Question about KitchenAid 32685 Mixer
No Power to Mixer
When it did work the motor worked but it would not mix. Removed side screws where the brushes are and now it won't start. Did I screw something up? Please advise.
Thanks. I was mixing pasta dough and it started smelling of smoke. It was running but sounded like something was missing.. I unscrewed the two big inset screws on the side, noticed that I couldn't see anything past that, put it back together.. now no power. :( What did I do???
    Scholar:
  • 181 Answers
Any of the part in your mixer wass burning as it was getting short and so you ver getting the burning smell .as in few minutes the mixer was going to become completely OFF due to that.as if at that same time if you have opened the mixer apart and checked out on the circuit board it would be easy to locate the faulty thing.but you unscrewed the mixer and then when you did nou understood any thing what to do further you just screwed it properly again .and again ON the mixer but this time the part which was short could not handle the electric current and got completely OFF.u just take it to the repair center and get it repaired as this is a common problem for this electric appliances.and it will be not at all costly to get it repair.this problem occurs due to moisture collected in the mixer circuit area or any water particles came in contact with the mixer and got the board short.
thanks.
Posted on Nov 19, 2008
  • 4,806 Answers
You did nothing wrong, the motor has burnt out ( thats the smoke you could smell )
kind regards
    Sergeant:
  • 276 Answers
Check out if any of the sensors on the area of the brushes is moved from its orignal position.
Can I buy new parts for the two dime-sized screws' inners? I removed them nd now the mixer wont work.
What you are describing is the two side screws on the side of the mixer motor head. Yes you can buy all new parts for whats behind those screws or you can just buy new "Charcoal" thing...which are called "The Brushes" If you buy new parts off ebay or from Kitchen Aid you will have one very small concern. There are four different ways to insert the brushes back into the machine but only one way will make the machine work right or work at all. The brushes are spring loaded into the machine the screws caps keep them in and pushing them forward, the brush end rests on the commutator portion of the armature (The Motor) and when the brushes do not touch that portion of the motor the machine will not work at all until they are put in the machine correctly. You will notice on the brushes that one edge is beveled, inside the brush holder is a small metal clip/piece that has been bent up and into the brush holder space, the beveled edge must go in so that it will slide past this bent metal, if it is inserted incorrectly then the metal piece will hold the brush off of the comutator and the electric feild will not create the spark / energy needed to operate the mixer. If you want to replace all the parts associated with the brushes and brush holder you will have to do a FULL tear down of the machine in order to get at the set screw that keeps the brush holder tube in place, and to do that you will have to take the machine entirely apart. I hope this helps. If not; get back to us with more info on the problem and we will FixYa
Oct 07, 2014 | KitchenAid Classic Stand Mixer
I took out the two black flat screws on the side of my KitchenAid mixer and out sprung a spring and magnet. When I replacter them my mixer won't start...
It sounds like you removed the brushes, look in the hole and determine the orientation of the carbon brush( what you describe as magnet). Rotated 90 degrees may keep motor from running...
Mar 12, 2011 | KitchenAid KSM150PS Artisan Series Stand...
My k5ss mixer will not start ,I remove the 2 screw on each side of the head, i put them back and now it wont start
Hi DENAULTR, I hate it when that happens. Those two “screws”’ are your mixer’s electric motor brushes. The slotted black threaded plastic parts are just the Brush Holder Caps and are the protective covers to the brush holder assemblies. They allow access to the brushes when they need to be replaced without having to take the whole mixer head apart.
From what you’ve described, I suspect that one or both of the brushes is (are) not seated properly when you reinstalled them. The brushes need to be installed so that they both seat correctly on the armature's commutator or you won’t get any ‘juice’ to the motor. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the part names and numbers. Locate Illus No 47, Brush holder assembly that includes Illus. Nos. #28, 32, 33, 34, & 46, and Illus. No. 29, Brush & Spring assembly respectively.
The Parts List illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Feb 26, 2010 | KitchenAid K5SS Heavy Duty Commercial...
I unscrewed the rubber "screws" on side and now I have no power
Hi CURIOUSHBGEO, I hate it when that happens. Those ‘rubber (plastic) “screws”’ are your mixer’s electric motor brushes. The slotted black threaded plastic parts are just the Brush Holder Caps and are the protective covers to the brush holder assemblies. They allow access to the brushes when they need to be replaced without having to take the whole mixer head apart.
