Question about HP Office Equipment & Supplies
RE: hp officejet 6110xi all in one: The light bar appears to be stuck on the right side of the scanner bed and it will not move. Prio to a power interruption the machine was working. Now when the computer is turned on the machine makes a grinding noise. The printer/copier etc. will not work. This happened once before and the tech was able to tell me how to correct the problem. I have already unplugged from the surge protector and replugged. Can no remember the rest of the procedure.
5 Suggested Answers
SOURCE: HP LaserJet 3330
Remove the small glass pane of the left side of the scanner bed. You onlt need to remove one screw. Push the driver belt which will move the scanner to the left. It can be a little tricky to move the scanner the last little bit so you may need needle nose pliers or someone with a hook (I used a fork) to pull the scanner last little bit. Once the scanner is in the open spot where you removed the glass panel, simple take a q-tip and clean the mirror.
I did this and my machine is working just fine.
Posted on Feb 10, 2008
  • 106 Answers
SOURCE: scanner failure hp 6110 - Noise and stuck head
the error message refers to the hardware issue of the printer. Below is the document that i need you to follow to somehow resolve your issue.
Please let me know if the document that i gave to you resolves your issue.
thank you so much.
Posted on Jul 21, 2008
SOURCE: installing hp officejet 6110xi onto my laptop
Hello Angel,
How are you doing?
Here are the links to download the software for your All-in-One.
If the operating system is Windows 2000 than use the link below:
If the operating system is Windows XP than use the link below:
How ever a full feature software and driver package for Windows Vista is not available for your product. But still you can print ,scan. Click on the weblink below for more information:
Thank you. Best of luck.
Posted on Oct 25, 2008
  • 121 Answers
SOURCE: HPcolor laserjet 2840 clicking with message "scanner bulb warming
Removal instructions:
1) unplug everything and move the unit to where you can work on it.
2) Remove the paper, and remove the hinged lid (tilt the lid to the up position and lift directly up and off).
3) Remove the push button cover which lifts directly off - straight up.
4) At the top of the button control module is a recessed release clip. Use a flat blade screwdriver and push down on the clip. While pushing down, slide the control button assembly down. lift the outside edge up (there are straight clips on the inside edge). Lift up slowly as the connection cable needs to be unplugged. the cable itself unplugs. Just pull down evenly grasping the top blue laminated section. The blue goes to the outside (contacts go to contacts on the inside). Set the button control unit aside.
5) Using a #10 Torx screwdriver, loosen the two screws in the back corners of the glass cover assembly. Lift the glass assembly up (like changing an ink cartridge), and pull the front lip left and right forward - there are two clips at these locations. Pull forward and lift up. Remove the glass cover assembly off and set aside. Note, tip over and remove the scews (best to remove and put back in after the cover is back fully in place). In reassembly, be sure to feed the control button cable back through the hole, and that it goes back into place the way it came out (including folding back into the slot under the button control assmebly).
6) The black plastic cover has two metal clips visible. These are not the release clips (they hold a glass piece in place under the black plastic cover). The release clips are outboard of these metal clips and are two slots. Insert a small flat blade screw driver, and push the handle toward the center. While prying, lift the cover at that end up, pry the other end and lift the black plastic cover off.
7)While you're in there, you might as well clean the mirrors (THERE ARE FIVE OF THEM)and glass. At the front of the lamp on the botton, the lamp wires lead to a white two piece plastic connector. Unplug the lamp wires. Where the lamp is, toward the front is a black philips screw in the clear plastic piece that holds the front end of the lamp. Remove this screw, and lift the clear plastic piece with the front end of the lamp up slightly, and then pull the full lamp assembly forward and out. This will open the space to the mirrors and glass. Use a Q-Tip and small pieces of paper towell and glass cleaner to clean the mirrors and glass strips. I tried to remove these to clean them, but the metal clips were too tight.. better to clean it all in place. BE SURE TO CLEAN THE EYE!!!!!
8) Clean the bottom of the glass top assembly.
9) Reverse the above to reassemble. Be sure to plug the lamp back in, and the button control assembly. Leave the black plastic cover off.
