Question about Frigidaire Affinity ATF7000E Front Load Washer
My washier keeps saying e-20
I have tired everything does any one know what e-20 means
  • 1 more comment
  • Anonymous Nov 23, 2008
    my washer is giving me the e20 error. what is it.? what do i do about this?
    and how much to repair is? this washer is just a year old today. judy peer
  • Anonymous Dec 01, 2008
    i have the e-20 error keep coming up...How can this be fixed? After it is filled with water I get the error. Could I please have a solution asap?
    Thank you!
  • Anonymous Dec 08, 2008
    I have the same E20 problem. The machine shows E20 and stops running mid cycle. I can press the start button again and it will work but I need to keep doing this 10 or more times per wash. The washer is almost 2 years old and we had called the repair man in once before. They want to charge $75 just for the visit. I think this sounds like a problem with this model.
Had the same problem. The service company said it is an internal error in the control board.
Posted on Nov 21, 2008
I have a rwd chrysler 300 2006. I wanna put 20 inch wheels on it but I don't know the correct offset. Is +20 mm offset okay? Will it fit good?
hard to answer without knowing what tire profile and rim width you will run, just saying 20 inch doesnt say much.
Sep 22, 2014 | Cars & Trucks
I have a 2005 nissan sentra. Tire size is 195/60 R15. I have the chance to get 2 195/65 R15 tires at a good price, and want to put them on the back, keeping the 195/60's on the front. Will this be OK? Some...
195(width in mm)/60(sidewall height in % of width) R15(rim diameter)
This means, a 195/60 R15 rides lower than a 195/65 R15 tire. Imagine how it would look like when you put these different tire sizes on one car. It can be done but the car will be unbalanced both mechanically and aesthetically. Remember, your car was not designed for different front and rear tire sizes unlike some sports cars.
A 2005 model will most like come standard with ABS as with most cars produced year 2001 onwards.
Just buy 1 tire size for your car. If you wish to change to another tire size, change all the tires.
Feb 21, 2011 | 2005 Nissan Sentra
Keep getting a message saying service tire system soon. I just had new tires put on and all four sensors replaced. Firestone store says there is nothing they can do. Any suggestions?
There is a special tool needed to reset the TPMS on your vehicle. The Firestone store may not have it, but your local Chrysler dealer will. I hate to refer folks to dealerships for seemingly simple problems but in this case I personally know of no other option.
Feb 11, 2011 | 2004 Chrysler Pacifica
2007 suburban dash is saying stability system disabled what does this mean ?
{: ) Check for excessive wear on any of the tires on the vehicle and then verify that all the tires are the same size, brand, and same model. It is also important to check and make sure the tire pressure is properly adjusted per the sticker on the door. The following examples listed below could cause this condition:
1. 2 tires on the vehicle are Goodyear P245/75R16 and the other 2 tires are Firestone P245/75R16
2. 2 Tires on the vehicle are brand new and the other two tires have excessive wear.
3. 2 Tires on the vehicle are Goodyear Wrangler SRA 265/70R17 and 2 tires are Goodyear Wrangler HP 265/70R17 (Same brand/different models)
4. Aftermarket Wheels and Tires (NON-OEM 20 inch wheels and tires)
5. Tire pressure is not properly adjusted.
Jan 27, 2011 | 2007 Chevrolet Suburban Three-Quarter-Ton...
My hoover washier dryer has stopped heating up. I works ok as a washing machine but the tumble dryier doesnt heat up. It is a hoover vhw654d washier dryier
on all dryers you have a hi and a low relay as well as the heater and in some you even have a run tstat check that you have continuity on each side of each of your relays as well as your heater any of these pieces that does not have continuity would be the one that u wuld replace hope this helps if you are not electrically inclined plz call a technician
Jul 21, 2010 | Hoover Dryers
Washier problems
Check pump belt or restriction or kinked hose
Oct 21, 2009 | Maytag PAV2300 Top Load Washer
I have a 2005 nissan pathfinder, and a light just came on , it's a set of parentheses with an exclamation point in the middle, what does that mean?
tire monitors pressure is low in a tire they **** if its blinking u have a problem just keep tires inflated to 36psi or sensors wont work if that fails go to dealer low tire pressure
Sep 30, 2009 | 2005 Nissan Pathfinder
2007 yukon TPMS keeps on blinking after everything has been check
unhook the battery for 20 min hopefully this will rest the puter
Sep 11, 2009 | 2004 GMC Yukon
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Frigidaire Affinity ATF7000E Front Load Washer Logo
64 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
