Question about Reddy Heater-30-55,000 BTU Variable
Reddy heater won't stay on
I have a kerosine type reddy heater 55,000 btu. i plug it in and it starts and has heat but only runs for about fifteen seconds. it will keep repeating this as many times as I plug it in. i had real old kerosine in it the first couple of times i started it i'v emptied it and put fresh kerosine in it. i'v tried starting it about a undred times and it just never stays on.
  • 6 more comments
  • wrivera40 Nov 20, 2008
    I think model 55
  • rrichardson Dec 21, 2008
    Reddy Heater Model M50A, 50000BTU. The machine will start and fire ignites. The machine will blow heat but flames out in about 5-10 minutes. The cloud and fan keep running w/ no flame. If I unplug it and replug it in it will repeat the process.
  • Anonymous Dec 30, 2008
    The same as above
  • mromenesko3 Jan 02, 2009
    I have a ready heater 110 and it does the same thing worked great then started this out of the blue
  • geaver1 Jan 04, 2009
    Have an RM60 Kerosene Heater. Inconsistant performance. Initially, ignitor would glow, fan would come on, (briefly) but would not fire up, then quickly shut down. Took to a dealer, checked pump pressure, adjusted, and it worked fine, (For about 20 minutes, then it shuts down). Same problem as above. Did a complete tune-up; filters, ignitor, etc.
    Any suggestions? (Note: had the unit back to the dealer twice, bring it home, it works great, then reverts back to aforementioned problem(s).
  • Anonymous Jan 06, 2009
    ignites, fan blows but flame only lasts for 20 sec to a minute
  • Anonymous Jan 14, 2009
    heater starts runs for about 5 seconds
  • davidandsons Jan 16, 2009
    reddy heater lights and runs for 5 sec. then stops. have taken apart cleaned, still same, mod. #r55a ser. #5126137
  • 35 Answers
Did you check the plug. If it is fowled or the plug is not gapped properly it will not fire or run efficently and will shut off.
Posted on Jan 13, 2009
  • 232 Answers
What is the model number? Could be a number of things, depending on which technology is used on your particular 55,000 btu heater.
Posted on Nov 19, 2008
  • Jerry Magee
    Jerry Magee Nov 21, 2008
    You're going to have to actually look at the heater, copy down the model number, then reply here on Fixya. There are many 55's. 2 different technologies, different troubleshooting tactics.
Have a Reddy Heater 55,000 BTU unit, when plugged in it will run for about 5 minutes or so and then shut off.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 11, 2011 | Reddy Heater-30-55,000 BTU Variable
Reddy heater 60000 btu kerosine heater
it either has too much fuel or not enough air. you will have to adjust both to figure out which is the culprit
Dec 12, 2009 | Reddy Heater 60,000 BTU Kerosene...
Lights and runs for 30 seconds then goes out and trips overload switch
Check to see if the pump is leaking some where.Then clean the pump out if there is no leak.Are you burning kerosine?K 1 will give you no problems,but diesel will cause a lot of problems,some reddy heaters can burn both,and some you can not,so look at the warnings.
Oct 17, 2009 | Reddy Heater-30-55,000 BTU Variable
70,000 BTU Reddy heater - runs - but it puffs smoke
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Dec 28, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy heater pro 110
Need parts for readdy Heater Pro 110 New
Jan 14, 2008 | Reddy Heater-30-55,000 BTU Variable
30000 & a50000 btu reddi heat
in the fuel line is a disk type filter see if its clogged. air compressor pressure should be 3.0 - 3.5 psi.
Dec 16, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30-55,000 BTU Variable Logo
814 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
