Question about Dryers
Timer motor keeps running on dryer
Dryer works fine, when you open the door you can still hear the timer running
  • 166 Answers
Sometimes as a timer gets older the timer motor will get a little loud. timer motors run even when the door is open. if the timer advances to off and everything works fine you don't need to worry about it.
Posted on Nov 20, 2008
Dryer will not come on at all. working fine on last load
check house fuse/circuit breaker
door switch
if an electric dryer the thermal fuse as they are often wired into the motor run circuit
check for power to the motor in start and run circuit, if present motors spent.
if not present trace back to timer and verify timer is sending power, if not timers spent.
more likely circuit breaker, door switch or thermal fuse if electric dryer..
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Kenmore 64902 Electric Dryer
Timer ticks, but dryer does not run
Sounds like door switch. Open door and push on door switch. you should here a clicking noise. If you can open the top of the dryer. put the 2 wires together of the door switch. Make sure it is unplugged when doing this. Make sure you use electrical tape when you put it together. Temp fix. Get a new switch
Oct 23, 2009 | Kenmore 62602 Electric Dryer
Wont start door shut tight can heat timer drum lite on when door open
If you can hear the motor running with door is closed and the dryer is turned on, the the belt that turns the drum is likely off the drum or broken.
If you cannot hear the anything when the door is closed and the dryer is turned on, then the door switch is likely defective.
The other more unlikely causes are either the Timer or Switch that starts the dryer is defective.
Aug 21, 2009 | Kenmore 400 6942 Dryer
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Dryer timer comes on but with door shut it won't turn on
There are several problems that can cause a dryer not to turn on. The timer running tells me you are getting voltage to the operator console as the timer runs off 220VAC. The motor, however, requires several things to working in order for it to run. The door switch has to be in working order and making contact as the door closes. An easy test is to push in on the door switch with the door open. If the light goes out, the switch is making contact. The following link I'm providing will give you some more pointers on what to troubleshoot next:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Read through the link thoroughly and make sure your dryer vent ducting is clean prior to replacing any failed components. It is essential that a dryer has proper air flow in order to operate efficiently. Some component failures are directly attributed to clogged ducting and will occur again if the problem is not resolved. Read through the section that decribes a dryer that "does not run at all". A common failed item is the thermal FUSE, which can fail due to overheating. If it is blown, it must be replaced. The component is usually white in color and made of plastic. It will be mounted on the blower fan housing inside the dryer.
The problems I mention, are the most common failures for this symptom. However, please check everything to ensure you rule out all possibilities. If you still need assistance, please let me know. I hope this helps you.
Nov 10, 2008 | Kenmore 62602 Electric Dryer
Dryer continues to run.
barnardfl
look for a cool down thermostat on the fan body. this thermostat opens on cool, and is in the motor circuit, not the heater circuit as the other thermostats are. After the timer switches off the heater and motor, this thermostat keeps the motor running until the temperature drops below ~45C, drawing unheated air through the dryer. when they fail they weld closed and do not switch off
aaaa3786
If knob does not move, there is likely a stripped nylon gear in the stepper motor for the timer
timer motors cost $~14 if available in your area, and attach to the timer body by two screws
rebuilt timers can be purchased at many parts stores, labelled as almost anybrand as many are interchangeable $~40
new timers are around $~60
Oct 09, 2008 | Whirlpool LER4634J Electric Dryer
Dryer won't stop running
The hot wire runs through the start button as a bridge to complete the circuit until the motor centrifigal switch closes the circuit when running. Now if you manually start your dryer and the timer doesnt advance keeping the dryer on until you open the door or advance the timer manually then the timer is good but the motor to advance the cam is faulted. The second scenario is that the dryer is off when the door is open, but when you close the door the dryer starts. With the second scenario we have a closed circuit at all times. At this point you have either a stuck start button or the centrifigal switch is closed. Usually it is the start button on this model.
Sep 08, 2008 | Kenmore 67082 Electric Dryer
Will not start; makes no noise
check the humidity sensor this will prevent the motor from starting
Sep 22, 2007 | Maytag PYE2300AY Electric Dryer
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
178 people viewed this question
Top Dryers Experts
Marvin
Marvin