From what you’ve described, I suspect that one or both of the brushes is (are) not seated properly when you reinstalled them. The brushes need to be installed so that they both seat correctly on the armature's commutator or you won’t get any ‘juice’ to the motor. See the illustration below: c8a97bc.jpg
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the first file K45SSWH0.pdf (341.41 KB) listed under Parts List (1) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 32, Brush holder assembly that includes Illus. Nos. #18, 21, 22, 23 & 31, and Illus. No. 19, Brush & Spring assembly respectively.
Feb 24, 2010 | KitchenAid K45SS Classic Stand Mixer
I have a classic k45sswh kitchen aid mixer. I removed back cover and replaced and now it does not start.Then removed brushes and must have put them incorrect but still it don't start. I notice a angle on...
Hi TRADESGIRLS, you are correct, the brushes have to seat correctly on the armature’s commutator or you won’t get any ‘juice. Unfortunately, the ‘screws’ on the sides of the mixer are just the Brush Holder Caps (brush cover), which allow you access to the brush holder assembly and has nothing to do with ‘adjusting’ the brushes. From what done already, still I suspect that one or both of the brushes is (are) not seated properly.
The brushes need to be installed so that they both seat correctly on the armature's commutator. See the illustration below:
Feb 03, 2010 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K5sswh mixer after replacing plastic gear-no power
Hi COVINIO. Yes, the "large black spring loaded magnetic screws on the sides of the mixer" are your mixer's brushes, which supplies electricity to the electric motor. (The black cap is the brush cover). I suspect that one or both of the brushes is (are) not seated properly. Did you remove the brushes to replace them or were you just inspecting them, when you replaced your plastic worm gear?
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 47, Brush holder assembly that includes #28, 32, 33, 34 & 46 which is the brush holder insert, and Illus. No. 29, brush & Spring assembly respectively. The illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
Jan 29, 2010 | Food Mixers
Took apart, pull magnets from sides, now the thing
ECARRERO2004 - Those 'magnets' you removed from the sides of your mixer are the electric motor brushes that provide power to the commutator/armature assembly so your motor runs. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the commutaor. The concave contact face should be resting completely on the comutator. If you've turned it 90 degrees too much, it wont' seat properly and you'll get no 'juice' to the electric motor so it won't start. I hope this helps - Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
Nov 24, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
I have disassembled my K5SS Kitchen Aid mixe with all gears removed in order to solve its electrical problem. When I plug in the motor and move the speed lever, there is no movement or sound of the motor...
Unless it sits at the back of the motor behind the vent cover. I couldn't find one anywhere on ours either. Check the motor brushes for broken or badly worn carbons, or collapsed springs. It could be a broken wire at the plug end or something wrong with the speed switch. Some strategic voltmeter sleuthing is required. Try turning the motor shaft while the power is on. It may have a dead commutator segment.
Aug 25, 2009 | KitchenAid K5SS Heavy Duty Commercial...
A-200 mixer brush carrier orientation.
Hi. I can't help you with your first question...But I can help with your brushes problem. Unplug the mixer With the two inspection plates removed at the commutator end loosen the two screws of the brush holder which are above and below the motor bearing cover, they're the only larger screws now visible. Note the markings on the brush holder on the bottom right side where you removed the inspection plate. Rotate the brush holder to the other mark. Set the brush holder screws. Plug in the power. and start the motor. It should now be turning in the proper direction, if not, make small adjustments by loosening the set screws, and moving the brushes until it starts to your satisfaction. Be sure that the set screws are tightened when you're done. If you need further assistance, post a clarification.
I have the same spec. mixer as you do.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 30, 2009 | Hobart A200 Stand Mixer
No Power to Mixer
If the motor worked prior to removing the brushes you most likely installed the brushes incorrectly. Remove the brushes and using a flash light look in the brush holder on the mixer. You will notice a small tab at the very end. That tab will prevent the brush from coming in contact with the motor armature if installed incorrectly. Clock the brush so that the angled side lines up with the tab and you should be back in business. Also if you are installing the original brushes use the wear marks to determine which side the brush came out of.
The original issue you had is most likely the nylon gear that is talked about in other posts on here.
Good luck
Nov 18, 2007 | KitchenAid 32685 Mixer
KitchenAid 32685 Mixer Logo
103 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