10) Place the glass top assembly back in place, and snap it down before dropping the screws in the back holes.
Don't know why, but you should be good to go.
After doing the above if in a few weeks you get the same msg again go back in there and take the black top off the housing that the mirrors are in and leave it off!!!! sound crazy but it has been working on a lot of the machines that come in here.
Posted on Jul 13, 2009
Officejet 6310 makes noice
Lift the Flat Bed Scanner up so that you can find the Cartridges Inside.
Remove the Cartridges from the Printer.
Move the Cartridge Carrier Back and Forth as fast as you can!
Replace the Cartridges back to the Printer!
Good Luck!!!!
May 14, 2013 | HP OfficeJet 6310 All-in-One Printer...
My HP Officejet J4580 All-in-One scanner does not work. Whenever I would turn on the printer, the scanner head (or what ever the thing with the light is) would start "clicking" and not move from...
1. Too much friction while moving the optical scanner unit.. Open the flat bed scanner lubricate the rail
2. Optical scanner unit faulty,remove the scanner unit open it gently, clean mirrors in side the unit with ear buds re-fix & clean the flat bed mirror neatly especially at home position.. re-fix as it is then check..I suggested this activity for only tec guys..
Sep 10, 2011 | HP OfficeJet J4580 All-In-One Laser...
Clicking sound from the scanner that won't stop
If it's coming from the scanner I'm guessing that the gears are grinding the wrong way and will continue to deteriorate. Safe bet is to have it checked w/ HP or at least have a technician take a look at it.
Nov 12, 2008 | HP OfficeJet 6110xi All-In-One Thermal...
Scanner failure hp 6110 - Noise and stuck head
thank you so much.
Jul 19, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Clicking nosie from scanner bed on epson cx5800f
I had a similar problem, the scanner bar was stuck to the far left side. Here's how I fixed it:
1)Unplug the printer, disconnect any cables/phone lines to it.
2)Lift up the entire scanner bed housing(you will see the printer ink cartridges).
3)Locate the access patch (approx 1 cm x 1 cm square) along the left edge of the scanner bed housing(this is the side that closes in, next to the keypad buttons).
4)Using a small knife blade, peel off the patch from the corners and edges(it's sticky. Save it, you can stick it back over the hole when you're done).
5)Stick a pen through the access hole, and push the scanner bar to the right, approximately 2-3 inches.
6)Now, close the scanner housing, plug in the printer, and power it on.
It should reset and re-calibrate the scanner bar. If it doesn't, repeat steps 5) and 6) a couple times, until the printer correctly performs calibration. Then, you can put the sticky patch back over the hole, and you're ready to go. Hope this helps!
Jun 28, 2008 | Epson Stylus CX5800F All-In-One InkJet...
HP Officejet 6110 scanner carridge appears stuck
Unplug the power. Plug back in, while simultaneously holding hash (#) and (6) buttons, until S-reset is displayed (sometimes this can take like forever) but it is a documented HP mode.... Then set up machine using 1 key to confirm options and arrow keys to select options.
To enter another maintenance mode (fat lot of good that will do you), press and hold * and #, then press 1 and then 2 and then 3 (or 5) for a variety of different options, which include testing of the scan bed. This of course only works once the scan bed has initialised...
Or: take out all cartridges and close doors. Wait until it complains, or indicates a cartridge jam.
Oct 20, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110xi All-In-One will not print
Presuming you're using a usb connection, try changing the cable with another just to ensure the cable's not defective. If that doesn't resolve your problem, try the following: Right click on My Computer. A window titled System properties appears. Left-click the Hardware, then Device Manager. If you're using a USB Connection, scroll down the list to Universal Serial Bus Controllers and Click the "+" to open the list. Your printer should appear there. Right click on the name of your printer click "uninstall". Do the same if you see any red or yellow markings on any of the other USB controllers. Then restart your computer and Windows Plug & Play will reinstall the drivers. Update your software and drivers from HP's website.
Oct 06, 2007 | HP OfficeJet 6110xi All-In-One Thermal...
Ben Johnson
