Question about Samsung SMH7178STD Microwave Oven
Sylvania Microwave Our Sylvania microwave SR-11092G in the camper continually runs when we plug it in. The LCD display is not lit up. Can this be repaired or do we need to replace it?
  • Samsung Master
  • 9,098 Answers
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order part # QSW-MA085WRE0 from Tritronics.
Posted on Nov 21, 2008
Sylvania model SR 11092G only inside light works panel lights does not work
I would check the primary and secondary door switches to make sure the contacts are closing when the door is closed.
You could have an issue with the power supply to the control panel. Check to see if there are any blown fuses on the circuit board. If there are, it would probably be best to have a technician repair it, as something else on the board probably caused the fuse to blow.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
May 10, 2016 | Microwave Ovens
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
Feb 11, 2015 | GE XL1800 1100 Watts Microwave Oven
Sylvania 11092B SR microwave problem?
you can check the fuse with a multimeter or take it to the hardware store and get a new one. they are cheaper than a new microwave. If it still blows the microwave fuse check for magnetron numbers may need to replace it.
Jan 08, 2014 | Microwave Ovens
No Power to anything in camper other than the Microwave Oven?
The main fuse has probably blown in the microwave oven.
Apr 15, 2012 | Microwave Ovens
The microwave (Sylvania SR11092B) has power but nothing on the key pad works no matter what you push. Help!!
How do I order a control panel for a Sylvania SR-11092B/SR-11092BNG microwave for my RV?
Jul 23, 2011 | Microwave Ovens
I have a Sylvania Microwave Model SR 11092.When you plug it in it runs but no heat.You have to un plug to stop.Light fan and turntable work fine.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Feb 11, 2011 | Sharp Microwave Ovens
The microwave does not work.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
You may have a failed keypad or control board.
We repair these for customers nationwide with our guaranteed $39.95 service.
Aug 07, 2008 | Whirlpool GH7155XHS Microwave Oven
Microwave Ovens Logo
398 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
