Question about Compaq Presario 5000 PC Desktop
Volume Jerry I have it hooked up to the tower but there is an extra plug in that comes from the speaker itself; it says 12v dc, 1.0a on the speaker where this extra cord is. I looked at the screen that it originally came from and the screen has a plug in on it for this cord. the original screen is a Compaq and the tower is a Compaq, I have just upgraded the screen.
    Problem Solver:
  • 7 Answers
Oh i see the first question was way to vauge to really answer. it sounds that this is a powered speaker meaning it requires that 12v that you are reading and wont work without it. i am assuming that the cord coming from the speaker is a male end that plugs into female if that is the case it will be difficult to find an adapter to plug into the wall as those have male ends as well. if there is a female plug on the speaker you should be able to find an adapter that plugs into the wall outlet(transformer) just be sure to match up all specs i.e. 12v 1.0a
Posted on Nov 19, 2008
  • 1 more comment
  • jerry riggs Nov 19, 2008
    hope this helps
    forgot to tell u this speaker is matched to the original monitor. all monitors do not have that
    plug on them
  • jerry riggs Nov 21, 2008
    yea ....your welcome
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
How to double check speaker hook up on asus desktop computer
maybe they have the volume muted. Check to make sure the volume is not muted and that the speakers are plugged into the light green port in the back of the computer.
Make sure the volume on the physical speakers are turned on and turned up. And make sure the volume in the Audio Sound Properties it turned up and not muted.
If you see the speaker megaphone at the bottom right near the time click on it to adjust the properties.
You can click Start/Control Panel and look for Sound or Audio properties.
May 02, 2012 | ASUS Computers & Internet
What power supply do I need for a pioneer pl-x55z turntable?
im guessing your standard plug like all turntables. radioshack or a music store should have some laying around
May 31, 2011 | Pioneer PL-990 Turntable
Our speakers worked at old business location, since we've moved they don't. one is plugged into the other and then plugged into the CPU. however when turn volume on actual speaker there is no light lit...
Yes there is. You will need to find the power adapter that went with them. It will usually be a small brick like adapter that has a cable coming off of the end of it that will only fit in your speakers.
Mar 30, 2011 | Dell A215 Computer Speakers
My Panasonic is Model# SA-ht650. The fan does not come on to cool the unit down. I took the fan out and tested it and it does work with 12 Volts DC @ 1.5 amps. Any suggestions.
For others, the fan on this model only runs with the volume turned way up, to test it unhook the speakers and play something like the radio with the volume set to 0dB, the fan should run.
Dec 23, 2010 | Panasonic SC-HT650 System
I cannot get any sound from my speakers or the monitor speakers. I have plugged the green cable to the monitor and to the green connector on the tower with no luck. I have also plugged the extra speaker...
It sound like you have connected them correctly however unless they are multi-channel speakers you should only have to connect the green cable. Check to see if the volume control on your speakers/monitor and also OS are turned up and not on mute and also check to see that you have sound drivers installed for your sound device/card.
Oct 23, 2010 | Acer Aopen MS698 Computer Speakers
Hi, I have a pair of Polk RT1000i powered towers and one now makes a constant loud humming or buzzing sound. It is not hooked up to the receiver. It does it as soon as its pluged into the wall. Any...
the volume on the speakers are too high. try to put make the speakers the master volume(whatever device you plug in into your speakers make that device's volume go all the way up and then adjust the volume on the speakers to what ever volume you desire.had the same problem with my computer speakers
Jan 16, 2010 | Polk Audio RT1000I Speaker
Do I need a battery? What is my power source?
Well first off if there is a power cord that goes in the front then it should be powered by that. Second of all you should have a power switch on the front of the speakers to turn it on and volume control.
Jun 18, 2009 | Boston Acoustics MicroMedia Computer...
Speakers need power scource
Yes, a general purpose 12V DC power adapter can be bought easily from your local electricals shop.Should not cost much.
Alternatively you can look for a cordless phone or CD player adapter with 12V DC output.
Mar 16, 2009 | Audio Players & Recorders
Compaq Presario 5000 PC Desktop Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
