW DRYER.***ALSO UNPLUG THE DRYER AND MAKE SURE ALL YOUR WIRES ARE TIGHT.
Jan 17, 2009 | Kenmore 74602 Gas Dryer
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
Freezer stopped working
A no power to the compressor is a good sign as far as being repairable is concerned. Locate the temperature control. Unplug the freezer and jumper the two main wires that connect to the control. Plug it in and if the unit runs replace the thermostat.
Jul 04, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Open Questions:
My Kenmore 80 series dryer (64852) develops a buzzing sound while drying. Functionally it works just fine. However, after about 20min (this varies) of run time the dryer will usually begin to buzz. The buzzing seems to come and go for a short while and then becomes more constant. Then about 10min (give or take) before the dryer shuts off, the buzzing usually stops. It doesn't seem to matter what setting the dryer in on. (e.g. "Timed Dry", "Automatic Moisture Sensing") Often times when the dryer begins buzzing I can turn the dial back a bit and the buzzing usually stop for a short time. But it seems to pick up with the buzzing again before the dial reaches the same point where it began the first time. Also, because the buzzing remains fairly constant, and I get the impression that the thermostat is cycling things off and on like it should, I don't really think that this is an issue related to the heating element. Although I've been known to be wrong before. As far as I can tell it does have something to do with heat though, because the buzzing only seems to start after the machine has had time to run and warm up for a while and then stops during the last 10min when I assume the machine would be cooling down. Also, I keep the "End of Cycle Signal" in the OFF position all the time. When I have turned it on in the past it sounds distinctly different from the noise it make while drying. One more thing. The buzzing doesn't sound like vibrating parts to me. Thanks for any help you can give.
Oct 30, 2010 | Kenmore 64852 Electric Dryer
Kenmore 64852 Electric Dryer Logo
907 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
