Question about Konica Minolta magicolor 2400 Laser Printer
Konica minolta 2400w error light at startup
I turn on the printer and it starts its warmup cycle, then error "lightning" light comes on. I reset many times before warmup is successful, but lately I cannot not get past the error light at all. One tech said it may be fuser unit not hot enough and needs to be replaced. What is wrong with this printer?
  • Konica Minolta Master
  • 1,879 Answers
It looks like your issue is related with the FUSER as you can go past the "warming-up" stage before.
The FUSER melts the toner powder to the paper that's why it needs to be warmed-up before operation..
A FUSER replacement is the next logical step.
Posted on Nov 19, 2008
    Sergeant:
  • 276 Answers
The error light comes up for many reasons. 1)paper tray not fitted properly. 2)paper jammed in the printer. 3)paper sensing sensor loose or broken 4)fuser unit nor getting quite heated. 5)if there is no paper in the printer. 6)power cord of the printer not connected properly. 7)tap all the sides of the printer for several minutes if any of the sensor is getting blocked somewhere comes up in the proper position. 8)if the cartridge is completely over the error light comes up. 9)if the gears r getting blocked by any foreign objects it needs servicing internally. as per the enginer said u about the fuser option is a rare chance to get faulty.but if it is the fault it is very much costly to get it replace. thanks.
  • smarttech Nov 19, 2008
    unplug the main power cord of your printer from the electric outlet for some time then again insert in in the electricoutlet and ON the printer.many a times it get resetted and starts working normal.
    also if you have a air blower with you open the printer cover and blow air in the printer from all the sides if any thing got stuck in the printer lower area it will be blowned and the printer will start working.
  • 4,806 Answers
Try re-intall the drivers! seems to work for linux/ubuntu users
hope this helps
regards
Hey I have konica minolta magicolour 2400w printer. When i turn it on, it start warming up but after 3 seconds it turns on the ERROR light & the printer doesn't work. Every time i turn it on same issue...
Hi
Usually these machines give you an error code on the control screen. You do not mention one but the webpage here:
Error Codes Konica Minolta Magicolor 2400W
gives most of the error codes for your model.
and also by changing the drop down menus along the top of the page you can view other errors for your machine and for other models and makes. You can also use the link to get a Service Manual for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Office Equipment & Supplies
Konica Minolta 2400 laser printer has a slow, 52 times per minute, yellow lightning bolt flashing on its control panel on the front right of the machine. It seems to be locked up. It wont print or r
Sir bad idea to replace with partial one. Replace with OEM cart Brand New machine counts how many prints for several different parts in the machine when it reaches certain counts on certain part it wants NEW stuff.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 18, 2014 | Konica Minolta Magicolor Model 2400w Color...
Konica minolta magicolor 2400w ready light steady error light blinking possible issues?
The possible reason for error is the printer does notread chip on the cartridges.
The reader for chips locate inside the printer bottom ofcartridges.
Take out all cartridges and you see reader it is a small blackplastic which come three contact plates.
Just clean it with compressed air and take out if some contactplate is sedentary.
Nov 13, 2010 | Minolta magicolor 2400W Laser Printer
2400W error light keeps on blinking even before connected to PC ?
Start the Konica Minolta Status application from your PC, it will give you more details about the error.
Jul 03, 2009 | Konica Minolta magicolor 2400 Laser...
QMS Minolta 2400W doesn't print
try lifting the drum assembly, at the back of the assembly there is a fuse. replace it. hope this helps
May 25, 2009 | Minolta magicolor 2400W Laser Printer
Replaced drum error light blinking
Start the Konica Minolta Status application on your PC and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Apr 14, 2009 | Konica Minolta magicolor 2400 Laser...
Konica Minolta 2400W Magicolor. Error light blinking
Ready indicator Error indicator Condition Action
Green Orange
Blinking Blinking Communication Check The Printer
error cable
____________________________
Print over-run Turn off the printer.
After a few seconds
turn on the printer
change to a lower
resolution.
________________________________________________________
This may help if not...let me know........Whytfang
Mar 25, 2009 | Konica Minolta magicolor 2400 Laser...
Error light
Start the Konica Minolta Status application and check the error, you should get more info there.
Feb 04, 2009 | Konica Minolta magicolor 2400 Laser...
Error light flashed when trying to print with Magicolor 2400W
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
137 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
