Question about Zebra Stripe S600 Thermal Label Printer
ZM400 is printing my label smaller that my program is set to.
My label program is set to print to a 1"x3" (h x w) label but when the ZM400 prints the label it comes out small enough to fit on a .75"x1.75" (h x w). I have tried changing drivers on the windows server the print job is coming from but no change. The label is programed in ZPLll . I have used the same label program at many other clients, with out this issue, printing on printer models: 105SL, 110XilllPlus, LP2844 Z.
Any help would be greatly appreciated!
  • BarbB179 Mar 23, 2009
    We have formatted labels from a Filemaker program for 1.5 x 3 inches but when printing to the Zebra, it cuts off the right edge of the printing and only prints a 2 inch wide label. We have tried everything we can think of as well. It prints fine on a plain paper laser printer when testing.
  • CGA Pkg Aug 17, 2010
    Can you tell me which software you are using?
SOURCE: Zebra LP2844 printer prints garbage
Sounds like you might be using a bad driver, or the printer is in dump mode.
Try hitting the green button and see if it says exiting dump.
If still having trouble, inside the printer it tells you that if you are having printing trouble:
  1. turn off the printer
  2. Hold down the feed button
  3. turn on the printer and at the third red flash release the feed button
  4. it will then feed some pagessome info and ask you to hit feed again to exit dump
  5. hit feed again and it will say exiting dump
This process re-reads the label length (so only do it with the labels you want to use in, or it will waste labels until you do it again with those in it) - but I'm suggesting it only because it enters and exits dump mode (which I have read can cause the garbage when you try to print).
Posted on Mar 11, 2009
SOURCE: Zebra LP2844-Z - no longer prints a barcode on a specimen label
Added ''3 of 9' font to C:/Windows/Fonts.
Opened Word document, selected 3 of 9 as Font and typed a word.
Went back to printer and it printer the accession number and barcode.
Posted on Mar 31, 2009
  • 32 Answers
SOURCE: LP2844 Printing light
You should first make sure the printhead is clean. If the printhead is dirty and you crank up the darkness, you will blow the printhead elements. Open the printer and from the bottom, you will see the printhead, which has a glass like appearance. There is a green strip from one side of the printhead to the other. Take a que tip with some rubbing alcohol and wipe it clean. I would make sure the printer is turned off before doing so. Just to be safe.
Posted on Oct 27, 2009
  • 185 Answers
SOURCE: Pause between each label.
When you go to file and print the dialogue box comes up and you inptut the amount of copies required, uncheck the Colate box just under the amount of copies required. This will allow each print to come out streamed no paused.
Posted on Oct 29, 2009
SOURCE: zebra lp2844 printing incorrectly with paypal multi order
Anyone solve this problem?
Posted on Sep 03, 2010
Zebra ZM400 drops interface on port 515
make sure you have no network traffic for your printer and decrease the printing speed, and make sure you are using a free port not a used and default port for the service..
Jul 20, 2014 | Zebra ZM400 Thermal Label Printer -...
The print out of ZM400 misalign to the left. How to make it back to the centre of the label?
Printing from an Internet Browser can cause this result if you have not set the margins, footers, and headers.
File ' Page Setup
Change all margins to 0.01 (or as close as possible, it may override you) and all SIX bars below that to Blank or Empty.
Apr 10, 2013 | Zebra ZM400 Thermal Label Printer -...
We're using 4.00 X 2.00 inch labels. The barcode is printing just under an inch long when it should be about 2 inches long so our scanners cannot read the barcodes. The text is printing out the
in some barcode software you can see the preview. if you click on the barcode itself maybe you can stretch it out to fit better. or try swapping to 2 by 4 format and see if that works. good luck
Aug 12, 2017 | Zebra ZM400 Thermal Label Printer -...
Zm400 media darkness settings get reset after printings lable from SAP
The printer driver settings override the printer settings unless you tell the driver to use the printer settings. You can tell by setting the printer setting and saving it permanently. Print a configuration label. Send a label to the printer. Print another configuration label. Compare the config labels and If it changed, then the driver changed it. Set the driver as above and it will not change when you print.
Jan 18, 2013 | Zebra ZM400 Direct Thermal-Thermal...
Will not print onto the label. but can see it on the black ribbon reel.
Perhaps your darkness is set too low, or your labels are not coated to accept thermal transfer printing. Let me know if this helps!
Aug 28, 2011 | Zebra ZM400 Thermal Label Printer -...
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Zm400 print a part of a label. Hello, my Zebra ZM400 only print 1/5 last part ot the barcode label. Could you please tell me how to fix it?
What part, rigth site or bottom site?
check the lengt and the with from the driver and print the testpage (have to print on full label)
if is one of the sides, try to give more pressure to that side on the printhead.
Nov 17, 2010 | Zebra 203DPI Printer
Printing and counting problem with Zebra ZM400. We have connected a Zebra ZM400 to our network and we now have a problem with printing. When we print he prints the labels 1 by 1 instead of de total...
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
May 20, 2010 | Zebra Z4Mplus Label Printer
Zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
Error condition ribbon out in ZM400
In the printer setting-
Change the Print Method from - "Tharmal Transfer to Direct Thermal" and save it permanently
Aug 10, 2009 | Zebra 105SL Thermal Label Printer
Zebra Stripe S600 Thermal Label Printer Logo
303 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
