Question about Pioneer Premier DEH-P960MP CD Player
Face plate doing the same.
My player just started doing the same thing this morning! Freaked me out at first. All I can do is hit the reset button while it's shut, then turn it on and still listen to tunes, but can't change settings or open the screen at all. I've never even taken the face plate off and I've had it for three years. Seriously, someone needs to figure this out.
  • swod Dec 13, 2007
    deh-p6400r fascia just blue lines down where can i get it fixed or?
  • markie_d2003 Jun 25, 2008
    i have the same problem face plate will not operate.i think the ribbon cabe needs to be replaced
  • 34 Answers
The ribbon cabe needs to be replaced .pioneer part # is cxx1799
Posted on Jan 09, 2009
  • 78 Answers
It needs a flexible pcb (the one that connects the face to the main board) it's a common fault on these units, you see every time you power the radio the fascia rotates and therefore flexes the connector and after time the pcb starts to break some of the connectors. If you feel confident enough the flexible pcb's are not too difficult to replace if you can get a replacement.
Posted on Dec 12, 2007
No sound or lights
make sure the yellow wire has power all the time and the red wire has power when the key is on. Most likely you do not have power to the red.
May 19, 2010 | Boss 506CA CD Player
My 9855 alpine will work when you take the face off / and put it on but the buttons don't work but you can control it with the remote,and when you hit the eject the face wont come down and it wont eject a...
had the same problem with my alpine, i was able to fix it once by, popping off the face plate and with fine grit sand paper (lightly) sand the connection points on the radio and the face plate, then put a little bit of dialectic grease on it . also doing a reset on the unit helped me from time to time...
May 02, 2010 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
Wont turn on
  1. go over all the wiring and make sure nothing came loose.
  2. find the reset button usually behind the face. reset the radio.
  3. make sure the face plate is completely on the head unit.
Dec 23, 2009 | JVC KD-R200 Car CD/ MP3 Player
When I hit the 'open' button the face continues to cycle
ribbon tape sounds bad. it goes from the units main board to the detachabel faces rear mounting plate , u can inspect it for cracks , most of the time theyre visibel from looking under the unit while face is open
Oct 17, 2009 | Pioneer Car Audio & Video
Display on kdc-mp638u not working
These units are pretty cut, and dry.. Basicly the only thing you can check for yourself is connection. If the connection between the face plate, and the deck is good, and tight then you have one of 2 problems.
1) Bad face plate. Fix= $90-$130
2) Bad connection to the board on the radio Fix $60-$120
There is however a VERY off chance the processor is jumbled up, and wont cost you a dime to do a cold reset, so give it a shot.
To reset this unit simply remove the face plate, and locate the rest button. It is very small, but easy to find. Just use an ink pen or something of similar size to push the button.
Aug 07, 2009 | Kenwood KDC-MP638U Car CD/ MP3 Player
Replaced my battery noew my pioneer cd player won't work is there a reset button?
pull your face plate completely off, look for a small indented hole that you can fit the tip of a pen in. note(its not on the back of the face plate) on the actual head unit. make sure while doing this that your vehicle is started or at least in acc position
Aug 05, 2009 | Pioneer DEH-P4700MP CD Player
I have a dual xdmr7700 stereo and lost the manual need to get the face plate off
Same problem as yours with my deck. Bought the deck a month ago, turned car on in the morning face plate does not move down, music plays everything ok but can not access the cd or move the plate regadless button pushing.
Have you tried the reset button? Hold it for 3 seconds ( ball point pen to press the button above power button) U will lose the presets but Oh weel.
I am going to remove power completey from the unit later on today, and if it still has issues I am returning it for a replacement ( Bought it form Best Buy)
L8R
Nov 09, 2008 | Dual XDMR-7700 CD Player
LCD screen
take the face off and press the reset button -if this does'nt correct the problem remove the power harness for about a minute or so put the plug back in and try again-if this does'nt help send me an e-mail at merle840@aol.com
Mar 27, 2008 | Virtual Reality VRCD500-SDU CD Player
Buttons!!! Nothing happening
try to do a reset.  usualy behind detachable face plate or on hide away unit.
Oct 08, 2007 | Clarion VRX755VD Car DVD Player
GARMIN STREET PILOT C330
take off the front face plate. hit the reset button on the right. charge it. I've got a 320. Same thing happened. On the 320 if you look closely there is a fingernail shaped indent on the inside of the square colored face plate. just pull the face plate towards you and it will come off with very little effort.
Feb 20, 2007 | Garmin StreetPilot C330 GPS Receiver
Pioneer Premier DEH-P960MP CD Player Logo
125 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
